Results 1 to 25 of 25
Thread: Tell me about lenses.
    Jun 2010
    PHOENIX ARIZONA
    174
    I recently purchased a DF+ body with a 80mm lens. I have a IQ 160 back.
    I am looking to make it 3 OR 4 lens kit.
    The NEW 40-80 is out of my budget. Please suggest good lenses. I am told the 35mm is not up to the job.
    Thanks,
    Ro--
    Aug 2008
    Carmel/Tucson
    2,355
    Re: Tell me about lenses.
    What lenses you decide to add to your stable really is a matter of use and personal preference.
    For more recent MFDBs, I recommend more the new Phase/Mamiya D series lenses or the Phase SK leaf shutter lenses. Older generation MFDBs, especially those with crops, can much easier utilize older lenses that may not be as sharp in the corners. Again, it depends on use.
    For my uses, I like the Phase 35mm D series focal length. My copy is reasonably sharp and works well with my IQ180. No complaints at all! If you're looking at true wide angle performance, you need to go to a technical camera, not the DF or similar DSLR bodies.
    Phase 150mm LS is my most used portrait lens followed closely by the 110mm LS. 240mm LS tempts me, but probably wouldn't see much use for me----though I do like the idea of the new 40-80mm LS, but haven't seen much by the way of commentary or review here.
    I'd decide what is the focal length range that you need to cover first----then decide the lenses that fall in that range. For me I have the 35mm D (though rarely used) and in professional use the range for me is the 55mm LS to the 150mm LS. So with that in mind, my DF kit is mostly: 55mm LS, 80mm D, 110mm LS, 120mm D, and 150mm LS.
    ken
    Apr 2010
    Palm Beach Gardens, Florida, USA
    358
    If you do not need the sync speed of the LS lenses the "old" 150 f/2.8 is truly stellar and affords the advantage of a larger maximum aperture.
    4,333
    I have more of a herd than a stable of lenses for my DF which is based on usage and personal preference. You don't say what you're shooting so I'll address from my personal experience as a wildlife, nature and landscape photographer.
    The one thing I've learned is to never attempt to limit yourself to a set number of lenses.
    From long to wide, I have and have gotten excellent results using focal lengths that range from 240LS (480 with the extender) to 150 (300 with extender) to 120 macro, 80mm, 55mm LS and recently went back to a 45mm Hartblie Super-Rotator. Each lens has a purpose and each allows me to capture the file I want. At any given time/location I may use one lens over the other or not at all and shoot with my Cambo WRS.
    Good luck and welcome to the infernal.....
    don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Apr 2010
    255
    The best ratio sharpness/price:
    45mm D is plenty sharp and cheaper than 55mm LS, 55mm AF non LS is pretty good and very cheap if it is not critical for you
    80mm D non LS, as sharp as LS
    120mm AF if it is critical for you, otherwise MF is still very good
    150mm AF non D is nice and practically for free, or D or even LS if this one is especially important to you
    You can get these used for much less than list price.
    LS are more useful but much more expensive and likely to fail sooner due to the leaf shutter.
    Aug 2008
    Carmel/Tucson
    2,355
    [QUOTE=Don Libby;608584][FONT=Tahoma]....
    [FONT=Tahoma]....
    ...especially here in Dante's Forum. Everyone can always use another good lens. Everyone.
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    You know this... ?
    I love the 35mm + 45mm, too.
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    I have the 28mm, 45mm, 55mm, 80mm, 150mm and 240mm.
    I use the 55 most, the 45 least. But I find I need them all!
    Not much help am I? Dante has me firmly in his grip.....
    Bill
    Bill CB
    www.billcaulfeild-browne.ca
    Jun 2010
    PHOENIX ARIZONA
    174
    I read all your comments. Thanks.
    I am thinking of 28,55,110 and 240
    OR
    45,80,150 and 240.
    I am not sure about the 28 as normally I don't shoot that wide.
    Any issues with corner sharpness on the 28mm?
    Thanks again.
    R---
    Dec 2013
    168
    Who told you the 35 is not good enough?
    http://flic.kr/p/oTkAsk
    Works great for me. As does the old 210mm.
    Feb 2009
    518
    Quote Originally Posted by synn View Post
    Lovely shot! But it's stopped down so much (f/16), and cropped so much (44x33 mm back), that it doesn't prove much about the 35mm lens. Those parameters hide its inherent strong field curvature.
    Ray
    Jun 2010
    PHOENIX ARIZONA
    174
    A major dealer told me to stay away from the 35mm and suggested the 45mm
    as an alternative. (no names).
    Unfortunately, I don't have the time OR money to experiment.
    Thanks,
    R
    Apr 2010
    255
    A Phase One branded 35mm would be acceptable, but still not as good as any 45mm D.
    Older copies of 35mm can be iffy, I've had a couple and wasn't excited about them.
    I'm not willing to pay $3000 for the best version of 35mm, when I have a great 45mm D which cost me $1000...
    You have a very big sensor like me, so 45mm is pretty wide IMO.
    You have here a used copy for $1600: Mamiya Sekor AF 45mm F2 8 D | eBay
    Apr 2013
    398
    Depends on which back one uses it on.
    The IQ160 is the Largest sensor currently made so not all lenses are up to snuff in the edges and corners. With smaller sensors one is using the central part of the image circle of the lens which is generally very good on all lenses.
    Feb 2009
    518
    I love this sort of thread - it gives us an excuse to go on about the lenses we like, whether or not they suit the OP's purpose!
    How important is AF to you? If the answer is "not very", then all sorts of lens goodies await.
    I have just the one Mamiya AF lens - and it's a zoom: the 55-110/5.5 AF. You could say it's my walkabout/convenient/everyday snapshot kind of lens. But it's a great performer too.
    Everything else I currently have is manual focus. There are several reasons for this: (1) I had M645 cameras before my 645AFD & DB; (2) the fastest and most unique lenses are only manual focus; (3) they're cheaper; (4) I also use them on my Canon and Fuji/Nikon DSLRs, and thus avoid duplicating focal lengths with additional 35mm primes. So far, no-one has come up with a cross-platform adapter which can operate the electronic aperture of the Mamiya AF lenses, so it has to be the manual focus lenses for use on other systems.
    The other AF lenses generally don't entice me.
    The 1st-gen AF lineup are now quite affordable, but were by and large optically identical to some of the manual focus ones, and not exciting in terms of aperture speed. I have the manual focus 105-210/4.5 ULD zoom, and might upgrade to the identically specced AF version, to complement my shorter AF zoom...that's about it.
    There are a couple of 2nd-gen D lenses that might figure in my future - if they really are that much sharper wide open. But right now they're well down my shopping list.
    My camera cannot operate the 3rd-gen LS lenses, and in any case they're too expensive for me and I don't care about flash speeds.
    So, back to the manual focus lenses!
    I have: 24/4 ULD Fisheye, 35/3.5 N, 45/2.8 S, 55/2.8 N, 80/1.9 C, 110/2.8 N, 120/4 A Macro, 150/2.8 A, 200/2.8 APO, 210/4 N, 105-210/4.5 ULD zoom, 2x N TC.
    I had: 45/2.8 C, 70/2.8 LS, 150/3.5 C
    I want: 300/2.8 APO
    Also, in terms of adapted 6x6 lenses -
    I have: 300/4 CZJ MC Sonnar
    I had: too many CZJ/Exakta-Schneider/Pentacon/Kiev lenses to list, from 30mm to 500mm...the better ones being the 30/3.5 MC Arsat Fisheye, 55/4.5 MC Arsat Shift, 60/3.5 Scheider Curtagon, 120/2.8 CZJ MC Biometar, 180/2.8 CZJ MC Sonnar. [Actually I still have all of these bar the Curtagon - I just haven't got round to selling them yet - PM me if interested]
    I want/am curious about: Pentax 67 105/2.4 and 400/4, Hasselblad 110/2, RB67/RZ67 500/6 APO
    And to round it all off, what lenses could I not live without? What keeps me in the Mamiya ecosystem, when from a camera point of view Pentax 645D/Z is the better option? Well that would be: 24/4 ULD Fisheye, 80/1.9, 120/4 A Macro, and the f2.8 APO telephotos. Of these, only the Macro has a Pentax equivalent - or an autofocus Mamiya/PhaseOne equivalent, for that matter!
    Ray
    Dec 2013
    168
    Fair enough, the 35 sits on a cropped sensor for my application. Can't comment too much about full sized sensor use except that c1p can help add a bit of edge sharpness. But yeah, the 45 sounds like a better option on that sensor.
    I am also thinking about the 50mm shift at the moment. Unfortunately, there's not much on the Internet about this lens.
    Aug 2012
    1,115
    I'm pretty sure somewhere here on GetDPI there is a test made by Jack or Guy..
    Found it: http://www.getdpi.com/forum/lens-acc...hift-lens.html
    Peter
    My website
    Apr 2013
    398
  19. #19
    Dec 2013
    168
    Thanks for the links, guys!
  20. #20
    Sep 2013
    Miami FL USA
    53
    I mainly do environmental portraiture and my work horse lens is a 55 LS with an IQ260. Its very sharp at all apertures and has a very pleasing rendering. I prefer leaf shutter glass, it gives me added flexibility when shooting outdoors with strobe.
    That being said, recently I received a commission to shoot an architectural project and I rented a 45mm which was absolutely perfect. Still editing the files but I may just buy one.
    The 40-80mm LS f/4.0-5.6 is a sweet piece of glass. I was able to use one for a few days on an IQ250 and found that its crisp even wide open on the corners. Its a handful, but I didn't have any issues using the lens for a full day shoot. (The lens was literally right off the workbench, the lens barrel was stamped sample #11. That made me chuckle.) I usually prefer prime glass over zooms, but on my shoot I didn't even think about using one.....
  21. #21
    Aug 2008
    Carmel/Tucson
    2,355
    Quote Originally Posted by Jeffery Salter View Post
    Oooh. I don't think I've seen much on this lens since its announcement. I'd like to know how the new 40-80mm LS handles a full frame MFDB sensor. Worthy of your review Jeffrey... Definitely one of those Dante purchases.
    Ken
  22. #22
    4,333
    And a huge welcome to a great photographer Jeffery Salter, great seeing you here.
    Don
    Don Libby
    Blog
    Tucson AZ
  23. #23
    Sep 2013
    Miami FL USA
    53
    Hi Don
    Thank you so much for your most gracious comments on my work. I appreciate feedback on my images and it definitely bouys my spirit to hear from an established artist and photographer such as you.
    Hey Ken. I agree it would be nice to compare the IQ250 vs IQ260 with the new 40 - 80mm LS zoom. Some would probably say, hey I can zoom with my feet or do a lens change, but for a fashion or catalogue photographer who is locked down and with lighting set it maybe more fluid and definitely less taxing to simply zoom in or out after doing 20 to 30 outfits.
    If can wrangle up the zoom again I will be glad to share my thoughts in a review this winter. Dante can be a toasty place to be in the winter.
    Thank you
    Jeffery
  24. #24
    Apr 2012
    Santa Barbara
    302
    I am getting a new CMOS back either the IQ or Credo (haven't decided yet) but the smaller sensor and the nature of repetitious product shooting demands a zoom range of 55-110.
    Voila, there is a Mamiya 55-110af, but not available new or late model gen, is that correct? I bought a used one cheap but don't know if the AF will work with my DF+ (Ray, any thoughts on this lens?)
    The 40-80 would work fine but is too expensive and the 75-150 is going to be substituted in place of the 80 in the new kit.
    More info on these older 55-110's please and should I bite the bullet and sub the 40-80 instead of the 75-150? Keep in mind the crop sensor of the IQ250 or Credo 50
  25. #25
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Quote Originally Posted by Egor View Post
    Eric I know that there is definitely a fw upgrade for the Mamiya 105-210 lenses where it needs to go back to Mamiya for it to work with the DF/+. Not sure about the 55-110.
    L
    LANCE SCHAD - Digital Transitions - Phase One,Mamiya | Leaf,Arca-Swiss,Cambo, Profoto
    direct/cell:610-496-5586 office:877-367-8537x224
    http://www.digitaltransitions.com email:[email protected]
