Results 1 to 9 of 9
Thread: H4D-60 back on Fuji GX680
    Nov 2012
    @onelittlecamera
    16
    Gents,
    Do any of you have experience mounting a Hassy back on a Fuji GX680? I know Kapturegroup make a back adapter, but I wonder how well the lenses and tilt function operates with these optics.
    Thanks in advance!
    - N.
    NYC
    3,274
    7
    Re: H4D-60 back on Fuji GX680
    The only first hand experience I have is with Phase and Leaf backs. I don't know of any photographers using a 680 with a Hassy/Imacon back. Hopefully someone does and will get in touch with you!
    Pratamnak
    9,333
    2157
    The tilt/shift functions should not be affected by the back, since the image circle is vastly larger than the sensor. I'm not sure if that goes for the 50mm as well. That lens has some tilt/shift limitations with film. Hasselblad backs should work without the OneShot box from Kapture Group, but I know that there have been mixed experiences with some of the backs. Can't remember which ones.
    Fuji 680 digital solution
    There's also a GX680 FB page where it's possible to ask questions:
    https://www.facebook.com/groups/fujigx680/?fref=ts
    Nov 2012
    @onelittlecamera
    16
    Thanks Doug. Does the camera work with the lens open so that one can use the 'live' view functions on the backs?
    Feb 2011
    15
    First problem would be powering the back, since the H backs do not have batteries built in. On my Hasselblad H3D-39 I use an image bank, but as far as I know the H4D series does not support the image bank. There are some 3rd party solutions that just supply power but I cannot remember them off hand. Your other option is tethering. Next problem... this may be limited to the H3D series, sync issues could be a problem. When I shot with it I saw horrible purple caste to image and extreme color shifts, getting worse at the higher shutter speeds. Originally I wrote this off to the fuji gx being a quirky camera to sync to, as syncing to a leaf back does not work with hardly any combination. Ok I said, how about something like the RZ67? I had no problems syncing it to my old leaf back in the past, this should be a piece of cake. RZ67 does the same thing, so this got me to investigate a bit. Turns out the H3D backs do not like early light, it seems to take a dark frame or do some sort of calibration BEFORE the shot, and when it gets hit by light early it screws it all up. The key then is to have the back start exposing before the shutter on the camera even opens. One inconvenient way of doing this setting the back's exposure time to something like 2 seconds, and manually triggering the back with a cable release, and then firing the shutter on the Fuji GX680 inside the exposure interval. Obviously this is not an easy way to shoot, so I came up with another more convenient to do the same thing.
    I have not tried this with the fuji gx YET, but it fixed the problem completely on my rz67, and in principal should be the same. First, find a cheap electronic cable release on ebay with a 2.5mm jack you can put into the H3D, this is how you will be triggering your fuji gx now. For my rz, I spliced and soldered a cheap cable release into the electronic cable of the L-grip, so now the button on the l-grip can trigger my h3d. Ok, the h3d can be triggered now... whats next? The H3D backs have a flash OUTPUT port as well, take any generic 3.5mm male flash cable, and splice it into the electronic release for your fuji. Essentially, you are turning your H3D into a release for your Fuji. Now that is all done, simply press the button on your generic ebay cable release to trigger the h3d, the h3d will output a signal through the flash output into the fuji gx electronic cable, thus triggering the shutter. This should all happen seamlessly, and instantaneously. At least that is how it worked on my rz67, but I see no reason why the fuji would be any different. The important thing is the sensor begins exposing before the shutter on what ever system you are using opens and everything should be ok.
    Member itsskin's Avatar
    Jan 2010
    Beijing
    118
    That is awesome. Basically this opens a lot of doors for H back owners. Sorry Doug, but IQ back is not needed to solve some simple problems.
    Senior Member stngoldberg's Avatar
    Apr 2011
    newport, RI
    801
    12
    Quote Originally Posted by bpepz View Post
    H4D does work with the image bank and does sync with a computer via Phocus
    Stanley
    NYC
    3,274
    7
    Quote Originally Posted by itsskin View Post
    I did not imply it was. My post was meant as a bump to try to get more attention so someone with experience with this combo could provide guidance - and it worked.
    NYC
    3,274
    7
    Quote Originally Posted by Nick Devlin View Post
    As long as the [lens is open] and [live view is on] then live view will work. Phase backs don't care how you get there.
