Results 1 to 19 of 19
Thread: Kapture Group cable
    Sep 2011
    1,068
    83
    Kapture Group cable
    I have been using the capture group cable for some time now and had occasional errors with the back syncing properly.
    On a recent trip, especially on longer exposures, 1/4s or less, it became quite frequent. Particularly when doing LCC's when I had to leave the shutter open longer. On T and B it was even worse.
    Luckily, I had my backup, 2 cable solution. I was able to use this with 0 latency as well as the two-push method without any issues. The 0 latency does eat through batteries and I have heard could heat up the back and introduce unwanted noise, although I have not personally done any testing in any controlled sense.
    Has anyone experienced this? Just wondering if I have a defective cable or if there is some issue that I am not aware of.
    Cheers...
    Vancouver, WA
    5,800
    564
    Re: Kapture Group cable
    This sounds like my experiences with the KG cable and why I ended up biting the bullet and buying the Alpa release instead. It also will occasionally double trigger but I know when & why (if the adapter gets a little loose). It cost 2x the KG adapter but it is more reliable and better built. I ended up buying two not because I wanted to but because I typically shoot two lenses and it was easier to have one on each as it takes time to replace it each time.
    I also use zero latency mode with my IQ back. It does build up heat if you don't turn it off after a while. In fact it'll literally get almost red hot if you forget and don't have an auto power off enabled - one of my shooting buddies here did this in So. Cal and his IQ was literally too hot to handle.
    Aug 2012
    Singapore
    32
    I was using KG cable with Hasselblad 203FE and Leaf Aptus 65 back. Never had any problem with this combination though I haven't used it for very long time as I've sold the back
    Sep 2011
    1,068
    83
    Thanks for the input gentlemen.
    Graham, I don't have the option of the Alpa release as I am on Arca. I guess I will just have to get used the the double click, but I suppose It's no different from the old MUP workflow
    The other issue I had with the KG cable is that it is just so damn rigid, and the short bit goes into the lens, particularly some of the tiny Schneiders is sometimes a PIA to get out, especially in the cold when your fingers are frozen.
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by jagsiva View Post
    Hi
    It you find it is a PITA to connect the cable to the shutter release, - I use these
    Gepe Cable Release Extension for Recessed Lensboards 603007 B&H
    I have seen rigid ones made by Gepe, but have not first hand experiences.
    Phil
    Jan 2012
    central europe
    101
    26
    i'm on arca too and would like to have a good solution to this as well.
    why do you think it isn't possible to attach the alpa release? you can screw in non "arca modified" releases as well.
    i'm concerned about the price tag - man, 700€ for the release plus cable
    once the mirror was up, you could use both hands again.
    but today i have to press one release with my left hand and the other with my right hand while the third hand has to held the lcc plexi ...
    www.thomasebruster.com
    _______________________________
    Arca Rm3di|RS90|SK43|RS28|CFV-50
    Sep 2011
    1,068
    83
    Quote Originally Posted by alajuela View Post
    Phil
    Thanks Phil. This will help, but may also make the whole thing even more clumsy. When using the 32HR, I'm always pushing cables out of the way....and the stiffness of this particular portion of the cable makes it cumbersome.
    Dec 2009
    87
    I had the cable failed in two occasions. The short cable release cable is held on to the black switch box by two small set screws, and it got loose. My solution was simply 'super glue' to the box instead of relying on set screws. Only part which may cause the problem is a small 'micro switch' so slightly loose cable release could be the culprit.
    It could save you $$$ if the super glue solution works.
    Jae M
    Vancouver, WA
    5,800
    564
    Granted the Alpa release isn't cheap. However, neither is the KG and NOTHING is cheap if it doesn't work!
    Jan 2014
    188
    HI Guys,
    do you have tested the Phase One Wake up cable? Is it OK?
    Could you use the alpa release Cable with cambo or Acra too?
    mueller
    Vancouver, WA
    5,800
    564
    The wakeup cables work with any technical camera that has a copal shutter so yes it will work with Cambo and Arca et al.
    Regarding the Phase One wakeup cable, it has a little button on it that needs to be pressed before releasing the cable release. It will also work with any of the technical cameras.
    Sep 2011
    1,068
    83
    phase cable works well. You jut have to push a little button and you have 5 seconds. Two issues:
    1. It is another step, and sometimes, by the time you get your crap together, hold the LCC card on the lens, the damn thing has already timed out.
    2. The timer starts right away. So if you are using the onscreen timer for your exposure, you have another mental calculation to do on exactly when you released the shutter.
    An update on the KG cable...the usability issues, stiffness etc. are still the same, but I recently had the sync post on my back replaced. The sync post is not used with the KG cable, but for whatever reason, it is far more stable and consistent. I also replaced the trigger end with a Leica cable which is far more pliable.
    23,623
    2555
    I absolutely despise that Kapture group cable. I always used zero latency with a straight cable from PC outlet to back and a separate cable release. One trick is just turn back off when your done shooting or just waiting. Never had a heat issue and really doing landscape work never went over 3 batteries in a day. YMMV
    I've seen that cable go down at least once with a attendee on ever workshop I have done. I can't tell you how many times I have stopped to help someone out during a shoot to get them going again.
    www.guymancusophotography.com
    Santa Monica, CA
    2,272
    2
    Although it is quite expensive, the ALPA cable is a clear improvement on the KG and Phase versions. Also, it allows use of a cable release or a button mounted directly on the lens.
    Senior Member PSon's Avatar
    908
    145
    Even super glue is not cheap if it does not work.
    ALPA (MAX, STC, TC) | CAMBO (Actus DB2, WRS-AE) | CONTAX | HASSELBLAD | LEICA | DB (CFV-16, CFV-39, IQ180, IQ360, IQ3100, P45+) | Lens (Canon, Fujinon, Leica, Nikon, Pentax, Rodenstock, Schneider, Zeiss)
    Sep 2011
    1,068
    83
    Quote Originally Posted by stephengilbert View Post
    Does the Alpa release attach to any lens or only those on Alpa mounts?
    Cheers..
    Santa Monica, CA
    2,272
    2
    To quote the inestimable Graham Welland:
    "The wakeup cables work with any technical camera that has a copal shutter so yes it will work with Cambo and Arca et al."
    KEMPTEN / GERMANY
    1,513
    116
    It even works with a PRONTOR PROFESSIONAL shutter . In the same way , than with the COPAL .
    Regards . Jürgen .
  19. #19
    Little Rock AR
    1,925
    3
    I use the Kapture group cable on my 260 and before on my 160. I agree with Guy it's a bit stiff and can be hard to work with. I prefer the workflow and don't mind the bit of extra fiddling.
    Mine will miss sync about 1 out of 25 shots, but so did my wake up cable solution, I guess since I didn't move quick enough. The latest Phase One firmware of 5.10.1 seems to have no ill effects on this setup.
    I also use the Gepe extensions on the lenses with the short mounts mainly the Schneiders, as the Rodenstocks allow a lot more room to move around and get the cable attached. However the 28mm Rod is still a bit hard and I have an extension for that lens.
    I also always carry the backup of the Phase One wake up cable just in case.
    In Arkansas in the spring and summer, zero Latency is a real heat build up enough that you will feel it hot to the touch. Working in outdoor temps of 85 to 105 degress with 100% humidity.
    Zero Latency to me drains the battery 50% faster and I feel if left on in combination with WiFi and a lot of LCD checking, the battery is done in less than an hour. That is what I have seen with my two backs.
    I am using it on the rm3di.
    Paul C.
