Results 1 to 11 of 11
Thread: Focusing the DF+
    Aug 2012
    Shanghai / Miami
    552
    124
    Focusing the DF+
    Hi
    Has anybody noticed or have an opinion on the improved focusing ability of the new DF+.
    I remember Jack recommended the speed setting and a triple or double tap on the DF.
    Phil
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Focusing the DF+
    I have tried the DF+ on a limited basis.
    first, the adjustment for each back is good but limited in the sense that it does not provide adjustments on a per lens basis unless you do one lens/ back combination per custom settings set.
    Other than that, it MAY have focused a bit better than the DF but not dramatically so.
    -bob
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by Bob View Post
    -bob
    Thanks Bob,
    I have not messed with back adjustment. I was out shooting yesterday and think I missed more shots than usual. I was on a monopod. On the DF, do you use the center focus point (spot focus) or all three, (Center , right, left).
    I do think the camera is slightly better than my DF, which I traded in.
    Phil
    Prescott, Arizona
    4,492
    367
    I only use the center focus point since the uncertainty of the rest just drove me MAD!
    -bob
    Dec 2010
    Southern California
    141
    21
    I have 2 issues with my 645DF+, but they are not with the autofocus.
    I don't have any complaints about the autofocus. I think Jack said he doesn't need the second and third tap anymore with accuracy mode.
    One issue is, I have to setup the custom fuctions I want every time I use the camera. When the camera is off for a while, it forgets them.
    The other thing I've found is, the autofocus assist beam can actually come on during an exposure. Then the red beam on the subject would ruin the picture, like this example:
    --Steve.
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by steve_cor View Post
    --Steve.
    Thanks Steve, So far I have not experienced the issue of the auto focus beam, - that is a real problem!! Lucky it is still under warranty. Do you know if Jack changed to accuracy on the DF+?
    Phil
    Aug 2012
    Shanghai / Miami
    552
    124
    -bob
    Hi Bob, do you the use speed or accuracy setting on the DF+
    I agree not dramatic improvements, but I find the buttons (Timer) are more responsive. And seems slightly "tighter" like the AFL and AEL buttons also.
    Phil
    Dec 2010
    Southern California
    141
    21
    Well, Jack doesn't have one, he just used one at a workshop. He said with the accuracy mode, "there was never a need for the third tap and rarely a need for even the second tap."
    I think it depends on the lens, and the subject. With the 150mm f/2.8, even in accuracy mode, the camera may adjust the focus on the second and third tap. You have to decide for yourself which mode works best. I prefer the accuracy mode, and only use the center focus point.
    --Steve.
    Aug 2012
    Shanghai / Miami
    552
    124
    --Steve.
    Thank you Steve, I think I will switch over to the accuracy mode. I have been shooting with a monopod, when not using a tripod. Found that helps with shutter speed. On Sensor plus and iso 400 handheld is usable for me as I can get shutter speed up to at least 250 at f8.
    Thanks again
    Phil
    Prescott, Arizona
    4,492
    367
    I use accuracy on both DF and would on DF+ as well.
    -bob
    Jun 2010
    270
    I had very bad experience with DF+
    1st : very slow focus, will not lock even outdoor.
    2nd : Defective viewfinder out of the box
    3rd : Demo unit so I can play around, much better than first body.
    4th : finally open my 3rd unit out of the box, focus beat all 3 previous copy. faster. So I bought it.
    I just found out last week that my body produces softer images than the demo unit 645 DF my dealer uses. It is very obvious in side by side comparison. Micro adjust will not fix it because it does nothing at all.
    I am sending it for service.
    So after 4 experiences with DF+ body, my conclusion is that phase one has very bad QC problem!!
