Results 1 to 11 of 11
Thread: RZ67 digital backs lens crop?
    Aug 2012
    1,115
    I really have a hard time figuring this out...
    If I use my IQ160 on a RZ67 what will the lens crop be compared to using the back on the DF+ or my Cambo?
    Will a 120mm image have the same angle of view on all three systems?
    Peter
    Peter
    My website
    Mar 2010
    Lindenberg im Allgäu
    1,294
    12
    Re: RZ67 digital backs lens crop?
    "....Will a 120mm image have the same angle of view on all three systems?..."
    Yes - exactly ! Focal length is focal lenght.
    Maybe to clear this you should get an app for iPhone which explains this quite good: It´s called angle of view. Highly recommended !
    Regards
    Stefan
    Aug 2012
    1,115
    Yes focal lenght is focal lenght but the angel of view can be different, eg if you use a 44x33mm vs a 53.9 x 40.4mm back.
    I will check out the Angle of View app, thanks.
    Peter
    Quote Originally Posted by Stefan Steib View Post
    Regards
    Stefan
    Peter
    My website
    Aug 2012
    1,115
    I'll rephrase my self:
    Will an image shot with a 120mm lens on all three systems have the same angle of view or will there be a crop factor to consider?
    Peter
    My website
    NYC
    3,275
    7
    Focal length of the lens and the size of the sensor involved are the only things that matters.
    If you use the same back on multiple bodies, each time with a 120mm lens then the framing of the scene will be identical on all three.
    The light tight box in the middle does not matter.
    Aug 2012
    1,115
    Ok, got it, thanks Doug.
    Some times my brain runs in circles and today was one of those days..
    Peter
    My website
    Mar 2010
    1,294
    12
    "...Yes focal lenght is focal lenght but the angel of view can be different, eg if you use a 44x33mm vs a 53.9 x 40.4mm back...."
    That´s true but you asked what will happen when you use an IQ160 on different bodies with 3 different 120mm lenses. :-)
    One thing that is nearly sure (though it doesn´t have anything to do with Physics) is these 3 images will NOT be identical.....
    because a marked 120mm lens normally is allowed to differ +- 10% by Iso in focal length !!! Zeiss for example limits their lenses to 5 % but this means unless you got "matched" equal focal length exemplars you might even end up with different image sizes using 3 of the same lenses on the same body !!!
    ....and now you know the rest of the story.....
    Regards
    Stefan
    Oct 2012
    Nyköping Sweden
    1,194
    You are right, but I don't think there is a significant variation in focal length within a single lens line, tolerance are probably quite tight.
    It is well possible that the exact focal length is say 107.5 mm, but it may be sold as either 105 mm or 110 mm. But most samples may be within say 107.2 and 107.8 mm.
    Another factor may be the optical construction may be changed over time. Perhaps a type of glass is replaced with another type having different optical properties.
    I used to muse myself with the 90-110 zoom that actually is a prime lens :-)
    Best regards
    Erik
    "...Yes focal lenght is focal lenght but the angel is these 3 images will NOT be identical.....
    Regards
    Stefan
    Mar 2010
    1,294
    12
    Hi Erik
    Try it and measure it. You will be astonished......
    I had to learn it the hard way, as we once had a customer who bought 2 of our 40mm lenses to use them on a book reproduction system. It didn´t work, because the cameras were mounted exactly on same mirrored positions and the lenses were NOT identical and more than a little.
    The reply of Zeiss is what I told you in the last post.
    For all complex lenses which are calibrated at mounting this is the same.
    The one exception that I know of are the newer Canon lenses like the 17mm and 24mm TS-E which use pressed aspherics.
    Greetings from Germany
    Stefan
    Oct 2012
    Nyköping Sweden
    1,194
    OK, I am astonished and stand corrected!
    Best regards
    Erik
    Hi Erik
    Stefan
    420
    4
    Quote Originally Posted by ErikKaffehr View Post
    Best regards
    Erik
    We like to think how perfect these great products are, especially our favorite products. But the fact is, they are not. And that goes across the board. The differences are more in what they do, rather than how perfectly manufactured they are. Although some products are less perfect than others.
    Steve Hendrix
    Capture Integration
    Digital Cam: • Phase One | Leaf | Leica | Sinar • Authorized Reseller
    TechCam: • Alpa | Cambo | Arca Swiss | Sinar • Authorized Reseller
