Results 1 to 6 of 6
Thread: Hasselblad hcd 28mm and vingnetting
    May 2013
    Germany
    233
    Do you have vignetting if you use the Hasselblad HCD 28mm with the lee filter system?
    Thank you..
    Cyron
    Apr 2009
    Sydney, Australia
    581
    2
    Re: Hasselblad hcd 28mm and vingnetting
    Not on the 40 but certainly on the 50, 60,and H3D 39
    Jeff
    www.jeff-grant.com
    Senior Subscriber Member
    Sep 2011
    Englewood, CO
    2,489
    1248
    You will have vignette with a 95mm ring adapter.
    Two choices:
    1) Push-on Lee filter holder.
    http://www.adorama.com/LEFK100.html?...FStp7AodwgEAsg
    2) Cokin X Pro holder.
    I prefer #1, although I sometimes either hold the filter with my hand or with graffer tape.
    If you only want to use a filter holder with only for graduate neutral density, bracketing with 3-5 pictures and process them in PS is convenient too.
    It is also good to have several choices.
    Regards,
    Pramote
    May 2013
    Germany
    233
    @ Jeff: ich have a H3DII -31Mpix...There should no Vignetting too....I hope .. is this right?
    @ Paramote: Yes i have the 100 Filter holder from Lee. And you mean that there ist noch vignetting?? OK!
    Thank you
    Apr 2009
    Sydney, Australia
    581
    2
    Check the sensor size on the 31 against the 40. The 40 is a smaller sensor, hence no vignette. My 39 was a larger sensor and did vignette.
    Have a look at this for some more info: http://www.getdpi.com/forum/medium-f...ide-angle.html
    Jeff
    www.jeff-grant.com
    May 2013
    Germany
    233
    Thank you, guys..
