Results 1 to 5 of 5
Thread: CF for HR 23
    Jul 2013
    Shanghai
    163
    CF for HR 23
    Hi, I have a question regarding CF for HR23. Could someone with this setup share their experience in regards whther the CF will help with the flaring issue inherent with the HR23 (Orange blob in the middle of the frame)?
    I am trying to figure out a way to generally solve the flare. I have used the hood from Alpa, but it doesn't help, I don't reammy like the bellow hood from LEE, so, it's now the CF I am considering? Any advice?
    Sep 2011
    1,069
    83
    Re: CF for HR 23
    The CF does not help with the flare. It is, however, key for better LCC results, noise in corners, and much better controlled vignetting. I find it a must with this lens.
    I think the only workable solution for the flare is one of those massive box hoods. I have avoided getting one just due to the bulk. I have a pretty good feel for when the lens flares, and usually use my body or something similar to block. I also check and double check the capture to make sure there is no flare as it really kills the shot.
    Jul 2013
    Shanghai
    163
    Re: CF for HR 23
    thnk you!!
    Jul 2013
    Shanghai
    163
    Re: CF for HR 23
    So am I correct in saying that this lens will need the massive bellow hood no matter what. The one from Alpa is completely useless?
    Vancouver, WA
    5,803
    564
    Re: CF for HR 23
    Yes - or your hand/hat etc. I would say that the propensity to flare is actually worse with the CF too. But, LCC is much cleaner.
