Results 1 to 17 of 17
Thread: Alpa Users: How do you cover your MFDB in the field?
    Jan 2011
    Palo Alto, CA
    621
    Wondering how you Alpa tech camera users keep your back's sensor covered out in the field.
    Currently, after working a venue, I take the back off the Alpa mounting plate (I use an HV mount), put the back's cover over the sensor and back in the pack. I'm thinking about leaving the back mounted to the Alpa HV plate and putting an Alpa plastic cover over the non-sensor side of the mounting plate. I fear sometimes when I mount the MFDB in the field on the HV plate that it will slip and I'll really damage the sensor.
    Thanks for your input,
    Bob
    PS- I break down the camera after each venue: no carrying on tripod allowed...
    KEMPTEN / GERMANY
    1,513
    116
    Re: Alpa Users: How do you cover your MFDB in the field?
    I use a CFV-39 and CFV-50 each mounted on a shimmed ALPA adapter and put the ALPA plastic cover onto the non sensor side of the adapter .
    I find this procedure much safer and handier than putting the HASSELBLAD cover directly onto the back .
    Regards . Jürgen .
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,196
    I never remove the back from the Alpa adaptorplate. Usually I only move the back from one body to another, or change from horizontal to vertical position.
    All my bags are choosen to hold a lens/body/back in place since I do not want to take it apart every time. For me this is important.
    Those rare times when the back is apart I store it with Alpa adaptor and Alpa protection.
    Alpa FPS • MAX • TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 • Leaf Credo 60 | www.danlindberg.com
    KEMPTEN / GERMANY
    1,513
    116
    Regards . Jürgen .
    Jun 2008
    SoCal
    291
    15
    Back plus adapter always mounted on Alpa camera also in the bag. In the bag it's stored with the 35XL lens mounted. If I need to change lens, I do that after the camera is mounted on the tripod. Quick and easy.
    Cheers, -Peter
    Vancouver, WA
    5,803
    564
    I do exactly the same as Jurgen, Dan & Peter. The back is always mounted on the Alpa mount and/or body.
    However, I will remove the Alpa cable release and sync cable if I will be hiking and risk placing any pressure on the bag. I NEVER leave the cable release mounted obviously.
    I do carry my P25+ also along with the IQ160 - if it's mounted on the TC it stays there. If I'm just bringing the back alone then I leave it mounted to my 2nd back plate and use the Alpa plastic plate cover. If the body is in the bag without a back then I use the hard resin/platic Alpa back body plate in the body.
    Vancouver, WA
    5,803
    564
    Quote Originally Posted by rga View Post
    Bob
    Btw, I am the poster child for exactly this case. This was caused by exactly such a slip and the hard prong on the back of the plate found the IR cover on my Aptus 65 a couple of years ago. Lesson learned quickly.
    Santa Monica, CA
    2,275
    2
    Graham,
    Did those cracks affect image quality?
    Steve
    Vancouver, WA
    5,803
    564
    They made for a very interesting stained glass window mosaic filter and also wallet emptying effect since I bought my P40+ to replace it. (Btw, it lives on today with it's replacement IR glass)
    In all seriousness though, keeping the Alpa base plate on the back is definitely the best way to go when just using the Alpa. I only remove the body from the plate when I either put the back on my DF or I need to clean the sensor with anything more than a bulb blower. The extra protection and distance of the sensor from harms way is useful with the Alpa adapter mounted.
    Shashin's Avatar
    May 2011
    Florida, USA
    4,502
    141
    An LCC can't handle that?
    Vancouver, WA
    5,803
    564
    No need, just buff it out with an old T-Shirt.
    Jan 2011
    Palo Alto, CA
    621
    Thanks everyone. I am VERY glad I asked; my back is now on the plate with the Alpa resin cover.
    Much appreciated,
    Bob
    Feb 2011
    New York
    79
    The $100 "old" covers were terrible since they bend out of shape with weather changes. This to the point that they would fit nice and loose on my DB. The "new" cheaper ones are finally fitting snug on the DB. Alpa as a courtesy and good service replaced all my old without a charge. Throughout a shooting day I'll take my DB off many times and the Alpa covers are by far the easiest and safest way to go.
    Vancouver, WA
    5,803
    564
    The resin covers are definitely temperature sensitive. Sometimes they're easy to fit/remove and other times pretty rigid and tough to get off.
    Maybe time to upgrade them ...
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by stephengilbert View Post
    Graham,
    Steve
    Regards . Jürgen .
    KEMPTEN / GERMANY
    1,513
    116
    Because of that temperature sensitivity , I have replaced ALL covers with the new type . Initiated by the issue with the cover for the HR 4,5/28mm , which sometimes even fell off .
    Some were replaced by ALPA for free and I got some additional ones .
    No more problems since .
    Regards . Jürgen .
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    971
    I carry the back mounted to the STC with the small plastic cover on the lens-side of the camera. I have in the past carried it with a lens mounted, but I seem to always be swapping lenses, so it didn't really save time. Another factor for me is that I use the sk150 quite a bit, and leaving that mounted on the camera would take up a lot of space.
    Dave
