Results 1 to 9 of 9
Thread: leica s lenses firmware, can't find it
    Member msadat's Avatar
    Dec 2010
    Hermosa Beach, CA
    195
    does anybody know or has the latest lens firmware for leica s lenses. i can not find it on their site. thx
    Senior Member thrice's Avatar
    Aug 2009
    1,265
    Re: leica s lenses firmware, can't find it
    It's built into the body firmware. The reason for the warnings on some of the rear lens caps is to ensure you update the body firmware prior to mounting the lens to ensure it is also updated and everything behaves as it should.
    If the lens needs a new firmware you will get a message when mounting it onto a body with up-to-date firmware and it will do the update.
    Workshop Member glenerrolrd's Avatar
    Jupiter FL/Atlanta GA
    2,279
    Take a look at the camera firmware ...pretty sure the lens firmware is included in the camera firmware download .
    Dec 2010
    Hermosa Beach, CA
    195
    so my s2 is @ 1.4 and when i try to load the 1.4 to update the lenses, it goes through the process of loading the firmware, it shows loading file and it quickly goes back to regular camera mode
    Aug 2009
    1,265
    I would say that indicates your lens firmware is up to date no?
    Dec 2010
    Hermosa Beach, CA
    195
    you might be right, i am going to chk the firmware against another lens of the same focal length to be sure.
    Jun 2013
    Oslo, Norway
    76
    Do you have an S2 or an S006? I think there is a slight difference, the S006 will automatically update lens FW.
    When I had the S2 there was a separate lens FW, and update had to be done manually for each lens.
    It is all on Leica Owners area, if you register your camera there.
    - ErlingMM
    Dec 2010
    Hermosa Beach, CA
    195
    i have an s2 and yes i remember it was a separate upgrade, i can not find it on the site any more
    Quote Originally Posted by erlingmm View Post
    Dec 2010
    Hermosa Beach, CA
    195
    ok the leica s2 combined firmware does not update lenses, just checked two 120mm lenses
