Results 1 to 12 of 12
Thread: 4k Monitors, is it necessary?
    Jan 2013
    1,173
    Sorry I posted this here but I wanted to hear the opinions of MFDB users.
    The 4K monitors are getting cheaper (Dell, Asus, etc.) and I've been considering to upgrade. My question is: is it really necessary?
    I do photo editing 90% of the time. and 80% of the image files are taken using Aptus 12 80mp back. I have limited use for 4k Video capabilities (don't have a 4k camera yet, might get one in the future, but not a priority).
    I assume the 4K monitors will allow me to have more real estate in viewing the images. Will the software (tool bars, menus, etc.) get smaller as the pixels count increase? My fear is that I won't be able to read them clearly.
    Lastly, will I need new graphic cards to drive the 4k monitors? I currently use Dual nVidia GTX580 in SLI.
    Thank you
    MM
    Senior Member RVB's Avatar
    Jun 2012
    Amsterdam
    807
    Re: 4k Monitors, is it necessary?
    I don't think 4K is necessary but it is really nice to use,I used one briefly last week on a nMP,it was an Asus 31",it was a great viewing experience,Its amazing how much real estate you have on this monitor.
    The real problem with current 4K monitors is the lack of true colour calibration and low Adobe RGB gamut,the Asus is only 60% Adobe RGB,so If I wanted to go 4k for photography I would prefer to wait for an Eizo or NEC.
    Dec 2013
    Holland
    158
    According to the Geforce website your graphics card has a maximum resolution of 2560x1600, so no, it can't display 4k.
    I sat behind the Dell 4k offerings for a while (the UP2414Q and 3214Q?) they definetely looked impressive. My everyday screen is an EizoCG243W, but the jump in resolution is very apparent. Felt a bit like when Youtube suddenly pops into HD after a few seconds of playing a video. The gamut is really good too (I think around 100% Adobe RGB) and from what I read on the web they are quite easy to calibrate too. If I could afford it, I would definetely spring for one of those. But the smart money is probably going to wait for another 6 months to a year to get a bit more choice.
    Jun 2012
    Amsterdam
    807
    Quote Originally Posted by JeRuFo View Post
    I don't think I would rate the Dell for colour accuracy.. here is a quote from Anandtech "Changing the color gamut to AdobeRGB instead of sRGB produces similar pre-calibration results. The grayscale is pushing red and this leads to dE2000 errors that are visible. A larger issue is the color gamut, as it is over-saturated at the points below 100% and has a serious tint shift in magenta. The color errors are very visible and it happens at all saturations for almost all colors."
    Rob
    Dec 2013
    Holland
    158
    Ah, yes, I see now that I read an overly enthusiastic owners review. It seems it's not really up to the job fully yet. But I do still think they are impressively close to making a high quality monitor. I couldn't really judge color accuracy in the store. It was a controlled environment in a grey studio, but it was just a demo and I couldn't play with calibration. Colors didn't seem overly flasy like many lower end monitors and pretty realistic. But I didn't look too seriously, because I couldn't afford a new monitor anyway. We were just having a discussion about screen resolutions.
    The extra resolution is definetely nice, but accuracy is still far higher on my list, since I print on a regular basis. Still time for me to save up then.
    Jun 2012
    Amsterdam
    807
    Start saving for one of these ... Eizo Brings to Light New Small Color Edge 4K Monitors | explora
    I'm also using the Eizo CG243W at the moment and the colour is very good,I think that when you need accuracy only NEC and Eizo are up to the job,both use LUT's.. I think the 30" is minimum for this resolution ,otherwise the pixels are too small..
    Rob
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    I have a Dell 24" 4K monitor and I like seeing photos on it. It is an IPS display, unlike Dell's 28" 4K display (stay away from that one), and the colors are damn accurate. I use it next to an NEC PA271W calibrated display.
    Brad Husick
    Jan 2013
    1,173
    Quote Originally Posted by bradhusick View Post
    I read the 24'' is much better than the 28'' (and twice as expenseive) because the 28'' lacks 60hz and true color
    Jun 2009
    Vienna, Austria
    145
    Slightly tongue-in-cheek: (this is based on my experience using a Macbook Retina 15", which is pretty close to a 4K desktop monitor pixel-density-wise) you won't believe how much better/sharper the corners of once deemed so-so lenses look in 100% view compared to a regular 70 to 100 dpi monitor.
    Member Rollei6008i's Avatar
    Aug 2012
    HK
    106
    For my opinion, not only MFDB users need 4K monitor , even DSLR need them.
    My 5D2 also has more pixels than a 4K monitor , so if I can see a good 4K mon with reasonable price, I had to need it.
    Reason is simple : You need a good monitor to enjoy your masterpiece . At film age, you also want a better projector for your Kodachrome.
    Unluckily, the display seems cannot catch up the development of camera sensors.
    Most unluckily , I still using Dell U2410 due to lack of money.
    Mar 2012
    Sweden
    1,538
    High resolution is a nice to have, but as far as I can see it makes no difference whatsoever in terms of editing images for prints. You can zoom in to check detail. For pixel peeping with new "retina" screens people will zoom to 200% (otherwise pixels are too small to peep unless you have super vision), not 100% as for the old screens, so the zoomed in box will cover the same area as before.
    What's really really important is wide viewing angle (so you don't get color and contrast shifts when moving your head a little), and a sane gamma curve (contrast). A fairly low contrast screen like many IPS panels are I actually see as an advantage as it better mimics the look of a print. High contrast screens "look better" at first view, but crush blacks and whites. Calibration takes care of not only fixing colors, but also black crushing etc, but the less calibration needs to do to adjust the screen the better it is, to strong calibration need may lead to banding issues.
    At some point 4K monitors will have these properties and be affordable, but I will not buy one until then.
    I do agree though in terms of displaying work on screen instead of through a print, it's a bit painful that you can't show all the fantastic resolution. But we're getting there
    Irvine, CA
    230
    24
    Quote Originally Posted by gebseng View Post
    Hi-
    I just bought a Toshiba 15.6" 4K Laptop. The display resolution is about 282ppi. What I've noticed is that even the HR lenses like the 40mm HR and 100mm HR remain very sharp at f16 and f22 when examined at 100%. The apo-Sironar Digital lenses also showed excellent sharpness at f16 and f22. That was not the apparent case when viewed on a 24" 2K calibrated monitor. This will change my use of the smaller apertures when I use large shifts and most shots using tilts.
    jim
