Results 1 to 5 of 5
Thread: Hasselblad H camera back on other systems?
    Feb 2012
    9
    I'm just wondering if it is possible to use the back of an H camera, say, H3D-39, on another system via the ixpress adapter? Or is the ixpress adapter limited to use on CF backs only?
    Thank you.
    Mar 2012
    Sweden
    1,538
    Re: Hasselblad H camera back on other systems?
    Ixpress adapter is only for the CF backs, the H3D-39 has fixed H-mount as far as I know. The H3D-39 will require power from the camera body or some other power source, for example this:
    http://www.silvestricamera.com/ita/c...g.asp?ID=7010K
    NYC
    3,274
    7
    Quote Originally Posted by thminhduc View Post
    Thank you.
    A H3D-39 digital back ("digital magazine") can only be used on the H3 body with which it was originally purchased, or additional H3D bodies purchased and paired/unlocked by Hasselblad to that specific digital back.
    You could also use it on a technical camera or view camera, Mamiya RZ, or Fuji 680 with the appropriate adapter. Note that this will require a cable to the lens and an additional external source of battery power (FW cable or battery pack with FW connection).
    Nov 2009
    65
    Doug
    That's very interesting... Not to take this thread too far off track, but could you elaborate on what it would take to fit a h3dii-31 (assuming same for -39) back onto an RZ67 Pro-II (non-D)? This is the best description I have seen for phase backs (HERE) but never considered the possibility of using the back from the h3dii-31 on an RZ.
    thanks!
    Feb 2012
    9
    Thanks for your replies. Is it because these backs are locked into the camera (or at least to the camera models), they have a lower price as used gears? I've seen some H3D-39 asking for under $10k before.
