Results 1 to 7 of 7
Thread: LCC on C1
    Nov 2008
    Chicago
    548
    LCC on C1
    Just beginning to use LCC in C1 (v6 so far). Does anyone know the difference between the three different settings in setting up the LCC, the first which is just "analyze", the second to "exclude dust" and the last for wide angle lenses?
    Do people find that they sometimes don't accept the full amount of light falloff correction as well?
    Thanks!
    Geoff
    NYC
    3,274
    7
    Re: LCC on C1
    Quote Originally Posted by Geoff View Post
    Wide angle is meant for small micron backs (P40/P65+, IQ140/160/180, Aptus II 8/10/12, Credo 40/60/80) when used with Schneider Wide angle lenses like the 35XL. It does additional correction for some kinds of artifacts unique to these combinations. When in doubt I use this option. When it's clear that it doesn't apply (i.e. 72XL with a 45+) I turn it off.
    The option to exclude dust correction makes the LCC calculation much faster, but precludes the option to remove dust from the image based on the LCC. This option is appropriate to check if you follow the "library" method of LCC.
    I find I often correct 100% of the fall off but then add slight vignette to reference/simulate/echo the natural vignette of lenses that dominates many classic landscapes. It focuses the eye inward in the frame and prevents the eye from "falling off" the edge. But by doing it with vignette after fully correcting the natural vignette I insure the amount of the vignette is the same from one image to the next regardless of aperture/lens/movements used and regardless of whether the full frame was used or only a crop (imagine a crop of the left side of the frame, the natural vignette would only be on the left side, which is just visually awkward).
    Nov 2010
    NYC
    1,575
    4
    Re: LCC on C1
    For reasons I don't understand, correcting 100% light falloff often makes the entire picture 1 to 2 stops brighter. Easily corrected, but still strange.
    --Matt
    Nov 2008
    Chicago
    548
    Re: LCC on C1
    Doug - Thanks for this. Does this mean that for the larger micron backs (7mu and up) that the simpler LCC, with dust removal, is an adequate choice?
    Sep 2011
    1,068
    83
    Re: LCC on C1
    You may want to download C1 v7.02 and give it a test drive for the highly revamped LCC tool. I think this alone is worth the price of the upgrade. Aside from better correction, it is just so much simpler to use. If you have the time, give it a shot.
    Senior Member etrump's Avatar
    Jan 2009
    1,206
    Re: LCC on C1
    You will also want to use the wide angle feature on Rodenstock 32 and wider and perhaps 40 if you are using the full image circle.
    Ditto on C1v7, it handles the LCC exposure the way you will most likely shoot them to obtain full benefit.
    NYC
    3,274
    7
    Re: LCC on C1
    Generally speaking yes.
    I still might be concerned with a 7mu back if you use some of the especially extreme-design lenses like the Schneider 28XL with movement. With such outlying cases you may wish to turn on the wide-angle option.
