Results 1 to 20 of 20
Thread: Shooting out of a helicopter
    Sep 2011
    1,069
    83
    Need some advise on shooting an 80MP back out of a helicopter.
    What kind of shutter speeds would I need to counter the speed of the chopper? not sure how fast they fly on tours.
    Any thoughts of a tech cam (not expecting movements) vs. a DF?
    Cheers...
    Senior Member Jamgolf's Avatar
    Sep 2013
    North Texas
    516
    Re: Shooting out of a helicopter
    Sounds like fun Jag. Whats would be the max altitude?
    Here are some thoughts that are coming to my mind:
    - pick a focal length that's not too wide to avoid including parts/interior of the helicopter
    - pick a focal length that would hi-lite some features on the ground instead of just a 20000 ft view
    - having image-stabilization/vibration-reduction would be helpful
    - composing might be quite challenging
    - be safe
    IQ3 100 Cambo 1600 Rodenstock 23,32,50,90 Zeiss 350SA
    UnTroubled Land
    Sep 2011
    1,069
    83
    It's nothing too crazy. Just a tour of the Grand Canyon with a landing. I'm thinking 32HR or 40HR with a tech cam, but not sure if I will get the shutter speeds to get sharp images. I would guess altitude at 1000-6000 ft.
    Other options would be P1 DF or Nikon D800E with 14-24 & D800 IR with Coastal Optics 60mm.
    Any form of image stabilization is likely not possible if I go with MF.
    May 2014
    Oxford
    759
    According to Antony Spencer's experience with the IQ280 and the IQ180, he usually use 1/(2*focal length) as the shutter speed at f/4.0 - f/5.6 and then adjust the ISO to the appropriate histogram.
    I would have to annoy you again with a repeated fact that he actually switched to a D800... A Credo 50 or an IQ250 could do better than an IQ280 in this use case. The best solution would be the Pentax 645Z with image stabilization.
    Cold hard but true fact. Lovely and stubborn CCD users
    Sep 2011
    1,069
    83
    Thanks Voidshatter.
    That is good to know. at 1/2x, I can be in the 1/100 to 1/200 range which will work just fine. I did not know I could go that low. I am going to research the typical speed of these things and get my wife to drive around at that speed while I take some shots, I'm sure she'll love that.
    BTW, not annoyed at all, it is always great to hear other opinions. An IQ250 may be better, but then I could not use my 32HR
    The Pentax would also be viable, but not sure a Nikon solution couldn't get close enough with more flexibility and arguably better glass.
    Jan 2012
    1,198
    Whatever you do, don't stick the camera out of the open door as the downdraft from the rotors will create all sorts of problems.
    The biggest challenge I had was shooting without the rotor blades ruining the shot, but I was shooting pretty much straight out - if you're angling down, this of course won't be a challenge.
    Can't remember the exact settings for this. It's in the tech cam photo thread somewhere!
    IQ180, Rodie 32HR, FPS. I think!
    Kind regards,
    Gerald.
    Sep 2011
    1,069
    83
    Thanks Gerald. I was hoping you'd jump in here
    As long as I don't need anything faster than 1/500 I think I should be fine. I will just have to work with whatever lighting prevails.
    You said you were shooting straight out. Any thoughts on having the lens dropped 10mm and still shoot straight out? It is not ideal, but I am hoping this might give a slightly different perspective than the usual "pointed down" look.
    Jan 2010
    523
    You won't need faster than 1/500th but my strong advice is to keep it well north of 1/250th if you can. You have both movement and vibration to contend with and vibration can be harder to gauge. It will vary from aircraft to aircraft.
    Jan 2012
    1,198
    Quote Originally Posted by jagsiva View Post
    Well on that one the horizon is a bit of a giveaway - I was pointing down a bit, and then straightened everything up in post. But the key thing here is that if you're trying to shoot something that is significantly above your horizon, the rotors can ruin the shot. For that frame, the idea was to fly at 300m so that all the other tall buildings in view didn't break the horizon line.
    It's just luck as to whether the rotors are there when you snap or not.
    It's been a long time since I've looked at shots from that flight, I should probably revisit them to jog my (very poor) memory about how things went.
    Sounds like a good plan to me to dial in a 10mm or so fall if you're looking to get the straight verticals.
    Kind regards
    Gerald.
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    My very limited experience with a Phase DF/IQ180 showed me that shutter speeds of 1/1000 or faster were needed. I shot at ISO 200 with a 150/2.8 mm lens at f4.
    Bill CB
    www.billcaulfeild-browne.ca
    23,623
    2555
    Man this was my life years ago when I was Chief Photographer at Honeywell Avionics. I shot tons of this stuff even with speed graphics cams but mostly with Hassy V. He'll there is a A12 film holder with my name in it at Lake Louise in Calgary. Lol
    Freaking cold as heck shooting in winter. Seriously it's not speed so much but vibration in helicopters so about 1/250 is your best bet. Now I use to hang out of these things door wide open all the time. Little tip duct tape your seatbelt latch down so you don't hit it open. Sit in back and feet under front seat for gripping power . That's just for normal sitting. I use to stand in the rail tethered to the bird. Now that is fun and crazy. Also lenses try normal or slightly wide of normal. But many shots I used the Hassy 50, 80 and 120. Anything longer and you just don't have the speed. Wider you run the risk of the blades or rail in shots.
    www.guymancusophotography.com
    Nov 2012
    UK
    128
    24
    Looking back at images shot from helicopters in Australia in 2012 when I took a Phase DF and IQ180, I generally used ISO200 and shot around 1/500 at f8. 1/1000 if possible at f5.6. Lens was mainly 80mm.
    I think I would have struggled using the ARCA in a confined space when the ability to see through a viewfinder and shoot fast was important.
    Nov 2013
    26
    Cameron Davidson shoots with an Arca TC and Leaf Credo 60.
    He is a member here so he might see this thread and share his experience.
    http://instagram.com/camdavidsonphoto
    Feb 2011
    20
    Quote Originally Posted by .:Aleph:. View Post
    Instagram
    Written 11 years ago for Sportsshooter.com - but still solid information about first time aerials.
    First Time Aerials
    I shoot with Nikons and my Alpa TC/Leaf Credo 60in the air. I always use a gyroscope. You can rent them from Kenyon Labs or many rental houses. I use a Kenyon 4x4 and/or a KS-8. (I own both) I occasionally shoot Hasselblad for aerials.
    The article should answer most of your questions about aerials. The biggest key is working with your pilot. Choose someone who understands photography and has flown many photo missions - it is a partnership while you are in the air.
    Also - stay out of the Robbie R-22 helicopter - it is a trainer and is not suitable for aerial photography - I don't care what anyone else tells you or what they claim as experience. I've been shooting aerials for thirty-five years and I will not fly in an R-22. My choice is a turbine machine such as an AStar, Jet Ranger or MD 500. An R44 is a fine machine with the right pilot. The Schweitzer 300 is also good with the right pilot.
    Hope this helps.
    Nov 2013
    26
    That is a great article, Cameron! Thank you for letting us know about it. I presume some things have change now: for example, I don't think you use Delorme Software and SunPath? There is the Photographer's Ephemeric website and Google, am I right?
    I think the thing missing from the article is the discussion about equipment and exposure settings as well as framing.
    Like this?
    http://marcstpierre.zenfolio.com/img...62117079-5.jpg
    How does that work?
    Feb 2011
    20
    Like this?
    How does that work?
    The article was written 11 years ago and while gear and software will change, the realities of aerial photography have stayed the same: safety first.
    Sep 2011
    1,069
    83
    Thanks for all the advise guys. Shot the IQ180/[email protected] 1/500 and worked quite well. Motion blur from speed was not really an issue, but vibration when I got too close to the plexi or other parts of the body with my arms or camera were.
    Will post some shots shortly. Thanks again.
    Sep 2011
    1,069
    83
    Now the pics. 40HR, 10mm down....
    Not sure why, but I appear to have detail in these images after I posted here. Any thoughts?
  19. #19
    Member Richard Osbourne's Avatar
    Jul 2012
    Norfolk
    74
    Cameron
    I just want to say a big thank you for that article - it's really great information. I've been considering doing aerial shooting for a while but have felt instinctively very cautious about it. Your article confirms why!
    Quote Originally Posted by Camdavidson View Post
    First Time Aerials
    Hope this helps.
  20. #20
    Feb 2011
    20
    Quote Originally Posted by Richard Osbourne View Post
    Cameron
    Most welcome.
