Results 1 to 8 of 8
Thread: colorcasting with H3dII
    Apr 2013
    Netherlands
    24
    This photo(100% crop) was shot with H3dII-31 with HC35
    Does anybody know why and how this colorcasting arises? But, more important.. how i can avoid this in the future?
    thanks!
    Mar 2010
    Germany
    253
    Re: colorcasting with H3dII
    To me it looks like standard moire. Slightly changing the distance might help. Using a different aperture normally does help.
    Have a look at, e.g.,
    Imatest - Color Moire
    Chris
    Sep 2010
    UK
    1,387
    Moire not colour cast.
    Only way to avoid on a 39Mpix back is to not focus on that portion of the image causing the issue (often impossible) or try a software fix with moire removal in Phocus.
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    You can remove it very simple. Do you use LR or PS? - And I think, the new C1 should habe an option for remove, too.
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
    Mar 2012
    Sweden
    1,538
    Most medium format sensor lacks antialias filters to provide more pixel-peep micro contrast at the cost of having false colors and moiré. Fabrics is worst case.
    You can remove it (or rather hide it) with software, but the result will be worse than it had been with a proper antialias filter on the sensor. The other alternative is to shoot less sharp pictures by having a smaller aperture or shoot slightly out of focus.
    Yes, being without antialias filter is bad, but MF sells a lot on resolution and being without it gives a pixelpeep advantage and as we all love to pixelpeep (but rarely admit it) being without AA filter is generally seen as a "feature" rather than the bug it is. Be glad that you don't have a 22 megapixel sensor, it would be even worse on that
    Nov 2009
    NYC
    276
    Sometimes a small change in camera angle (position) will eliminate moire.
    Ciao,
    Giorgio Niro
    www.giorgioniro.com
    Apr 2013
    Netherlands
    24
    tanks for the replies!
    This technique worked quite well for me:
    A New Way to Remove Moire on Vimeo
    Member Paul Claesson Hasselblad's Avatar
    Oct 2008
    Union, New Jersey, USA
    89
    I recommend using the Moire tool in Phocus, available for Mac and PC.
    Go to the Adjust tab > Noise filter > Moire
    A level 2 or 3 should do the trick.
    Paul Claesson
    Technical Support Manager
    Hasselblad Bron Inc.
