Results 1 to 8 of 8
Thread: Aptus 22
    Jan 2013
    1,173
    Aptus 22
    Looking at an attractive deal on a used Aptus 22. I like the fat pixels, and the form factor works for my alpa 24mm xl .
    Anyone has any experience with this back? I hear that it's not compatibile with Capture one? How does it compare to P25/ P25+?
    Mm
    Aug 2013
    34
    Re: Aptus 22
    I have this back. I bought it 6 months ago. I can't comment as to a direct comparison with the P25/P25+. However, on paper, the reason I went with the Aptus is because:
    1) You can zoom to 100% on the back to check your focus. This is not possible on the P25/P25+ as the screen is not adequate for this.
    2) I had heard many great reviews about the Dalsa sensor in the Leaf compared to the Kodak in the p25. However, this seems to be very personal. All in all, I am very happy with colors and results on the Aptus.
    Now, when it comes to long exposures, the P25+ beats the crap out of the Aptus. I can live without long exposures for my work. The longest the Aptus can do is 32 seconds; there is no way around it. That said, at 32 seconds noise can become noticeable.
    And you CAN use the Aptus with Capture One!! It works very well. You must buy/have the Pro version though. It will not work with the DB version.
    Moire can be an issue with all of these backs, but if you are going for fat pixels, you likely know this already.
    All in all, I am VERY happy with my Aptus.
    Foster
    Aug 2013
    34
    Re: Aptus 22
    Sorry, forgot that another difference is that the "base" ISO on the Aptus is 25. I think it is 50 or 100 on the P25, not sure. I also like the lower ISO on the Aptus.
    Foster
    Oct 2010
    48
    Re: Aptus 22
    Do you use a centre filter with your 24mm XL? I'm about to get mine back from Schneider Kruznach after having it mounted to the Alpa mount.
    I'm also wondering if the digital centre filter (by Nurizon) is any good.
    Thanks for your input.
    Jan 2013
    1,173
    Re: Aptus 22
    Quote Originally Posted by Sarnia View Post
    Yes. I do use a center filter from Schneider. I have not tried the other brands.
    I find it very useful to even out the vignette. You lose a stop but that hardly matters on a tech cam.
    The lens' image circle is too small for my Aptus 12. I think it only has a 65mm circle.
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    Re: Aptus 22
    It must be 60mm:
    Tech Camera, Image Circle, Focal Length Equivalent
    And you mean the older Aptus 22 or do you think about the newer Aptus II-5? I can't tell anything about the 22 - but I had the Aptus II-5 some time.
    I think your Combo would be fine; I had it with the same 24 Schneider. With the Aptus II-5 (+CF) I nearly needed no LCC - only sometimes or if it was needed to get perfect pictures.
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
    Jan 2013
    1,173
    Re: Aptus 22
    Anyone had experience with a P30? I know it's a smaller sensor with a 1.3 crop. So obvious not one of those lovely fat pixel backs. what do people think about this one?
    Feb 2009
    518
    Re: Aptus 22
    If your Alpa does movements, the P30 would not be a good choice - it has microlenses.
    A P25 or P45 would therefore be better suited.
    Ray
