Page 3 of 3 FirstFirst 1 2 3
Results 101 to 123 of 123
Thread: Technical Camera Tech Spec Summary
  1. #101
    Dec 2009
    237
    Re: Technical Camera Tech Spec Summary
    Wait a second. A valuable forum member posts an informative link.
    Instead of a warm welcome, he gets fire for that in an ad hominem way.
    The discussion becomes personal, acid and insulting. With many chiming in.
    One other member threatens to never post again as a result.
    Is this some kind of kindergarten here? I just went through the thread and cannot understand why such a huge discussion can develop out of a spec table.
    Everyone knows that Doug is biased, it says it in his signature!
    Everybody calm down, I just find this discussion over camera spec sheets way out of proportion. There are more important things in life!
  2. #102
    23,623
    2555
    Just looked at the charts , it actually looks pretty good. Now not to say it maybe missing something in Alpa since I don't know the system well enough. But in regards to the 28XL and I did a long review with it and the Roadie 28. Now this was with the IQ160 and at the time C1 was not the latest and greatest version and I did buy the 28Xl which I loved the form factor and the look of the lens BUT I was noticing some magenta cast in the upper right side even after a LCC and even after shooting with no movements it was faintly there. I finally asked Dave for a return of the SK 28 for the Roadie 28 and that all cleared up. So I can see why Doug say no on the 180. Although I never tested it with the 180 its a safe assumption it be a issue. Now again this was with a older version of C1 so and we all know they keep getting the LCC correction better in each version. Today it maybe a different story I don't know.
    Maybe no as Doug states is correct or maybe the word with restrictions possibly would be better . Hard to say since I tested it myself I might just say no as well. Given its a chart that leaves out a lengthy description like I just mentioned or similar than I guess it makes sense. Now I agree any of the bodies this should make no difference the body is really only a go between the most important parts to the lens and back.
    I'm not going to defend Doug's work here on this chart but like anything else in any review or spec its all up to us to use data as a piece of a puzzle and not a absolute. Maybe that should be said in some fashion. I'm not here to tell anyone what write as I see it as pretty valuable regardless. The shift thing with Alpa clearly states with adapter. It's up to us buyers to look that up. I know he made changes as some of the requests came in and I can't remover what they all are but looking at the piece today it looks pretty good. Now that's my opinion and YMMV as always.
    I take a approach to any review or data sharing as a piece of the puzzle and its up to me to figure out if it fits my needs or not. Than if in doubt I will ask questions on this very forum. Obviously with over 18k posts I have a lot of questions in there. Lol
    Anyway I see it as a good effort on his part regardless of how bias he maybe, heck he could have authored it without Alpa in there to begin with, than the sparks would fly. I suggest update Doug and see if he will make those changes but its his piece and his info that he puts out. Honestly I don't change my product reviews to make someone feel better only if I am wrong will I update something. And we count on forum members to help us along the way. At least that's the way I see life. No one has to agree with that either.
    www.guymancusophotography.com
  3. #103
    NYC
    3,274
    7
    Guy are you trying to make sense of this post:
    Quote Originally Posted by darr View Post
    I do not know why he has "No" for the 28 lens with Alpa as I have one and it works well with my Max.
    If so I had clarified in the next post:
    That's under the heading "TS Available" meaning Tilt-Swing available. The 28HR is not available in a short-barrel tilt-swing compatible mount from Alpa.
    You're absolutely right that the body has no impact on whether a given back+lens combination works well regarding acceptable lens cast. In other words the 28XL produces poor results (even without movement) on an IQ180 regardless of what body is between the 28XL and IQ180. With the current version of Capture One (which has a better LCC routine than when you were testing) it works acceptably with an IQ160 and other 6 micron backs, but only within a limited range of movements.
    In fact I considered listed it as "very limited" but decided that simplicity trumped the additional information, and to cover the nuances of how much movement I felt each lens/back combo allowed to longer/more-detailed conversations client-by-client.
    To further clarify Darr's original post the 28HR (which I believe is the 28 Darr is referring to) is a great lens whether on an Alpa, Arca, or Cambo (or any other body). The table simply specifies that one cannot purchase a 28HR in an Alpa short-barrel mount, which means it cannot be used with the Alpa tilt-swing adapter. If you want a 28HR lens and consider tilt to be an important feature for your needs then good alternatives (as neatly laid out by the chart) include going with a 32HR short barrel on an Alpa or the 28HR with a Cambo or Arca which do allow tilt with that specific lens. Other options (e.g. Technica) are out there but are not covered in the chart.
  4. #104
    23,623
    2555
    Yes I was. Thanks for updating me as I was a little baffled by Darrs post and I figured since I tested it under a older version of C1 that maybe better with newer version and It seems by your post better but not cleared up entirely. Okay that all makes sense.
    I know this is a lot of work since its about 4 sensor sizes between systems. Be nice to know the movement limits of each lens on each sensor. I know that is like 6 months worth of work to test all that out . Im not volunteering either. ROTFLMAO
  5. #105
    23,623
    2555
    Yea I think I remember when buying the 28mm for my Cambo the SK no tilt option but the Roadie 28mm did have the tilt option. I did not buy the TS in the 28mm since I felt I may not need it on such a wide angle. My DOF would probably be good enough with it. I really like the 28mm and I wish the SK worked out as I liked the look of it.
  6. #106
    NYC
    3,274
    7
    Quote Originally Posted by Dogs857 View Post
    Just a quick correction for you mate.
    The 120mm Schneider is listed on your site with a 110mm image circle. Schneider list is with a 120mm circle. Also their list for the filter thread is 46mm not 40.5mm.
    Thanks!
    There are three (modern) Schneider 120mm lenses:
    - Macro
    - N
    - ASPH
    The ASPH is the newest and is meant as a replacement for both the N and the Macro.
    I originally only had the N on the chart. It's specs were correct (110mm IC, 40.5mm thread).
    I've kept the N on the chart and added the ASPH which is starting to ship (we've received one, another poster here on the forum has received one). I've left some fields as "?" until I have a chance to look up the rest of the specs.
    The ASPH lens has a 150mm image circle and 46mm thread size (Schneider's typo on their website implied the image circle was smaller, but 150mm IC is for-sure the correct specification of this lens) though I do not know which systems will show what amount of mechanical vignetting which would lower it's effective image circle size. For sure Arca will be able to use the full image circle size without mechanical vignette.
    See also this recent thread.
  7. #107
    Santa Monica, CA
    2,272
    2
    Two points:
    The Alpa SWA is listed as having rise on the rear only. In fact, the SWA has rise on the front only.
    You seem to consider rear only movements a feature, while many might consider it important to have rise on the front. The Alpa Max has rise and fall on the front, and shift on the rear (with all movements on the rear if you choose to use their shift adapter).
  8. #108
    NYC
    3,274
    7
    Quote Originally Posted by stephengilbert View Post
    I do consider rear-only movement a feature. On the SWA you can swap the lens and back and thereby allow rear-only movement. This comes from my experience with clients who either purchased or looked at both the DS and the RS, one major difference of which is that the DS has rise on on the front (and would require an additional adapter to keep the lens stationary during a rise/fall) while the RS is natively rear-only for both rise/fall and shift. Something to think about though.
    To help clarify this I've added the word "capable" after "rear only" indicating that the specification only indicates whether it is possible to use the body with rear-only movement (whether natively, with separate adapter, or by swapping front/back panels). This (I think) also helps illuminate the spec as a feature and not a limitation. Hopefully this clarifies rather than obfuscates what I'm trying to explain.
    Perhaps I could add a column for "front only", as you're right that some users will prefer the back to stay stationary and have the lens rise/fall (as with the SWA, Max, and Cambo Wide DS). But I would say that from my experience with clients that, with the advent/main-streaming of digital stitching, front-rise is a minority use-case and doesn't fall under "overview".
    Or perhaps it should say "Rear-Only Method" and list "native", "via swap", and "adapter" to provide more detail? That seems to be getting overly complicated for the overview-level of detail. Though it seems to be a salient detail for someone who considers rear-only movement a priority for their needs.
    What do you think?
  9. #109
    Santa Monica, CA
    2,272
    2
    Maybe two columns, for front and rear movements. Yes, no, or with adapter.
  10. #110
    Jun 2008
    SoCal
    291
    15
    The filter thread indications for the Alpa Schneider lenses are also not correct, they are all 67mm except the 35XL (72mm) and 28XL (89mm). These are the current offerings of Schneider lenses from Alpa under the name Apo-Helvetar and Apo-Switar(35mm). The stock Schneider lenses are no longer available in Alpa mount, except for maybe the 90N and 100N.
    Cheers, -Peter
    Alpa TC STC | IQ140 | 24XL 35XL 120N-ASPH
    www.peterlomdahl.com
  11. #111
    NYC
    3,274
    7
    Quote Originally Posted by PeterL View Post
    Indeed I had that on my list to figure out how to address since the lens listing is for the lenses that come out of Schneider and Rodenstocks factory. For instance the weight and size are without the lens panel/mount that Cambo/Arca/Alpa put on.
    Likewise the "special editions" of the Cambo RS Anniversary Edition varied (cosmetically) from the standard issue. Though since that's not a current product I'm inclined to leave that detail out of the overview.
    Separate columns for Thread Size Native and Thread Size Alpa-Badged might be the right approach, or an asterisk on the column that clarifies that Alpa's rebadges have different thread sizes. Will look at that tomorrow.
  12. #112
    Feb 2011
    Eads, Tennessee
    1,033
    Thanks!
    - Macro
    - N
    - ASPH
    How does this lens replace the Macro version? The closest focusing distance is 1.16M. The only way that I see it could be used for Macro would be with extensions.
    Victor
  13. #113
    Mar 2010
    Southampton
    565
    I wouldn't have thought it does (but the 120 'M' is missing from the S/K website?). With genuine macro lenses image circles get bigger the closer you focus, whilst with non-macro versions they get bigger the further away you focus. e.g. 120 'M' has an IC of 80mm @ f11 @ 1:4, 90mm @ f11 @ 1:2 and 110mm @ f5.6 @ 1:1 (because of diffraction it shouldn't be used @f11 @ 1:1). The 120 'Asph' has a maximum IC of 153mm when focussed ... at infinity. One lens can't do everything, although I'm willing to bet the 120 'Asph' is ok close-up - though just how close you can get I'm not sure.
  14. #114
    Jun 2011
    Hong Kong
    122
    I can confirm this, on the Alpa Max with full frame sensor I only hit the lens limits in vertical orientation at around 22or 23 mm or rise. You could easily do a 9 stitch shot with this lens and it's sharp as sharp can be.
    Though I received this lens last year already. I double checked it's definitely the Asph. Version not N and certainly not M.
    Grischa
    Thanks!
    - Macro
    - N
    - ASPH
  15. #115
    Mar 2010
    Southampton
    565
    Quote Originally Posted by rupho View Post
    I only hit the lens limits in vertical orientation at around 22or 23 mm or rise...
    Since the IC is 153mm, with a full-frame sensor (e.g. 40mm x 54mm) in vertical orientation, it should take about 46mm of rise or fall to hit the edge of the IC ... is it mechanical vignetting from the Alpa mount that you're seeing at 23mm?
  16. #116
    Senior Member Dogs857's Avatar
    Apr 2013
    Thursday Island - Australia
    307
    Please excuse my ignorance and this is slightly OT but what is mechanical vignetting??
    Stop chasing gear, start chasing photos instead.
    Jeff, but my friends call me Dogs
  17. #117
    Santa Monica, CA
    2,272
    2
    Vignetting caused by the construction of the lens mount. A long, relatively narrow mount or barrel can cause vignetting just as a too narrow lens hood can.
  18. #118
    23,623
    2555
    The frame of the body is interfering with the lens . Basically blocking the lens angle of view.
  19. #119
    Apr 2013
    307
    This is how I understood it as well, cheers.
    Ok that makes sense. I am not used to moving backs but I can see how this could happen. Thank you.
  20. #120
    Jan 2010
    431
    I was reading this thread on my mobile phone, while traveling. I wondered what all the fuss was about, but it was quite entertaining on a long wait at the airport.
    finally I got to see the table in question, when I reached a real 'puter. I must admit a few light bulbs went on when I saw the description of these cameras capabilities reduced to a simple tabular form.
    I don't think these cameras lend themselves well to such simplistic summations. The fact that Alpa Max's left- right shift is given as +/-18mm =36mm, vs 40mm on the Cambo, is notionally correct, but of course you can reverse the camera, and you'll have 25+18 =43mm shift possible. Which is a greater range... How do you put that ability in a table?
    I have no idea if the Cambo or Arca's have this reversible front/back, up/down ability, but the table does give wrong info, when you can switch it all about (no 'accessories' involved Doug!) and have a bigger range, should you need it, in whatever direction.
    There was for example a bit of flattery for the Arca system and tilt on any lens, which is indeed praiseworthy. Cambo and Alpa are lumped together as needing special lens mounts TS mount on the Cambo lens, and a TS adapter on the Alpa SB lenses. It might be worth pointing out that owning just *one TS adapter allows you to tilt any lens (virtually) you own in SB, so you only need one of those for all your optics, an improvement on the Cambo answer.
    The description of the lenses needing special SB mounts (Alpa) or TS mounts (Cambo) also while true is a little off in tone, as anyone investing in a new system would simply order their lenses SB (no extra cost) and they have it. However with Cambo, it's at an extra cost above normal mount, (I think?).
    These are details that jumped to my attention. I like Doug And feel his contributions are good addition here. But see why someone might get a bit heated at such broad brush tabulation that flatters one brand over another, especially when the tabulator sells that one and not the other.
    I'm positive Doug means well, but it needs updating and footnoting to not be misleading. The idea after all is to allow people to make a good informed decision. Isn't it ?!
  21. #121
    NYC
    3,274
    7
    Quote Originally Posted by narikin View Post
    I agree completely with "these cameras lend themselves well to such simplistic summations" - or at least that they don't lend themselves easily to simplistic summation. This becomes apparent as you try to do so, as I have .
    Still, I do firmly believe that having some summary (prefaced as ours is with a note affirming "This page is provided to help guide our customers early in their process of selecting the body and lenses... the numbers... are only a small part of the process of selecting a tech camera.") is better than no summary at all.
    Your point about rotation/inversion is well put and provides additional value to several of the cameras on the list (of all three brands). In fact I was contacted by two Arca users to make the same point, in this case about the Arca which uses the same Arca-Swiss Rail (the standard on which RRS and a few others base their grip equipment) on the top and bottom of the unit, allowing especially natural inversion of the camera; this is especially pertinent to the RL3Di which has 40mm of rise. On the Cambo side the RC400, uses tool-free removal and reattachment of nearly any of it's accessories to top/left/right/bottom, allowing easy rotation as seen in our bumblebee video. On the other side the Cambo RS-1200 for instance is not especially easy/natural to use in a 90-degree-rotated manner.
    But I don't think such nuances belong in an overview. At least not as a full in-depth explanation (which might easily overwhelm someone who is just starting and looking for a broad overview). So in lieu of explaining how easy/hard it is to use movements in a rotated/inverted/reversed manner I've added the word "Natural" to the rise, fall, and shift listed for each body to help clue the reader in that the movements listed come with a caveat. Underneath which I've added the following note:
    Natural Movements: The rise, fall, shift listed are for the body in standard vertical orientation. Several of these bodies are (with varying degrees of ease, speed, and naturalness) able to be rotated, inverted, or reversed to allow their larger movement ranges in a direction other than it's natural direction.
    I've just reworded the note on Tilt-Swing in response to your well explained concerns. It's a subtle difference, but I think it addresses what you've brought up; your further opinion is very welcome.
    Old Wording:
    With Arca every lens can be tilted or swung. With Cambo the lens must be in a Cambo TS mount and only some lenses are available in TS mounts. With Alpa you must purchase a SB (short barrel) version of the lens and a separate TS adapter and only some lenses are available in a SB version.
    New Wording:
    TS Available: With Arca every lens can be tilted or swung. With Alpa a separate TS adapter is available which allows tilt/swing with all SB (short barrel) Alpa lenses; only some lenses are available in a SB version. With Cambo only lenses in a Cambo TS mount can tilt/swing and no adapter is required; only some lenses are available in TS mounts.
    Even here, I am excluding some detail, including detail that strongly favor Arca and Cambo. For instance the difference between the systems of where the hinge point is relative to the nodal point of the lens. Or the fact that Cambo can tilt and swing simultaneously which is unique among the three (unless you count a relatively obscure combination of two Alpa 17 TS adapters and a 34SB version of a lens). Or the throat size of the various mounts which can limit the usable image circle of some of the monster-image-circle lenses (Arca has the largest throat). Such details simply don't fit the scope of overview in my opinion.
    I only point out the above details which would benefit Arca/Cambo in response to earlier posts (not yours) which seem to imply that if I've left out any detail that might be considered a positive for Alpa that it must represent malice. In fact positive attributes of all three systems are sacrificed on this page in pursuit of taking a very complicated and seemingly-intimidating topic and reducing it to something that might be understood early in one's education on tech cameras. I am not attempting to write the Encyclopedia of Tech Cameras (i.e. cover every contingency and detail) but rather to provide an overview. Not enough detail can be misleading, but too much detail will obfuscate the overall intention.
    I really appreciate the respectful tone of your arguments and suggestions. If you have suggestions for (further) rewording I'm very open to hearing them.
  22. #122
    Vancouver, WA
    5,800
    564
    Doug, you should know by now that no good deed goes unpunished!
    Thanks, as ever, for the good work and bravery in sharing.
  23. #123
    Jan 2010
    431
    Interesting see the difference in responses from LuLa MF forum, where it was also posted, to here. Over there everyone was like "Great help, thanks!". Here it's hard core MF users, often with multiple systems, pointing out inaccuracies.
    Sadly LuLa probably has more page hits, but... that's life.
