How to trigger strobe from Technical Camera?
Guy Mancuso
Administrator, Instructor
Sure you hook your Pocket Wizard with mini cord attached to it than the other end is a PC end that connects directly to the sync port ON the back.
jagsiva
+1 on what Guy said. Again, I would use a radio solution as I personally would be anxious hooking up a sync cord directly from the strobe to the back.
Added bonus is you get the LS sync speeds, 1/500 in my case.
Take a look at some of shortballer's images in the tech cam images thread, so really stunning work.
Shashin
You can use a cord or a radio transmitter. I have done both with a P25+ on a Linhof C679.
gazwas
Very true as long as you know the sync voltage of the flash equipment you are using is safe. Some older flash equipment have a high sync voltage and can damage the back and why it is safer to use radio if in any doubt.
Same goes for any modern digital camera, not just medium format.
Hard to see in this picture but there is a pocket wizard on top of the camera triggering Bowens Gemini Pro heads.
Guy Mancuso
Its a much better day if blow up a Pocket Wizard over a back any day of the week. LOL
Seriously its also one less oh **** I tripped over the freaking cord on the floor with a 30 K back on the other end.
Thank you everyone. I have Pocket Wizard and always used on DF, however I didn't know that it can be connected to the IQ DB as well. Never opened the manual. LOL!!!
stngoldberg
Does anyone know how to employ a flash (quantum for example) with an H4back attached to a RM3Di? Neither my dealer nor Quantum seem to know if it is possible.
Stanley
