Capturing a Firework with DMF ?
Stan ROX
Hey,
I'm thinking about doing a firework photography and would love if somebody has some tips and tricks for me to start with.
Is it the right tool to use a DMF, or is my Nikon D600 the better choice (re ISO)?
Thanks in advance
Stan ROX
gerald.d
You don't need high ISO for fireworks - they're plenty bright enough, and you'll probably be wanting a 5-10 second exposure to get decent trails. ISO100 and f/8 work well for me.
(worth adding that that's a basically unprocessed image - plenty of scope in there for bringing up the foreground a bit)
dougpeterson
As long as the back handles semi-long exposures well you will love the results.
I've found color fidelity during highlight recovery and smoothness in roll offs to blown highlights can't be beat by a Phase and Capture One v7.
Shashin
I would say go for it--I think Ed hurst has some firework images at GetDPI too taken with a Pentax 645D. The trails are bright and reaching saturation can actually be a problem. Good tripod and long exposures. Then it is just timing--before the rocket goes off will give the flower-like form. You can almost time it by when you hear the launch.
rga
You can also use an old trick: Take a dark hat with you and leave the shutter on B with the hat blocking the light (over the lens). Then remove the hat for a couple of seconds (as previously suggested) and you can have fireworks at different times appear on the same file.
Of course you could also blend but that, IMO, would be a lot more work...
Good luck and please post your results!
Bob
Shashin
A hat? Great, another thing to buy! And I suppose a cheap Joe's Gas Station cap will not cut it...
aeaemd
Try to get the first few rounds before the smoke get too much. if it is a slightly windy night, that will help clear the smoke in-between.
I would use a fast tripod head(e.g. ball head) because yo might to adjust quick in-between firings for reframing, it is hard to predict how hight they will go sometime. the cube would be too slow for fast adjustments.
