Page 2 of 2 FirstFirst 1 2
Results 51 to 59 of 59
Thread: Distance measurement
  1. #51
    Senior Member thrice's Avatar
    Aug 2009
    1,265
    Re: Distance measurement
    Am I missing something, isn't the nodal point on any central shutter lens (all lenses on tech cameras other than the FPS) the location of the shutter/aperture?
    I simply use a ruler and line it up with the axis of rotation on my pano head.
    On topic, any laser rangefinders safe to use for close distance portraits? The disto D5 is meant to be 'eye-safe' but that strikes me as a relative term.
  2. #52
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    Quote Originally Posted by thrice View Post
    That is a very good assumption and for a symmetrical design it would be good place to bet on. For a telephoto or reverse telephoto (retro focus), not always.
  3. #53
    Mar 2012
    Sweden
    1,538
    Uh, I thought the distance on the focusing ring was from the image plane, not the lens front nodal plane?
    Ie DoF formulas are for the front nodal plane, and the Alpa HPF ring is for the image plane. So when you want to focus spot on you should align the disto with the sensor.
    Concerning the DoF calculator - for longer distances it will be no problem to ignore that the DoF formulas is for front nodal plane rather than the image plane, and for close/macro distances the typical DoF formulas has other errors too and DoF will be so extremely short so it makes not much sense to use it. The distance scale for close focusing works fine though, from the image plane.
  4. #54
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Thank you guys. That's what I needed to know.
  5. #55
    KEMPTEN / GERMANY
    1,513
    116
    Unfortunately , I could not find corresponding information for any RODENSTOCK or SCHNEIDER lens .
    On this following sheet the pupil position is measured from the film (sensor) plane .
    http://www.hasselblad.de/media/6008/cfi150.pdf
    All the HASSELBLAD V-SYSTEM lenses (except F and FE lenses) have a central shutter but the distance is always measured from the film (sensor) plane and it is not always the position of the shutter .
    Attachment 73307
    In some other CZ documentation , for other lenses , that measurment is given from the front lens.
    Regards . Jürgen .
  6. #56
    Jan 2008
    South of England
    3,295
    Thanks Jotloob - I will experiment.
    In the meantime I am taking one for the team: here is a table which took me for ever and ever to cut and paste and which gives all the Rodie/Alpa HPF distance markings down to 0.5m so other users of the system with a disto can cut out and keep! The process of getting the data out of Alpa's PDF was a nightmare due to weird formatting issues...
  7. #57
    Jan 2012
    central europe
    101
    26
    that's what i thought too
    i always measure the distance from the sensor plane. never heard about measuring from the nodal point...
    www.thomasebruster.com
    _______________________________
    Arca Rm3di|RS90|SK43|RS28|CFV-50
  8. #58
    Jan 2012
    central europe
    101
    26
    ok, just read in jae moons thread "talking technical on tech cameras" again.
    really couldn't remember most of it
    nodal point and sensor plane are mentioned, but i'm afraid i'm not really getting the point. my understanding of optics is just not good enough...
    but one sentence saved me from frustration:
    jae moon: "It is an industry convention that the object distance is between the sensor plane (not the nodal point) and the object."
    and therefore hpf rings or arca helical are made to do the right thing for you.
    just measure the distance from sensor plane - don't worry about nodal point
    am i getting it right?
  9. #59
    Jan 2008
    South of England
    3,295
    My initial tests seem to indicate that that works - which is all I need to know!
