Results 1 to 8 of 8
Thread: Distortion correction with Rodenstock 40mm
    Little Rock AR
    1,926
    3
    What software/plugins are others using to correct the distortion on this lens? I have PTlens, but it currently doesn't have profiles for the 40mm.
    Capture One if it has a correction, I can't find anything but the "generic" which doesn't seem to do very much.
    Paul Caldwell
    NYC
    3,274
    7
    Re: Distortion correction with Rodenstock 40mm
    Paul Caldwell
    Shoot something with a strong grid pattern.
    Select Generic.
    Dial in "distortion correction" slider
    Save it as a style or preset.
    Use the "movements" tab in the future in such cases as there was a rise or fall or shift.
    It will not correct it 100% (since the slider assumes "simple" distortion and the 40HR has a touch of "complex" distortion). But if it corrects it 90% then you're unlikely to care (based on what I know of your kinds of subject matter) about the remaining 10%.
    Little Rock AR
    1,926
    3
    Doug,
    Thanks, I assume a brick wall? would work. Does it matter on distance from the subject with the grid?
    Paul
    Sep 2008
    Near Brussels, Belgium, Europe
    541
    Alpa offers a free tool to correct distortion of many Schneider/Rodenstock lenses. Options like rise/fall or left right shift movement if applied. it's Photoshop 64b compatible as a plug-in. Works great.
    NYC
    3,274
    7
    Not macro, but otherwise not really important the distance.
    Alpa's tool is great. But it requires you leave the raw workflow. If you can get satisfactory results using Capture One's raw distortion correction you can apply in batch (without open-adjust-save-close) and apply without leaving raw.
    Sep 2009
    Ontario, Canada
    446
    Doug, thanks for the pointer. I have been using Alpa's tool but will try venturing into the deeper areas of C1. Just to confirm, if I enter the shift the distortion model accommodates?
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    970
    You could always use LR/ACR's lens profile maker. I used it on the Zeiss 21 when I was shooting canon and it fixes that lens's mustache distortion very well.
    davechewphotography.com
    NYC
    3,274
    7
    Quote Originally Posted by cunim View Post
    Correct!
