Question: Olloclip + Viewfinder Pro
Marlyn
All,
Does anyone know the correct Lens factors to use in Viewfinder pro, for the OlloClip WIDE and OlloClip FISHEYE Lenses ?
I've been looking around the net, and I can't get a clear answer.
Regards
Mark.
jctodd
I estimated mine as 0.7 for the normal (non-fisheye) lens. I simply took one of the existing frames, noted the field of view, put the Olloclip on and tried different factors until the field of view matched the frame again.
Marlyn
Thanks.
I was just doing that today actually, and estimate the Wide Angle to be 0.5x
The FishEye seems to be wider than the 0.38 of Viefinder pro unfortunatly, which is annoying.
Seeing if I can compensate by messing with the custom back/camera sizes to account for it. I only need it to work for measuring pano off the 32mm HR. So may setup a 'custom' camera for just that one.
Regards
Mark.
