Results 1 to 4 of 4
Thread: Phase One P20 on Tech Cam?
    Aug 2012
    1,114
    I may have the opportunity to acquire a P20 for a very reasonable price and maybe play around with it for projects where I don't need the resolution of my IQ160.
    But! Does it play well with tech cam lenses? Or is it similar to the P30 which doesn't?
    Peter
    Peter
    My website
    Mar 2012
    Sweden
    1,538
    Re: Phase One P20 on Tech Cam?
    As far as I know the P20 is the 16MP square version of the 22MP P25, 9um pixels without microlenses so it should work very well. The P21 on the other hand will not, it's that one that's similar to P30.
    Aug 2012
    1,114
    Thanks Anders, yes you're right, it is just a smaller version of the P25 sensor so should work very well.
    Peter
    My website
    Member weinlamm's Avatar
    Sep 2012
    Germany
    229
    3
    It's great on Tech Cam.
    I use it very often for stiching with 55mm. Somewhere in the direction of 8.000x4.000 pixel is enough.
    20mm left, center, 20mm right.
    In this case you have to have a look for the different in white balance. - But it works nearly the same as LCC.
    To get the same white balance I did some time ago a white balance shoot with plexi in front of (same plexi I use for LCC). Adjusted + saved. And now I'm using this for set the white balance (but I allways use my back in "daylight"-mode).
    __________________
    Christian
    P.S.: If your wife knows everything... it's mostly not good for your gear.
