Results 1 to 8 of 8
Thread: Rodenstock 35mm HR
    Jan 2015
    11
    Rodenstock 35mm HR
    just purchased a alpa tc kit that came with a rodenstock 35 hr. curious if someone could tell me if this color shift seems normal for this lens. the lcc was taken at f/11 in clean flat daylight using a phase one lcc plate.
    thanks!
    grant
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    971
    Re: Rodenstock 35mm HR
    Looks like a pretty normal lcc to me, but I don't own that lens. What back do you use?
    Dave
    davechewphotography.com
    Jan 2015
    11
    an iq160
    Little Rock AR
    1,927
    4
    Thats normal. The 35mm has a 70mm IC. Non shifted it should correct fine.
    Paul
    Jan 2015
    11
    its corrects okay but has a funny feeling to it. nothing i can show an example of for just now though. i work a little loose and havent always been as .. efficient as a i could be with the lcc at the time the image was shot. maybe its just the heavy amount magenta the lens throws.
    that said i use an arca swiss m2 for work along with the schneider 43 xl and a heavy amount of movements. that lens as you know tends to get pretty colorful quickly and my lcc corrections with it are always perfectly clean.
    Nov 2013
    95
    I agree with paul, your 35 HR perform as it should. It is still a very usable lens, unfortunately the image circle allows only slightly movements on big chips.
    Sep 2011
    1,069
    83
    Looks pretty good. A lot better than what my old 35XL used to look like on the IQ180.
    Jan 2015
    11
    thanks y'all
