Results 1 to 19 of 19
Thread: a good battery for a firewire repeater...
    May 2009
    Marseille, FRANCE
    972
    My Macbook pro being out of order, i need to buy a new laptop !
    Apple stopped the Macbook pro 15" 2,6 with 1 Go RAM...
    So, i'm considering buying a retina... but before, i have to make shure that i will be able to shoot with my Leaf Aptus II7 with it...
    The firewire/thunderbolt adapter can't provide enought power... so you need to use a powered repeater...
    i've bought a really good quality one... Unibrain
    No, i need a good battery pack for it... price are from 10 euros to 800 !
    Any suggestion for the good value for money battery pack ?
    i'm in france, so 220V !
    DC Power connector: Walkman-type 2.0 mm DC
    Power Input Range: DC 8V~30V, max. 1.35A.
    Power Consumption (at 12V DC): 1.5W max.
    FireRepeater-800 Pro: Four and Five ports industrial 1394b (Firewire-800) Repeaters
    2,798
    Re: a good battery for a firewire repeater...
    Toms Hardware reviewed batteries here:
    Tekkeon myPower ALL Plus MP3750, MP3450, MP3450i : External Battery Roundup: Stay Away From The Wall Socket
    I used the Tekkeon for you desired hub power...for the H3D II 39 back...but I am unable to ascertain if its power supply for charging is still universal, although I do think so.
    BH Photo carries a number of the Tekkeon batteries.
    Bob
    Mar 2010
    Lindenberg im Allgäu
    1,294
    12
    I can recommend Mili products- am using a power adapter for my iPhone (3000mAh) from them for 2 years now.
    18000mAh MiLi Power King F iPad,Laptop,Galaxy Tab,Phone | eBay
    Regards
    Stefan
    May 2011
    Hong Kong
    691
    I use this one: Energizer® XP18000 Portable Charger for Laptops | External Battery | Portable Charger and it works fine. There's a 19v output (for laptops) that would be required for the firewire (which is 16 to 30v IIRC). Mine is 220/240v
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by wentbackward View Post
    so that's one is easily available in france... is it ok for my Repeater ?
    by the way, in the package content pdf, i can't see any adaptor for macbook...
    http://www.energizerpowerpacks.com/i...PC-XP18000.pdf
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by Stefan Steib View Post
    Regards
    Stefan
    thanks, but the link is broken !
    searching for Mili products, while it looks really good for iphone, i can't find one for my purpose...
    May 2009
    Marseille, FRANCE
    972
    "by the way, in the package content pdf, i can't see any adaptor for macbook... "
    it looks like, they are working on it... but apple...
    i'm an apple user till 1996, it was a good ideology at the start...
    the computer needs to adapt itself to the user...
    now, the only ideology seems to be... the user is a consumer, how can we force him to buy only apple product$...
    grgrgrggrgrrr !
    May 2011
    Hong Kong
    691
    Quote Originally Posted by archivue View Post
    Yes it will work in that range.
    Regarding the macbook connector, the shop in HK had them here quite cheap, but since I upgraded to an air the adapter changed and now I haven't been able to get one again!!
    If I find them I can let you know.
    Paul
    May 2009
    Marseille, FRANCE
    972
    ok, thanks !
    May 2009
    Marseille, FRANCE
    972
    a forum member, inform me that the energizer solution isn't enought to keep the mfdb working...
    Maybe we should use a quantum... ?
    May 2011
    Hong Kong
    691
    It works for me! You need to keep a battery in the back though, but I've used it for hours with no problems.
    May 2009
    Marseille, FRANCE
    972
    with aptus and aptus II you CAN'T use a battery in the back while a firewire cable is connected !
    May 2009
    Marseille, FRANCE
    972
    here is the mili that stefen steib was referring to... it looks similar to the energizer !
    MiLi Power King
    May 2009
    Marseille, FRANCE
    972
    if i can't find an ideal solution, i will probably buy a non retina macbook...
    http://www.getdpi.com/forum/medium-f...leaf-user.html
    May 2009
    Marseille, FRANCE
    972
    Here is an other challenger...
    CAlumet powerblock 900...
    it looks like, it is compatible with the Quantum SD16 cable.
    Do you think it will works with the repeater ? and with a leaf back using the leaf plug ?
    http://www.calumetphoto.com/etc/us/p...001-manual.pdf
    May 2009
    Marseille, FRANCE
    972
    the powerblock is only 2000mAh...
    I can't find this information for the Quantum Turbo 3 !?
    May 2011
    Hong Kong
    691
    Oh yes, it's been a while since I switched from the leaf, it has that plastic plate you put in place of the battery.
    So I'm powering an IQ back but also using a powered cable not a firewire hub. Basically what I have is a small circuit board that is permanently attached to the end of the cable, there are two are firewire IO ports the other is DC power.
    If your hub can already power the back (using the DC output) all you need is a battery that can match that output. You could go to a specialist RC shop and get a lithium battery, these guys push the boundaries of their batteries and should be able to offer advice. You could also check a resource like this. They should also be able to advise on getting the certificate for aeroplane travel.
    May 2009
    Marseille, FRANCE
    972
    "You could go to a specialist RC shop and get a lithium battery, these guys push the boundaries of their batteries and should be able to offer advice."
    this isn't an option over here !
    i've tried many times... without success ;-(
    i think i will try the energizer first, if it doesn't work, i will keep it for iphones...
    The safe way, seems to be a quantum Turbo 3... but really expensive over here... 700€ !
  19. #19
    Mar 2012
    Slovenia
    62
    Keeping film photography and printing alive!
