Results 1 to 3 of 3
Thread: IQ 160 w/ HV 500CM
    Jan 2011
    Palo Alto, CA
    621
    IQ 160 w/ HV 500CM
    Going backwards here a bit, can someone tell me if the IQ 160 (with V mount) will work with an older 500CM? Also, the IQ manual says not to mount the back with mirror lockup engaged. Does that mean you can't use MLU once the back is on?
    Thanks for your help; couldn't find a relavent thread regarding teh older Hassys and MLU.
    Best,
    Bob
    Member schuster's Avatar
    Mar 2011
    New Hampshire, US
    130
    11
    Re: IQ 160 w/ HV 500CM
    Quote Originally Posted by rga View Post
    As far as I know, the 500CM is the same as the 500CW, except for "off-the-film" metering, electric winder option and altered mirror geometry to eliminate vignetting in the viewfinder with long lenses. I use the IQ-160 on the CW with no problem. I can't speak about mounting the back with the mirror locked up, but I almost always lock the mirror up when shooting with the CW and IQ-160.
    Jan 2011
    Palo Alto, CA
    621
    Thank you!
    Quote Originally Posted by schuster View Post
