Page 3 of 3 FirstFirst 1 2 3
Results 101 to 147 of 147
Thread: Medium Format Pano's
  1. #101
    California/Thailand
    1,206
    Re: Medium Format Pano's
    Quote Originally Posted by Bob View Post
    Even though I prefer the screw clamps, this is one instance where the levers have a slight edge.
    The Arca lever, if properly adjusted, just won't easily close if the base is skewed a bit.
    -bob
    The only close-calls I've had with RRS clamps have been with the screw-type, and always because I thought I had it seated correctly, but did not. Working in the field in awkward positions, with cold hands, etc., I have "skewed" the placement and the clamp pinched just the "rim" of the seat.
    With the lever I have better feedback as to whether it is seated correctly. IMO both are good, and both require that I pay attention (easily said, but not always practiced by me).
    I tend to shoot a fair number of vertical comps, and often shoot a scene horizontally then look for something vertical I can use from the scene (or visa-versa), for which the lever style clamp is a life saver. And further, I prefer the way the RRS lever tucks under the Mamiya body. Really I like both, but I do find advantages to the lever-type at times as well. I just have to be careful with either.
  2. #102
    Member Clawery's Avatar
    Apr 2008
    Atlanta
    125
    I just picked up the RRS BH-55 LR. When I called them and told them what I was looking to do, the suggested that the lever was the best bet. The said that sometimes the twist lock can not be fully tightened and the plate/ camera could slip. From the other posts that I've read... they might be correct. I have to say the build quality of this head is top notch!
    I'll have a better idea how it truly works in Carmel / San Francisco this week.
    Chris Lawery
    Sales Manager
    [email protected]
    Capture Integration, Phase One Dealer of the Year
    877-217-9870 | National
    404-234-5195 | Cell
    Sign up for our Newsletter | Read Our Latest Newsletter
  3. #103
    Melbourne, Australia
    2,338
    52
    Thanks Jack!
  4. #104
    Brooklyn
    4,043
    1253
    the only problem I encountered using the RRS slider is that the slider clamp to the camera is meant for a left-right oriented camera plate, which is what RRS provides for the mamiya, M2 and dslrs. for the Blad and Rollei, though, the camera plate is front to rear. the plates are not made to be rotated 90 degrees, as they rely on the camera edge as an anti-rotation method. I had to stack another camera plate at right angles to the F-R plate! but it is tidy and works
  5. #105
    Los Altos, CA
    10,486
    1031
    John:
    If you buy the basic plate -- MLP 1 I think -- then the little $5 stop, then the clamp of your choice, you can mount the clamp on the rail in either direction for fore/aft or side/side attachment of the camera.
    home: www.getdpi.com
  6. #106
    Senior Member etrump's Avatar
    Jan 2009
    1,206
    First real work with my Cambo RS/P45/35xl. Feeling real good about the kit but have a lot of learning to do.
    Anyone care to share their focusing routine? The calculated hyperfocal distance doesn't seem to give sharpness to infinity.
  7. #107
    Los Altos, CA
    10,486
    1031
    Hi Ed:
    Nice pano! You might want to use the LCC tool to prevent the magenta-green color casts that get imparted with the lens shifts, though they look kind of cool in this shot
    As for DoF with medium format -- I say use a two stop lower hyperfocal for the actual aperture. IOW use the f11 hyperfocal for an f22 actual lens setting... Or consider focus stacking.
  8. #108
    Brooklyn
    4,043
    1253
    an issue with the lever clamp on the cube is that it has a minimal range of travel, so if you set it to grip well, it doesn't open very far and as you have so slip the camera base plate in from the end it is fussy.
    the screw clamp from RRS will open far enough so you can drop the camera plate straight down into the dovetails. much nicer
  9. #109
    carstenw's Avatar
    Berlin, Germany
    2,530
    This is not the case with my RRS quick-release clamp. If I open it to 90 degrees, yes, I have to slip it in, but if I open to 180 degrees, it drops in vertically. Is yours different, or is it somehow Cube-related??
    Carsten - Website
  10. #110
    Brooklyn
    4,043
    1253
    i was speaking about the standard Arca lever clamp on the Cube
  11. #111
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    The Arca clamp that came on my cube opens all the way if the ribbed metal latch is pulled back with the thumb.
    Plates then are easy to get in or out even sideways.
    -bob
  12. #112
    Brooklyn
    4,043
    1253
    ??? my arca cube clamp lever will only move 90 degrees when releaeing the latch button providing about .020" range of travel
  13. #113
    Prescott, Arizona
    4,492
    367
    Mine will move about 180.
    First stage lock:
    Round sliding button on side of lever unlocks for the first 90 degrees.
    Second stage lock:
    look at the lever surface that is now newly exposed. There you will see a serrated pin that connects the sliding button to the lock. pull that pin out just a bit with your fingernail, and the lever will open the remaining 90 degrees.
    -bob
  14. #114
    Los Altos, CA
    10,486
    1031
    John:
    The other option if you want to stick with the Cube clamp --- that lever is Delrin and easily machined. (To remove it, simply loosen the jaw adjustment wheel all the way until it slides out.) I re-contoured the cam surface to a larger flat at the 90 degree stage. This allowed for an easier in and out of standard plates.
    IMO the gold fix would be a longer shaft and adding a washer and small o-ring a-la the RRS clamp
  15. #115
    Prescott, Arizona
    4,492
    367
    Jack,
    With the current lever design, that is not necessary.
    The double catch allows a bit of safety as well as the convenience of complete opening.
    -bob
  16. #116
    Brooklyn
    4,043
    1253
    a-ha!
  17. #117
    Los Altos, CA
    10,486
    1031
    Jack,
    -bob
    Understood, but I think it can be improved upon and who better than John to do that?
  18. #118
    Prescott, Arizona
    4,492
    367
    John,
    I am willing to field-test anything you come up with in this area :-)
    -bob
  19. #119
    2,338
    52
    Sheeesh - thanks for teh tip Bob. Someone shoudl volunteer some help to Arca re writing a user leaflet in English that works! LOL
  20. #120
    Los Altos, CA
    10,486
    1031
    Someone should volunteer to build Arca a website!
  21. #121
    2,338
    52
    True - so very true!
  22. #122
    Prescott, Arizona
    4,492
    367
    Quote Originally Posted by PeterA View Post
    I just read the German one.
    -bob
  23. #123
    Subscriber Member mwalker's Avatar
    Kentucky
    924
    74
    Guys you have inspired me to try this.. I have a heavy duty CF Gitzo tripod, I can't afford a cube now what would you recommend as a kit? I have a Sony a900 with a CZ 24 -70 or G 70-300. I will purchase APP.
    Mike
    website under construction
  24. #124
    Brooklyn
    4,043
    1253
    mike I have nice acratech ball head i could sell you for $200
    http://acratech.net/product.php?prod...7&cat=1&page=1
  25. #125
    California/Thailand
    1,206
    Quote Originally Posted by mwalker View Post
    I like the RRS BH-55. The pan base locks very solidly (good for using off-axis or horizontally) because they employ a tension strap design, instead of the common set-screw type of design.
    You could get by with a lighter head than the BH-55 also, such as the BH-40 or Arca-Swiss ball head, or Acratech as offered above. I prefer the pan base on the RRS (BH-55 head, but these others are strong enough for you kit in terms of weight.
  26. #126
    Prescott, Arizona
    4,492
    367
    Mike,
    If you want to do panos with a BH-55, I would recommend topping it with an RRS PCL-1 pano clamp. I use it on top of my gitzo head in my light-weight setup. If course, it is not as easy to level as the cube, but it is usable. It is important to level the panning element most of all, and a ball head helps with that.
    -bob
  27. #127
    Brooklyn
    4,043
    1253
    Mike I also have a RRS PCL-1 pano head that I used on the acratech: $175
    both are pristine
    http://reallyrightstuff.com/rrs/item...a%20Components
  28. #128
    California/Thailand
    1,206
    I thought about mentioning the PCL-1 also, but not knowing the budget thought I let it trickle into the conversation. I get by without the PCL-1 by taking extra time at setup, but after trying one have planned to add it also. I just tend to take some long hikes at times and my kit is already rather heavy.
    The PCL-1 plus an additional dovetail mount allows for a quick setup. Or one can forgo the "normal" RRS clamp and use the PCL-1 as the clamp (rather than the lever clamp or screw-type clamp).
    Good call, Bob.
  29. #129
    Kentucky
    924
    74
    I seems I need a ballhead because the one I have now is the RRS 25 for the M8, and a L- bracket for the camera, ball-head, PCL-1 with dovetail, and a RRS rail to set the nodal point...correct?
    Mike
  30. #130
    carstenw's Avatar
    Berlin, Germany
    2,530
    For single-row panos, yes. Btw, you only need the rail if you will work with things close up. For landscapes it might not be necessary. For multi-row panos with things close up, you will need the full pano kit, not just a rail.
    Carsten - Website
  31. #131
    Prescott, Arizona
    4,492
    367
    Mike,
    You can order the BH-40 or BH-55 with the PCL-1 pre-installed as the top clamp.
    I would use a rail usually, since the nodal slide is more an issue in a three dimensional scene. The dovetail piece is needed only if you want to use a regular clamp as well as the pano clamp. I keep my pano clamp mounted all the time.
    I don't have a full pano kit, since I don't do VR and prefer to use a wide-ish lens and a portrait orientation to the camera to avoid as much geometric distortion as possible.
    -bob
  32. #132
    Brooklyn
    4,043
    1253
    mike:
    the acractech clamp is completely functional with any of the RRS dovetails. I used it with right angle brackets, camera plates, pano rails and the pan head.
  33. #133
    Kentucky
    924
    74
    Nodal point RRS rail a necessity or not? CS3 or Auto Pano Pro?
    Mike
  34. #134
    Prescott, Arizona
    4,492
    367
    You can do without it if your subject is pretty much in one plane and relatively far away.
    If your subject contains tree trunks in the mid or fore-ground, for example, then you will find the nodal slide to be beneficial.
    -bob
  35. #135
    Kentucky
    924
    74
    Thanks Bob,
    I will be in the forest a lot so done, purchased...slap em down $100...$200
    Is there new stitching software in CS4?
    Mike
  36. #136
    Prescott, Arizona
    4,492
    367
    CS4 can stitch for several cases, but autopano is better IMO.
    -bob
  37. #137
    Fort Collins, Colorado
    2,077
    +1
    Woody
  38. #138
    DougDolde
    One of Uptown Sedona. This is an old shot with Contax 645, 140mm and Kodak DCS back. I was never satisfied with the processing until now. About 4 frames stitched in PS CS4 and processed in Nik Silver Efex.
    Real big version here: http://www.arizonaconnect.net/big.jpg
  39. #139
    Senior Member JimCollum's Avatar
    santa cruz, ca
    936
    155
    a couple more from the SWD and Aptus75s
    both taken with the 135mm lens
    3 image horizontal stitch
    9 image (full shift in all directions)
  40. #140
    Los Altos, CA
    10,486
    1031
    Jim, I really like the first one, especially due to the subtle pastel sky color ---
  41. #141
    santa cruz, ca
    936
    155
    Quote Originally Posted by DougDolde View Post
    nicely done Doug!
  42. #142
    santa cruz, ca
    936
    155
    here's the shot, but with the 55mm
    Quote Originally Posted by JimCollum View Post
  43. #143
    santa cruz, ca
    936
    155
    here are 2 crops from that image (before any processing.. no sharpening)
    closer look at just the 1 rock
    100%
  44. #144
    4,333
    This might not seem to be a very exciting image on the surface however it represents my first multiple image panorama using the Cube and Novoflex combination.
    4 shot image, Phase AFD, 75-150 lens came out to 51x17.
    Now to find a better location to shoot!
    Don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
  45. #145
    Los Altos, CA
    10,486
    1031
    Nice shot Don!
  46. #146
    4,333
    I wanted to test the limits of both the Cube and RS this morning so I did a test. Standing in my backyard I put the RS with a 72mm lens attached onto the Cube all attached to the tripod. I leveled the RS using the Cube then began taking images from left to right beginning at the furthest point at 20mm working my way right at 10mm increments for a total of 5 images. I opened the images directly into Bridge and photomerged from there. I didn't do any LLC or other type of post processing although looking at the images color I know I needed to. What I was looking for was the type of image I could obtain doing what I did; if I worried about the content I would have gone somewhere else.
    What I found was that I can produce a single row panorama using the Cube/RS combination at measures 16.64x43.553 inches. I know I can do multiple row/column images with the RS so the next test will be using the Cube/Phase AFD along with either my 28 or 75-150 lens and will try a multiple row/column merge.
    I want to try this out prior to meeting Ken next month in Canyon de Chelly.
    Don
    Don Libby
    Blog
    Tucson AZ
  47. #147
    4,333
    just completed a two row by 3 column shot using a combination of the Cube and Phase AFD along with a 28mm lens. I found the markings on the Cube to be very friendly and returnable shooting the first row then moving upwards to the second row. Again while this might not have been the greatest subject matter I can see where the Cube can be used to do multiple row image merges.
    Here's two sample images:
    The first just after it was merged while the second shows what I feel is a usable crop. No post processing has been done as I wanted to leave it as it came from the camera and yes I can see the dark streak in the sky right of center. The object of this was to see if I could obtain a multiple row/column image using the Cube and I proved to myself it can be done.
    While I think I proved what I set out to I also proved (at least to me) that you just can't beat a technical camera for flat multiple image stitching.
    Gotta run
    Don
    Don Libby
    Blog
    Tucson AZ
