I have found that if you just want to leave the camera open for one long exposure, the Canon's are a better solution. With a single long exposure, you have to have long exposure noise reduction on, (not for noise, but for stuck pixels,) it has nothing to do with traditional digital noise. The longer the camera stays on, the more stuck pixels you will get. These may or may not be taken out by LR as it seems to be very dependent on the file/camera. For sure you have to be shooting a raw file if you shot as jpg the only way to get them out is to manually do a dark frame subtraction in photoshop and I have yet to find any of them that really get the stuck pixels out as they seem to leave a halo or shadow.
Canon will allow you to buffer even the long noise reduction dark frame. You can more than likely get 3 40 minute shots off back to back with Long noise exposure one, after the 3rd, you will be locked out for about 20 minutes, until some of the buffer is freed up. With Nikon if you have it on, you are locked out until the dark frame is finished.
Gaps,
You will get gaps even with a single exposure. I have read many reasons for this but on a single frame they are very faint. If you stack, you most definitely will get a faint gap. This effect can be again very faint and seems to be made less or worse with selected aperture. There are a few software tools to remove the gaps, and the one I use is call startracer. It's very inexpensive and works only on a windows platform. Takes a few tries to get a hand on it and it seems to be very selective on colorspace. I have had a few problems using it with anything else by sRGB images. But it for sure works.
Ed, nice shot, nothing wrong with that one.
Paul Caldwell
