Results 1 to 8 of 8
Thread: H3DII and Sensor Cleaning
    May 2013
    Germany
    233
    has sombody experience with cleaning the sensor of the Hasselbad H3DII 31Mpix? What kind of tools do you use? What kind of fluid?
    Do you only use the Hasselblad service to clean the sensor?
    Thank you.
    cyron
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    Re: H3DII and Sensor Cleaning
    For Phase One you get a Sensor cleaning Kit like this:
    See on youtube.
    But I didn't use it in the past; for me it was enough to clean with a blower. But if you really want to clean your back wet, it's much simpler to do this than to clean a dslr.
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
    Member fmueller's Avatar
    Feb 2010
    Northern Virginia, USA
    95
    2
    Quote Originally Posted by cyron123 View Post
    Thank you.
    cyron
    That would be a hassle. MF Sensors tend to get a little more time out in the open, so you need to know how to clean them yourself.
    Quote Originally Posted by weinlamm View Post
    See on youtube.
    Blower is always the first step, a Rocket Blower is a good first step and maybe the only step that is needed most of the time.
    I am the new owner of a Phase One back and just last night used their tools and methods to clean my sensor and was less than pleased with awkward tools and the results. I finally ended up using some Eclipse Sensor swabs with the phase one solution B after reading THIS After doing this under good lighting, a Solux desk lamp, it looked clean and a test shot into an expo disk verified my work. I also have one of the Pentax Sensor cleaning kits as demoed by the Leica assembly team here (at the 13:20-15:15 mark but have never had the guts or the need to use it!
    Fred
    May 2013
    Germany
    233
    Could i use an Phase One kit for the Hasselbald too?
    See on youtube.
    Santa Monica, CA
    2,272
    2
    "Could i use an Phase One kit for the Hasselbald too?"
    Almost certainly; you're cleaning glass.
    CI sells wipes and cleaning solution here: https://captureintegration.com/product/sensor-solution/
    Note that the Phase kit comes with two cleaning solutions, one that appears to be a detergent, and the other just alcohol. The detergent rarely needs to be used, and is a pain to fully remove. There are GetDPI threads that talk about this. See http://www.getdpi.com/forum/medium-f...-cleaning.html
    Sep 2012
    Germany
    229
    3
    I think so, too.
    And perhaps you can buy a bottle of Eclipse. I use this for every other camera. If I didn't had got the Phase One Kit, I would use this for my MF, too.
    And perhaps you can ask at Microtools what they say.
    __________________
    Christian
    Member Miller's Avatar
    Aug 2010
    66
    Do you know the Hasselblad bulletin? This one is about sensor cleaning:
    Hasselbladbulletin.com
    May 2013
    Germany
    233
    Thank you guys. This is very useful...
