Results 1 to 6 of 6
Thread: p65+ and view camera / tech camera
    Aug 2013
    5
    Hello gentlemen,
    Last week I obtained a p65+ back.
    Already I am blown away by the results on my rz67.
    I am looking to mount it to a view camera for interiors & tabletop/ macro.
    I was recommended a Sinar X and a Cambo wrs.
    My questions are:
    1) I'm not sure of the lens mount names, can I use the same lenses on both these systems?
    2) I see my p65+ back already out-resolves the Schneider 35XL lens (max recommended sensor is 37x49mm). Is this also true of the Scheider 120 macro and other lenses. How should I select the lenses appropriate for p65+ resolution?
    many thanks for your help and many apologies for my naiveté
    all the best from nyc
    MM
    Jul 2009
    49
    Re: p65+ and view camera / tech camera
    I have used it with sinar X and P2. No experience with Cambo. As long as you can get a used X with good working condition( tight focus knob...), it should be good enough for typical still-life shooting. (But still, don't trust the on-board bubble level on the sinars. I use separate/good level to insure the parallelism of lens plane and capture plane...) You need a sliding adapter(phaseone adapter is better), and a bag bellows..
    I'm happy with 120 schneider macro(f8 or f11), 100 schneider digitar(f11 or f16) with it. I heard that the new schneider 120 ASPH is better, but no experience. I heard that Rodenstock 100 HR is better, but it has very tight image circle. So, it might be an issue in some cases. For me, I want to try the new schneider and see the difference from the usual schneider 100 digitar or 120 N digitar. I'm expecting a bit better image quality, but not sure how much... So, here again, the best & expensive and the second best & cheaper choice...
    I have a feeling that the new schneider 120 ASPH might be the best normal(a bit longer side) lens for P65+ with a tech camera in the typical still-life setting now.
    Aug 2013
    5
    i have found a local rental company to supply p2, p3 and Schneider 120mm f/5.6 Apo Digitar. i will check out the other macro lenses you suggested !
    Jul 2009
    49
    only schneider 120 macro digitar is macro lens which is good above about 1:4 magnification.
    The others are normal lenses which is good for less than about 1 : 4 magnification.
    I'm not sure about the new schneider 120 ASPH...
    Jan 2013
    1,173
    For interior/macro, you should go with a view camera rather than a pancake technical camera. You'll have more freedom which you'll need. Mounted on a tripod indoors size and weight won't be an issue. Also cheaper. A linhof 679 is pretty awesome for pretty much about anything
    Aug 2012
    Shanghai / Miami
    552
    124
    Hi
    For Table / Top - you would probably be better better off with a view camera.
    For interiors allot of people use tech camera, the Cambo RS is great - so is the Arca Swiss R line. - I think tech cameras are the sharpest.
    Keep in mind for tech cameras you have an added expense of mounting the lenses in the makers mounts to fit their cameras.
    For View cameras
    I would also look at Arca Swiss - they have 3 lines, all good, F line ( a little lighter - but very strong I put a 1.5 kg lens on mine with no slop in the mounts)
    The M line which is a bit heavier and more robust
    Then the M2 - sorta in between
    The F and M have full movements on the front and back standards and M2 is sightly limited, more like a tech camera.
    For digital - Get metric -- it is very good - I would say necessary (geared movements)
    Have fun!!
    Phil
    ps - Get a sliding back, you can check Kapture Group. If you are in the USA - Capture Integration has demos for both Arca Swiss and Cambo 23 models
