Results 1 to 16 of 16
Thread: Leaf Credo leveling tool is off... anyway to fix it ?
    May 2009
    Marseille, FRANCE
    972
    i'm testing a credo 60 (second hand), but i've found out that the leveling tool is completely off by a wide margin... 99% of my images being levelled...
    is there any way to fix it ? calibration ?
    May 2009
    Marseille, FRANCE
    972
    Re: Leaf Credo leveling tool is off... anyway to fix it ?
    i've found this : but can't find the way to doing it !
    Calibration of Virtual Level
    One of the Credo’s best features is its virtual level with roll and pitch calculation. The Leaf Credo was also the first out of the current digital backs to allow for user calibration of the level: meaning if there is a specific angle which the photographer intends to take the image, the photographer can zero the level to that angle which allows for easy recognition of any deviation.
    Vancouver, WA
    5,802
    564
    If it's like the IQ back, and I believe it is, you'll need to bring up the level, go into the tools view and press and hold the level icon until it sets itself to the current values. That'll be your new zero.
    Better yet, I found this: http://www.mamiyaleaf.com/assets/fil..._V1.30_web.pdf
    Pg 69 is your friend!
    May 2009
    Marseille, FRANCE
    972
    perfect !
    many thanks !
    i should upgrade my french brain sometimes... any link for it ?
    Mar 2010
    Germany
    253
    A curious question: Is the virtual horizon on the Credo working properly if you rotate the back on your tech cam? What I mean is: The back is mounted in landscape orientation, the camera is leveled, the virtual horizon is calibrated and shows 0/0. If you detach the back and remount it in portrait orientation - does the virtual horizon still say 0/0 (as it should)?
    Chris
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by cly View Post
    Chris
    Nope !
    Keep in mind, that it's really precise, and the sensor is mounted in the back / the back is mounted on a plate / the plate is mounted on the camera !
    you can use virtual horizon... or value
    when in vertical it says 90 and 0, the in horizontal = -0.6 and 1.2
    Mar 2010
    Germany
    253
    Quote Originally Posted by archivue View Post
    Nope !
    Thanks! It was like this on a couple of IQ140 I had access to, same on one IQ260, same on one IQ250. And it's not a mounting problem of the back which one can easily show by superimposing images made in the two orientations.
    The virtual horizon is a great idea but meanwhile I'm quite sure that PhaseOne's technical implementation sucks. (I once shot myself into my foot by relying on the virtual horizon when working in near darkness. I use a small spirit level again :-)
    Chris
    Vancouver, WA
    5,802
    564
    I found that the level on my IQ260 was way, way less stable and reliable than my IQ160 was. We even swapped out my first IQ260 under warranty because it would constantly wander and jump 1-2 degrees when securely mounted. The replacement was a little better but still not great and definitely unlike the IQ160 where I could set up the level once and in use it would stay at zero or at most slowly drift maybe 0.1 degrees. The new one seems over sensitive to me.
    I fear that we hope for a bogus level of accuracy when using the fine digital display read out and it's best to be practical and use the larger graphical display.
    If you want the ultimate definition of frustration then try matching your camera body level with the back, the tripod head and tripod levels. Consistently. You might do it once but I challenge you to do it again.
    Mar 2010
    Germany
    253
    no no no, been there ...
    (One of the levels of my cube is off by a few degrees, so it's useless. One of the levels in my Max isn't terribly accurate as well. But, much to my surprise, the levels in the RRS clamps, small as they are, are pretty much in agreement with the small spirit level I regularly put on top of the Max.)
    Chris
    May 2009
    Marseille, FRANCE
    972
    Chris
    Do you think that the sensor isn't totally align with the back itself ? or the level isn't perfect ?
    Mar 2010
    Germany
    253
    To me, it's clearly a problem of the sensor(s) in the back which is/are measuring the orientation. I have no idea why they are off if you rotate the back by 90 degrees. I can't imagine that they can move inside the back :-)
    It's definitely not a problem of the back mount or the adapter, at least on my camera. If it was, this would be visible when overlaying images taken in both orientations as they would not align.
    Chris
    May 2009
    Marseille, FRANCE
    972
    Chris
    things are complicate at the top ;-)
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Chances are that when you remove and remount the back you are moving the camera a bit, which will explain small errors.
    Mar 2010
    Germany
    253
    Quote Originally Posted by yaya View Post
    Sure, but the problem is replicable and got nothing to do with a possibly moving tripod or camera. There are user errors which are quite easy to check :-)
    Chris
    May 2009
    Marseille, FRANCE
    972
    when i put it back to horizontal, is says it's levelled !
    May 2009
    Marseille, FRANCE
    972
