Results 1 to 14 of 14
Thread: ALPA and HY6 back adapter
    Jan 2013
    1,173
    I just got an Alpa Hy6 back adapter.
    It doesn't fit perfectly on my Aptus 12 back. only three of the latches claps on securely, one doesn't.
    The back is very secure on the camera, but I am bothered by this imprecision. Does anyone else have a similar issue? Is this normal or should I return this adapter?
    Nov 2008
    Chicago
    549
    Re: ALPA and HY6 back adapter
    Fitting of AFI backs onto adapters is a bit of a … mystery? While the backs work great on the AFI, the fitting to third party adapter plates is not without some issues. While I have no mounting experience with the Alpa version - it does look very well made. Have had experience with Kapture Group's, which took a bit of fiddling, but with some adjustment he got it right.
    On a Silvestri adapter, its a real struggle, and works better in some orientations than others (believe it or not). Sometimes it takes some hard (but by hand) "pressing" to get the one errant locking tab to engage. Difficulty can vary by season - winter is different than summer (shrinking dimensions with cold).
    I'd send it back to Alpa and have it adjusted. Try rotating the back location and seeing if its the same prong or the locking mechanism.
    Senior Member PSon's Avatar
    908
    145
    I also have the same issue with the Cambo version for their cameras to fit the Leaf AFi 7 and the Sinar Hy6 digital backs.
    ALPA (MAX, STC, TC) | CAMBO (Actus DB2, WRS-AE) | CONTAX | HASSELBLAD | LEICA | DB (CFV-16, CFV-39, IQ180, IQ360, IQ3100, P45+) | Lens (Canon, Fujinon, Leica, Nikon, Pentax, Rodenstock, Schneider, Zeiss)
    Jan 2013
    1,173
    yeah, only the upper left prong doesn't fit.
    I will take it to the dealer and go from there. good that I bought retail on this one
    Senior Member EH21's Avatar
    San Francisco, CA
    394
    This is interesting to read, because Alpa normally has a very high standard.
    I'd send it back for service myself.
    Jan 2013
    1,173
    it's hard to do because i don't want to send the back along with the adapter to Switzerland. However without the back it'll be hard for them to fix it.
    Nov 2008
    Chicago
    549
    Not necessarily. Kapture Group has some sort of "working back part" to check fit of their AFI mounts - Alpa likely has something similar.
    Did you try rotating the back and seeing if its the same prong on the back that is giving the difficulty (regardless of its position), or is it the same hole on the mount that is problematic?
    If its the prong on the back, these can be replaced - and while it sounds scary, they literally screw off and replacement ones can be screwed in.
    211
    Wow! I never knew their was an Alpa adapter for my Sinar eMotion 75. This takes my fantasizing to a whole new level! But, viewing and chimping would be challenging.
    Anyone use Sinar backs with Alpa?
    Thanks,
    Mitchell
    Jan 2013
    1,173
    Quote Originally Posted by Geoff View Post
    just that one prong. so I should send the back to my dealer instead of the adapter to alpa?
    San Francisco, CA
    394
    Yes, these pins do just unscrew, but if yours looks fine and works fine on the camera, I doubt that its the issue. Maybe just for sake of thoroughness, check to see if that pin on the back is fixed tightly and not loose. Also you could try the rear cover plate for the Hy6 camera body and see if that fits into the Alpa adapter… if that is not working either then it would point more the adapter plate.
    When you look at the Alpa adapter plate can you notice anything different about the receptor that does not lock?
    Jan 2013
    1,173
    Quote Originally Posted by EH21 View Post
    Thanks Eric. I brought it back to Jeff. We couldn't figure out why and he'll get another adapter to try tomorrow.
    I have not tried to touch the screw nor did I try the cover plate. The adapter looks good too. Just one corner is off by a fraction of a millimeter and the latches does not lock in. Will report back
    Jan 2013
    1,173
    Sorted it out. Turns out the adapter was not precisely machined... this is a first from Alpa. Changed to another adapter and everything works buttery smooth
    San Francisco, CA
    394
    Quote Originally Posted by mmbma View Post
    Glad to hear you have it all worked out!
    Vancouver, WA
    5,800
    564
    you realize that somewhere in Switzerland an Alpa gnome worker is going to be hung drawn and quartered over this!
    Everything I've ever had from Alpa has always been perfect. Excessively so in fact.
