Results 1 to 7 of 7
Thread: Mamiya 645 Pro 50mm f/4 Shift
    Member DanTidswell's Avatar
    Aug 2013
    Colchester, England
    30
    I'm certain that this is a stupid question, but can someone tell me what this rotating part of the lens does?
    I did look for a manual before asking - honest! :-)
    Vancouver, WA
    5,800
    564
    Re: Mamiya 645 Pro 50mm f/4 Shift
    It is the lens tab that connects to the exposure coupling pin on a Mamiya 645 Pro. Basically it is used on the older non-electronic coupled cameras to tell the body the f/stop selected on the lens.
    Quote Originally Posted by DanTidswell View Post
    Try page 10 here: http://www.cameramanuals.org/mamiya_...ya_645_pro.pdf
    Aug 2013
    Colchester, England
    30
    Thanks Graham, I would never have figured that out on my own, that website is a wonderful resource.
    Vancouver, WA
    5,800
    564
    It's an absolute gold mine if you have an older camera! I use it all the time.
    Feb 2009
    518
    Sort of...more precisely, it tells the metering prism the f/stop *difference* between full aperture and the stop set on the lens for shooting. It is a relative aperture indicator, not an absolute one. For example, mount an 80/1.9 lens and set it to f/5.6; note the position of that coupling lug. Then mount a 300/5.6 lens and set it to f/11; the coupling lug rotates to the same position, as in both cases there's a difference of 2 stops.
    I think the system is rather clever in its simplicity. It tells the meter what it needs to know for correct exposure; no more, no less. Feeding in an absolute aperture value would allow back-calculating of the light eV level, but would not result in a different exposure.
    Ray
    Aug 2013
    Colchester, England
    30
    That is quite elegant Ray
    Oct 2009
    128
    5
    The system was developed after the old Nikon systems of the 1960's which also sported this claw type connector on the lens.
    Rod
