Page 548 of 555 FirstFirst ... 48 448 498 538 546 547 548 549 550 ... LastLast
Results 27,351 to 27,400 of 27725
Thread: Fun with MF images
  1. #27351
    Senior Member Ed Hurst's Avatar
    Sep 2008
    London
    1,431
    Re: Fun with MF images
    Quote Originally Posted by ejpeiker View Post
    The center is very good and there's a little falloff into the corners but it's better than I expected and better than the 12mm f/2.8 coupled with the Laowa Medium Format converter - that combo has essentially the same optical formula but by eliminating the mount between converter and lens, the corners are more consistant with each other (at least with my lenses). I have basically only used the lens on one shoot so far but I did do a quick and dirty centering test and did not find any decentering and, as I said, the corner resolution falloff was better than I expected on the ISO test chart. It is much better, for example, than the Nikon 16-35 f/4 at 16mm on a D850. Hope that helps
    Thanks for that! Are you in a position to compare its performance with the Nikon 14-24 used at 14mm on a D850? For me, that's the key comparison because not only are the focal lengths (angles of view) more similar, but its also a stronger competitor... The 14-24 is superb at 14mm (by the standards of such systems).
  2. #27352
    Senior Member ejpeiker's Avatar
    Aug 2016
    Chandler, Arizona, USA
    437
    Quote Originally Posted by Ed Hurst View Post
    I used to own that lens with a D810. The Nikon has a lot more linear distortion as that is it's weak point and the strength of pretty much all of the Laowa lenses. The 14-24 is probably a little bit sharper deep though into the corners.
    E.J. Peiker
    www.EJPhoto.com
  3. #27353
    Aug 2016
    437
    By the way Ed, one of the strengths of this lens is that it actually takes screw on filters. 86mm but I have some 95s from my Phase One days that I just step down to 86. It works well for a single filter but if I stack two it does vignette a bit.
    E.J. Peiker
    www.EJPhoto.com
  4. #27354
    Sep 2008
    London
    1,431
    Interesting! However, as a Pentax 645Z user, it's not an option for me :-(
  5. #27355
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    2,330
    36
    Quote Originally Posted by AlanS View Post
    Weardale...
    I really like this one Alan. Vertical composition, simple color palette, path leading to the tree(s) with yellow leaves remaining... Well done sir.
    Coincidentally, I just sold that lens because I couldn't get it to work with the X1D II using the Techart adapter. I'm glad it works for you using the 50S.
    Joe
    _________________________________
    Joe Colson Photography
  6. #27356
    Senior Member AlanS's Avatar
    Dec 2012
    UK
    1,724
    Thankyou for your kind words Joe, I had to shoot this as soon as I saw it!
    I am using a Viltrox adapter and it works fine (also autofocus and I.S. works fine with my 16-35 f4 canon lens!)
    Regards, Alan.
    https://www.flickr.com/photos/[email protected]/
  7. #27357
    Mar 2009
    4,031
    Yes, unfortunate for us 645D/Z users Ed. Even if there was an optical adapter that took into account flange to sensor/film plane distance differences between the Fuji GFX 50 and Pentax 645, these sorts of adapters generally cause degradation of the image beyond acceptability for most. I had tried a few of these adapters a number of years ago across 35mm systems and all were unacceptable in my opinion.
    Dave (D&A)
  8. #27358
    Senior Member etrump's Avatar
    Jan 2009
    1,383
    Finally getting some image processing wrapped up. Here’s a couple from the TX Hill Country in April. Both shot with P1 XF2/4150 & 40-80LS:
    Ed Cooley
    Visit My Website
    Likes 34 Member(s) liked this post
  9. #27359
    May 2012
    A bit north of Copenhagen
    2,115
    780
    Cold and frosty this morning, but I did manage to find some colour....
    (Weardale)
    Beautiful Alan !! and that Tamron 90 SP 90 Macro (I guess its the new version - F017N ?) is doing really fine even on MF. I found it sharper than the 100/2 Zeiss Makro, so one shall not underestimate the Tamron 90 macro.
    It's encouraging to see your super-pictures with the Canon 24TSE too...
    so if i stumble over a tiny bag of money, a GFX-R with that equipment could be reasonable...hhmmm
    Which adapters do you use?
    KR thorkil
  10. #27360
    Jan 2018
    Switzerland
    192
    Return to Lauterbrunnen Valley https://djessemay.com/new-images.html
    Leica S, Super-Elmar-S 24
    Best regards,
    Jesse
    djessemay.com
    Likes 17 Member(s) liked this post
  11. #27361
    Dec 2012
    UK
    1,724
    Beautiful Alan !!
    Thanks Thorkil, much appreciated.
    The lens is the old Adaptall 2!!!!! (I put it on the pic border). It was a pleasant surprise to find it completely covered the sensor at any distance and is also really sharp in a relaxed sort of way. I am using a Viltrox a/f adapter which seems to work fine.
  12. #27362
    May 2012
    2,115
    780
    Thanks Alan! Ok, I guess that mine new version also might do it, perhaps. And which adapter for the Canon 24 TSE ?
    The GFX-R is at campaign price, but unfortunately I have to hold my breath for still a while (or reestablish realistic common sense )
  13. #27363
    Little Rock AR
    2,427
    8
    [IMG]Clarendon Bridge final1 sunset L flat series wk 1 P0001133 Panorama by paul caldwell, on Flickr[/IMG]
    The last night of the Clarendon Bridge, Clarendon Arkansas. It was demolished the next morning. Sad to see this wonderful truss bridge destroyed for no reason other than politics.
    Taken with a IQ4 and Arca rm3di 32mm Rodie. 2 Frame averaged exposures. 2 minutes long each (15 second exposures)
    Paul C
    Paul Caldwell
    [email protected]
    www.photosofarkansas.com
    Likes 18 Member(s) liked this post
  14. #27364
    Dec 2012
    UK
    1,724
    See above.
  15. #27365
    May 2012
    2,115
    780
    For my Nikon F mount Tamron 90 and other Nikon F mount it seems like the only serious option will be Steelsring NK-F GFX auto focus adapter, almost as expensive as the Tamron 90 itself.
    And for Canon EF lenses either the Viltrox EF-GFX or the Techart EF-GFX adapter, neither of them are the offer of the day..
    Time will show if dreams come through..
  16. #27366
    Dec 2012
    UK
    1,724
    Waiting, river Wear...
    I can't believe how much river bank has been eroded the year!
    Regards, Alan.
    Likes 14 Member(s) liked this post
  17. #27367
    Senior Member vieri's Avatar
    San Ginesio, Italy
    1,338
    4 minutes of Vestrahorn Sunrise
    After almost 8 months from my last visit, I am almost ready to go back to Iceland for about two weeks of photography there! Iceland is always beautiful, but in winter is truly amazing and I am very excited to be there again. Here's a shot from my last visit, taken at the amazing Vestrahorn mountain:
    236 seconds (almost 4 minutes) of exposure with my Hasselblad X1D, Hasselblad XCD 21mm and Formatt-HItech Firecrest Ultra filters.
    Thank you for viewing, best regards
    Vieri
    Vieri Bottazzini
    Formatt-Hitech Signature Artist | ABIPP EP
    WORKSHOPS | FINE ART PRINTS | PORTFOLIO | THE BLOG
    Likes 33 Member(s) liked this post
  18. #27368
    Nov 2010
    NYC
    2,255
    4
    Some interesting flora. Not, I suspect, native to Manhattan.
    GFX100, 32-64/4
    And then there's this. ISO 102400. Yes, that is a stupid number. And yet, I like the result.
    Matt
  19. #27369
    Senior Member dave.gt's Avatar
    May 2012
    Atlanta, USA
    1,997
    77
    Skeleton Tree
    Leica S
    Vario 30-90mm:
    Dave (GT)
  20. #27370
    Sep 2008
    London
    1,431
    Château de Chambord in the Loire Valley (completed in 1547).
    Pentax 645Z with 28-45mm f4.5 lens @ 33mm.
    [IMG]StarTrailsFromFilesIMGP7352-8710_VERSION3_Step8sRGBSMALL by Ed Hurst, on Flickr[/IMG]
    Ed Hurst, www.spiffingpics.com
    Likes 23 Member(s) liked this post
  21. #27371
    Apr 2018
    France
    173
    Lines
    MMFC4390 by jean-luc cochy, sur Flickr
    MMFC4407 by jean-luc cochy, sur Flickr
    Mamiya ZD and Mamiya 105-210 mm .
    Likes 36 Member(s) liked this post
  22. #27372
    Dec 2012
    UK
    1,724
    Teesdale, 3 vertical image stitch...
    Regards, Alan.
    Likes 15 Member(s) liked this post
  23. #27373
    Jan 2009
    1,383
    Central park panoramic everyone photographs (for good reason, it’s luscious!).
    Been here three times and these lights never seem to be working.
    XF2/IQ4150/40-80LS:
    Ed Cooley
    Visit My Website
    Likes 30 Member(s) liked this post
  24. #27374
    Nov 2010
    NYC
    2,255
    4
    Quote Originally Posted by etrump View Post
    XF2/IQ4150/40-80LS:
    Lovely, Ed.
    Multi-shot to remove people? 5AM? There's NEVER no one there - except sometimes during a snowstorm. But then the photographers come out and make tracks everywhere.
    Matt
  25. #27375
    Aug 2008
    Saugeen Peninsula, Ontario
    2,808
    331
    Bottle Cove, Newfoundland, XF/150/80.
    Bill CB
    www.billcaulfeild-browne.ca
  26. #27376
    Jan 2009
    1,383
    5-5:30 and there was a ghost or two. I took a few shots and blended them.
    Quote Originally Posted by MGrayson View Post
    Lovely, Ed.
    Matt
    Ed Cooley
    Visit My Website
  27. #27377
    Oct 2016
    498
    First image from my Smoky Mountains shoot. Lots of new interesting work. Just need to find some time to look at it all. The day we arrived in the park, there was a wind storm with winds approaching hurricane force. It was kind of a blessing in disguise. It allowed me to photograph the trees with a bit more structure as compared to a wall of colour. I prefer to see the structure of the trees. I had two weeks of shooting and managed to get fortunate with some days with fog and some with snow.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    www.friedmanphoto.com
  28. #27378
    Aug 2008
    Jonesboro, Arkansas
    281
    Quote Originally Posted by stevenfr View Post
    Steven, been anxiously waiting to see your series from GSMNP!
  29. #27379
    Oct 2016
    498
    Thanks Greg. I am pretty pleased with what I got. To bad you missed out. It was a challenge with the wind storm and the sunny days. The fog and snow days made up for it.
    Quote Originally Posted by Greg Haag View Post
  30. #27380
    Senior Member ndwgolf's Avatar
    Jun 2015
    409
    A nothing picture really but it was processed in Photoshop for iPad. First of all photoshop for iPad can’t unbelievably process RAW files (this is a H6D100c Raw file) so first of all I had to open it in Lightroom and make the initial adjustments then finish it off in photoshop.
    Hopefully photoshop for iPad will add that RAW feature in the future as I enjoy the mobile iPad workflow.
    Neil
    My all NEW Website can be seen HERE
    Likes 12 Member(s) liked this post
  31. #27381
    Mar 2009
    4,031
    "Elements of Autumn" (#1). Rockbridge County, Virginia.
    Pentax 645Z: FA 200mm.
    Dave (D&A)
Name:	_IMG0804 for web.jpg
    Likes 24 Member(s) liked this post
  32. #27382
    Sep 2008
    London
    1,431
    So, following yesterday's entirely genuine post, let me follow up with something rare for me - something where I have done significant Photoshop 'playing' to produce something substantially different from what was...
    First, a little explaining. This château is lit up until 2am a variety of garish and ever-changing colours. This means that taking back-to-back shots and stacking them for star trails leads to some rather odd effects. In the sky and on the building, I was able to minimise this through a combination of colour balance, curves and the like - and, in the case of the building, overlaying a single frame with nice lighting. But, in the water area, the movement of the surface (with its consequent scattering of the light) meant that the colours and patterns were all over the place - in a way that interfered with the reflected star trails. So there was no way in which I could get rid of the messy lighting effect and still have genuine reflected trails. Well, apart from re-starting my shoot at 2am - which, on this occasion, I couldn't do.
    So, with the picture posted yesterday, I simply accepted I wasn't going to have reflected trails - and used the static shot for that area too. This absence of star reflections often happens anyway with water in motion, when the reflections aren't distinct enough to show up. So it looks convincing. But, being an obsessive, it bothered me! So, I set out to create the reflected scene as well as I could.
    And this is what you see here...
    [IMG]StarTrailsFromFilesIMGP7352-8710_VERSION2_Step12sRGBCropSMALL by Ed Hurst, on Flickr[/IMG]
    By the way, for anyone who doubts that reflected star trails really happen, take a look at these shots. There's no jiggery pokery here - it's entirely genuine:
    https://www.flickr.com/photos/160639...in/dateposted/
    https://www.flickr.com/photos/160639...7632566383126/
    Likes 16 Member(s) liked this post
  33. #27383
    Senior Subscriber Member
    Sep 2011
    Englewood, CO
    2,706
    1254
    Hi Ed,
    It's a fantastic captured. Just amazing!!!
    Your talent, passion and dedication are very inspirational.
    Congratulations!!!
    Best,
    Pramote
  34. #27384
    Oct 2010
    North Carolina, USA
    2,330
    36
    You had me at "jiggery pokery".
    Ed, you're a master at night sky photography and night photography in general. Pramote nailed it - talent, passion and dedication. Congratulations and thank you for sharing your inspirational work with the rest of us (who are still asleep).
    Joe
  35. #27385
    Jan 2010
    Southern California
    522
    Quote Originally Posted by Joe Colson View Post
    Joe
    Hi Joe,
    Always fun to read your posts and I hope the year has been good to you and your family. I do want to ask you what "jiggery pokery" means. Is that some kind of Southern jargon? Have a great Thanksgiving!
    Marty
    http://www.martinfeldmanphotography.com
  36. #27386
    Aug 2008
    Jonesboro, Arkansas
    281
    XF2/IQ4150/40-80LS:
    Beautiful image Ed!
  37. #27387
    Sep 2008
    London
    1,431
    Thanks so much, guys! All i can say is right back at you - your work inspires me!
    On the phrase "jiggery pokery", to my knowledge it's a British expression (certainly used widely there, where I grew up and currently live). It means sort of cunning or manipulative antics that might lead to misleading others, while also implying some ingenuity. The playfulness of its tone means it can refer both to serious such actions and more lighthearted occasions, of the "ooh, you are naughty, aren't you dear!" kind...
  38. #27388
    May 2018
    145
    S007 w S120
    Likes 7 Member(s) liked this post
  39. #27389
    Senior Member drunkenspyder's Avatar
    Oct 2017
    Northern California
    560
    Wow. Amazing Ed.
  40. #27390
    Oct 2017
    Northern California
    560
    Re: 4 minutes of Vestrahorn Sunrise
    Quote Originally Posted by vieri View Post
    Vieri
    Beautiful Vieri. Can't wait!
  41. #27391
    Jan 2009
    1,383
    Thank you Greg!
    Like most of my images it took 3 or 4 trips to the city to get the conditions I was looking for. Now maybe an autumn version.
    Beautiful image Ed!
    Ed Cooley
    Visit My Website
  42. #27392
    Oct 2017
    Northern California
    560
    Back to the Empire State Plaza. The Corning Erastus Tower & Egg. Three image vertical stitch, plus crop for detail [such as GetDPI shows].
    X1D v1 | Nikon 19PC | f/4 | 1/20-1.3s | ISO 100
    Likes 35 Member(s) liked this post
  43. #27393
    Oct 2017
    Northern California
    560
    Dawn is such a great time to shoot there. Love the image.
  44. #27394
    Dec 2012
    UK
    1,724
    Teesdale...
    Regards, Alan.
    Likes 22 Member(s) liked this post
  45. #27395
    Aug 2008
    Jonesboro, Arkansas
    281
    Quote Originally Posted by drunkenspyder View Post
    That is a stunning image!
  46. #27396
    Oct 2017
    Northern California
    560
    Thanks Greg!
    Greg
  47. #27397
    Sep 2008
    London
    1,431
    Teesdale...
    Tasty, Alan!
  48. #27398
    Sep 2008
    London
    1,431
    Stunning picture! I hope you don't mind the query, but is the halo around the building intentional?
  49. #27399
    Jun 2018
    91
    Helsinki - more or less a test shot for my new CFE 40mm IF. Still learning with this lens.
    Hasselblad 500CM, CFE 40mm IF, P45+, Stitch of 2 images.
  50. #27400
    San Ginesio, Italy
    1,338
    Thank you very much Greg! I got here today for a few days of personal work, and I am looking forward to meeting you & the group soon!
    Best regards,
    Vieri
    Vieri Bottazzini
