Page 3 of 3 FirstFirst 1 2 3
Results 101 to 128 of 128
Thread: Arca Swiss Cube........ OMG!!
  1. #101
    Sep 2010
    UK
    1,387
    Re: Arca Swiss Cube........ OMG!!
    Resistance is futile and deep down everyone who contributes to this section of the forum must know, all tripod heads eventually lead to the Cube.
    Unlike many expensive and "Lustful" purchases that usually get sold again within 12 months, the Cube really is a lifer IMO.
    Have I said I'm loving mine??
  2. #102
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by Vincent Goetz View Post
    a few years back I saw Graham shoot with a Cube. I owned one a few weeks later. money well spent.
    A few months back , I saw Grahams cube attached to the tripod by a very solid RRS clamp .
    Today , I have two of these clamps . (for the clamp , see also his picture with the iPHONE above) .
    There must be some mysterious influence .
    Regards . Jürgen .
  3. #103
    Vancouver, WA
    5,803
    564
    I saw someone else's Cube and looked at it. I then had to buy one.
    Now someone else will see /try your gear and the cycle will continue. It's just the natural order of things that passes down through time and camera gear.
  4. #104
    Sep 2010
    UK
    1,387
    Ahh, yes Graham-san! (said in terrible Chineese accent)
    Its getting all Karate Kid now this discussion.
  5. #105
    Senior Member RVB's Avatar
    Jun 2012
    Amsterdam
    807
    Quote Originally Posted by gazwas View Post
    "San" is Japanese..
  6. #106
    KEMPTEN / GERMANY
    1,513
    116
    Take it easy Graham
    It's just a bit CUBE talk (small talk) . There must also be some fun here .
    BTW , if I would not have seen your RRS tripod/CUBE solution , I would not have it . And I am very happy with it . Thanks again for that good advice .
    Regards . Jürgen .
  7. #107
    Vancouver, WA
    5,803
    564
    Jurgen, it's all in good fun and it is the cycle of gear life.
  8. #108
    KEMPTEN / GERMANY
    1,513
    116
    Graham
    While you are in Australia don't only beware of dangerous spiders and snakes
    but also of kangaroos . They like to steel CUBEs and ALPAs and they like to play with them .
    Have a great time and good light for plenty of good shots .
    Regards . Jürgen .
  9. #109
    Brooklyn
    4,043
    1253
    last bit for now:
    after the above machining, i have my pan axis truly plumb when the pan platform is truly level for the full 360 degree rotation.
    the second thing that really matters is (how) to determine the mounted camera is also level when the pan platform is level. I am using the Cambo WRS, which has bubble levels for both ways mounted on the top of the body. here is what i found:
    to determine if the body itself was plumb: done by aiming a self leveling laser at the lens mounted on the Cambo: laser height set so beam hits center of lens; then a clear glass cover plate was fitted over the lens barrel, which reflected the beam back to the source; it was within 1/4" of being on the source over 14', i can live with that. (I am only setting forward/back level)
    however with the pan platform truly level, the cambo mounted using a RRS base plate, the front-to-back reading on the Cambo level was considerably out; the edge of the bubble was all the way at one of the lines. So even if you are not panning, using that to set level will be incorrect. the solution will be to re-fit the cambo level.
    the horizon and the grid function of the IQ can be used to check the left/right level.
    what I am going to achieve is to have both the cube and cambo levels consistent and accurate for level, both ways.
    all this time i have been leveling with the cambo levels and they are off. for example, if using the laser setup, I set the cambo bubble to level, the reflected dot is 2-1/2" high. (or if i set the cube bubble to level, it is 1-1/2" low.)
    over 14', 1" out is about .4 degrees, but since it is reflecting the dot it is half that angle or say 1/4 degree per inch of dot mis-alignment. the cambo level is then out by a bit more than 1/2 degree.
  10. #110
    314
    Any suggestions on what sort of clamp to mount a Cube at top of tall ladder?
  11. #111
    Aug 2008
    Carmel/Tucson
    2,355
    Super Clamp?
  12. #112
    314
  13. #113
    Brooklyn
    4,043
    1253
    weekend project coming up: the cube levels are inaccurate (badly mounted) and insensitive. as far as sensitivity, those vials are about 180 minutes (1/2 degree) for .100 bubble movement, similar to a carpenter's level.
    i just received some much more sensitive spirit vials (150 seconds for .100 bubble movement) and will be fitting them to my cube and cambo. will still have the rough circular level on my RRS clamping base
  14. #114
    Senior Member rayyen's Avatar
    May 2011
    Hong Kong
    608
    Now my Cube is happy
    Leica | Angenieux | Alpa | Hasselblad | Phase One
    www.raymondchak.com
  15. #115
    Nov 2010
    NYC
    1,575
    4
    Nice project! But over 60 times as sensitive? Isn't that going to be hard to dial in manually? I wonder if there's surveying gear that automatically levels loads as large as the cube.
    --Matt
  16. #116
    Brooklyn
    4,043
    1253
    i use a more sensitive level all the time, but you are right, if it is too touchy it won't be right. the test of the prototype will tell the story. if the sensitivity is too fine, the cube knob feel may be too crude, but at first attempt, just dropping the vial on the cube and trying it, it looks pretty promising.
    any self leveling gear i have used stays floating a bit (transit-level, laser levels, etc.) and would not be secure.
  17. #117
    Member AreBee's Avatar
    Dec 2012
    Highlands, Scotland
    171
    jlm,
    When I purchased a Cube I checked it with a precision spirit level. The result was exactly what Matt notes above: far too precise for the pitch of the head's gearing. Maybe my levels were simply too precise.
    Please let us know how you get on. I, for one, am very interested not only to read about the levelling aspect, but the modification process itself.
  18. #118
    314
    Is anyone using these screws to attach Arca-compatible plates,
    which also allows use with BlackRapid straps?
    BlackRapid FastenR Tripod (FR-T1)
  19. #119
    Jun 2012
    Amsterdam
    807
    Is this the Cube beater??
    Just grabbed this snap earlier as it was being used to make a commercial for Alfa romeo outside my home... Arri Alexa I think....
  20. #120
    Aug 2008
    Carmel/Tucson
    2,355
    Quote Originally Posted by RVB View Post
    Isn't that Graham's suv?
  21. #121
    4,333
    Can't be. It's too slow.....
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
  22. #122
    Vancouver, WA
    5,803
    564
    Exactly! Also looks like a soft-roader too so I wouldn't be caught in one of those!
  23. #123
    Senior Member Ed Hurst's Avatar
    Sep 2008
    Sydney
    1,161
    Hello fellow Cube fans! Quick question... I remember seeing someone on here (Graham, was it you?) indicate a nifty idea that involved putting some RRS parts between the Cube and a tripod, allowing you easily to remove the Cube from the pod. Great for travel when it needs to be removed readily and also great if you want to swap the Cube between different tripods. I guess it also gives more confidence that the Cube is securely attached as it doesn't depend solely on a 'tight twist'. Trouble is, I can't find the explanation of the parts involved.
    Can anyone here remind me? Thanks in advance!
    Ed
  24. #124
    KEMPTEN / GERMANY
    1,513
    116
    Ed
    The idea came from Graham . Thats correct .
    I have picked up that idea and applied the solution on two tripods and on my CUBE and also D4 .
    What you will need is : RRS TH-DVTL-55 and RRS B2 LLR II 80mm clamp .
    There is also a B2 LLR II 60mm clamp , but I prefer the 80mm one .
    The solution is perfect and I don't want to miss it . Thanks to Graham , the RRS specialist .
    Have a look to the RRS site and you will see the items and how they fit together . Good luck .
    Regards . Jürgen .
  25. #125
    Sep 2008
    Sydney
    1,161
    Ah yes! I see how that would work... Thanks Jürgen (and Graham of course!)
    What I have to decide now is whether it's a good idea for my own situation. I tend to make extensive use of a full multi-row pano rig attached to the Cube, together with a 645D and often quite heavy lenses - quite a lot of weight. I wonder if the extra elements involved in this nice solution (and the inevitable joints) would, when combined with the existing parts, contribute to a slight loss of stability... I already find with the current rig that the whole thing has enough play in it to flex fractionally (only a tiny amount, but I don't want to make it worse). No vibration I think, just very slight bending of parts of joints. Hmmm...
    Ed
  26. #126
    Aug 2012
    Shanghai / Miami
    552
    124
    Quote Originally Posted by Ed HUrst View Post
    Ed
    Hi Ed
    What you need is a plate that goes on the bottom of you cube which has an Arca type fitting.
    http://reallyrightstuff.com/ProductD...Plate-&key=ait
    Then you need to put a clamp on the base plate of your tripod to accept it
    I use this
    http://reallyrightstuff.com/ProductD...-clamp&key=ait
    Or a Pano head should work - This is the general idea
    PCL-1: Panning Clamp - PCL-1
    I do this and can swap out my cube for a panning head which I like better on the 645, and also a gimbal for the white Canons.
    I also like the idea of the leveling head because then the cube is neutral and can use it to "aim" or fine tune the camera.
    If you have a series 2 or 3 Gitzo RRS makes a leveling head that will fit after you remove the center plate on the tripod.
    http://reallyrightstuff.com/ProductD...h-Hook&key=ait
    You are right also - I always remove and carry my cube when flying
    Hope this helps
    Phil
    PS - If you decide to do this --- get the RRS TH-DVTL-40 - the RRS TH-DVTL-55 is too wide will interfere with the lever that locks the rotation of the base of the cube. I tried them both,
  27. #127
    Aug 2008
    Carmel/Tucson
    2,355
    You only need two RRS parts: the DVTL-40 attaches to the bottom of the Cube.
    Then you simply only need the RRS lever clamp (for each set of tripod legs) which attaches directly to the tripod legs.
    No more searching for bits and pieces to cobble your different heads back onto the legs. One lever switch and swap the heads. The platform remains extremely stable with no discernible loss in rigidity. If installed correctly, there are less parts for human error....
  28. #128
    4,333
    I've done the same thing thanks to Graham & Ken both of whom are always willing to help me spend money. I'll admit it has been one of the better ideas! Now I have a quick release at both ends of the Cube which makes for a very happy cube. A happy Cube is a ...
    Don Libby
    Blog
    Tucson AZ
