Results 1 to 13 of 13
Thread: Mamiya 645 lenses on Cambo WRS
    May 2011
    Niagara Falls, Ontario
    44
    31
    I have a Mamiya 150mm A (manual focus) that I'm rather attached to. Is there such a thing as an adapter plate to allow Mamiya/Phase 645 lenses to be used on a WRS-series technical camera? There would be obvious issues with wide-angle glass, I'm sure, but it seems a simple way to use longer lenses. It'd just need to be a dumb lens mount correctly spaced to the Cambo lens plate.
    NYC
    3,275
    7
    Re: Mamiya 645 lenses on Cambo WRS
    I'm fairly certain I saw just this item on eBay once (adapter to put Mamiya mount lenses on a Cambo Wide body). However a quick googling did not reveal anything today. Either I'm mis-remembering, the seller no longer makes them or sells them on ebay, or I'm a bad googler.
    It would only be useful for the older 645 Pro TL generation of lenses and the new 120TS which have manual aperture settings. Otherwise you'd have no control of the aperture.
    Also on an SLR mount long lenses and short lenses mount at the same spacing-to-sensor so if it works for one lens in the lineup, it will work for all lenses.
    Member Arjuna's Avatar
    Mar 2008
    Calgary, Alberta
    203
    Wouldn't you need a shutter?
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Doug,
    There used to be an ebay listing of an adapter for the Hasselbald V lenses to the Cambo Wide DS mount that someone made.
    I cannot seem to find the information anywhere.
    Lance
    LANCE SCHAD - Digital Transitions - Phase One,Mamiya | Leaf,Arca-Swiss,Cambo, Profoto
    direct/cell:610-496-5586 office:877-367-8537x224
    http://www.digitaltransitions.com email:[email protected]
    NYC
    3,275
    7
    Lance is right. I was thinking of a hassy v lens to Cambo DS mount.
    Phila./NY
    1,146
    19
    Quote Originally Posted by Arjuna View Post
    It actually had a cocking mechanism for the V-Series lenses.
    Lance
    May 2011
    44
    31
    Ah - shutter - blast! I knew it seemed too easy.
    Doug - I was thinking of vignetting issues on the wide-angle, but the dream is lost anyway.
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    That is a thing, I had thought about, too. The "shutter problem" is not really a problem. It must be possible to buy a second lens or only a copal shutter, which could release the time for the back. I think with this it must work (hope so ).
    But where to find an adaptor for leses to adapt on Cambo?
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
    Feb 2009
    518
    Quote Originally Posted by weinlamm View Post
    That's a clever idea but I'm not sure it would work...I believe the back needs a faction of a second of complete darkness within which it clears the CCD pixels in preparation for the exposure. The closed shutter in the lightpath provides that period of darkness.
    Ray
    Feb 2009
    518
    ...However, if you were doing a long exposure, you could use that external shutter/lens as a trigger, and employ the "hat trick" to control when you let the light in.
    Ray
    May 2011
    44
    31
    I think it's a question of having an M645 mount attached to a Cambo plate with a Copal-style shutter mounted in between, with no focussing helicoid - the M645 mount being calibrated to the correct distance from the sensor to mimic the M645 mirror box. I dream, I dream.
    Mar 2013
    240
    Just recieved a "like new" one
    I'm off for 10 days, so i'll make a mini report when back to my office.
    ps: for hasselblad V lens
    Aug 2008
    Carmel/Tucson
    2,355
    Y'know----we could just all hope that Cambo comes out with its own version of the FPS....
