Results 1 to 15 of 15
Thread: Complete Cambo Actus Spec
    May 2010
    San Francisco Bay Area, California
    381
    2
    Here we go... complete Cambo ACTUS spec:
    http://www.cambo.com/Html/products_p...tusDB_2015.pdf
    I was trying to figure out what are lenses works with this new toy and the answers were not very clear. On the right side of the last page, there is a chart for lenses and corresponding compatible focusing rails.
    So the focal length limit is 23mm to 180mm.
    Subrata
    Brooklyn
    4,043
    1253
    Re: Complete Cambo Actus Spec
    couple of personal confirmations, using my actus, my Alpa lens adapter and my WRS lens adapter.
    23mm Alpa would focus at infinity; 210mm long barrel Alpa would focus at infinity and 24" using the standard two-fold bellows. also any alpa lenses in between: tried the 72Rmm, 150R, 60mm Alpa. this was all with the standard monorail. admittedly the 210 was out there for the close focus , and the bellows was at it's limit of stretch, but it worked
    with the 32mm in the WRS, could not reach infinity focus before the standards came together, suggesting the wide angle limit with the WRS is larger than 32mm. no problem with the alpa mount as noted.
    in my flat lens board, (not the combo recessed board) the 32mm R and 60mm SK would reach infinity.
    also i saw no way to raise the lens standard as Cambo suggests can be done with their lens boards. it might be possible by simply putting a second countersink in the mount, but it was not so with the cambo boards I had
    May 2010
    381
    2
    Jim,
    Since I don't own any Alpa or Cambo mounted lenses, I was more interested to see how a native lens with standard or your flat lens board will work. Native lenses definitely will reduce the overall cost of the system, so I was looking from that angle.
    Subrata
    Subrata
    Mar 2010
    Southampton
    565
    Thanks for the link to the PDF.
    Looks like Cambo have produced their own WRS (ACB-WRS) and Alpa (ACB-ALP) adapter plates. No A/S one though (yet).
    Oct 2014
    81
    We were really excited to have our Actus, and we've done a lot of coverage on it. Check out some of the blog links, Steve Hendrix in particular has had a LOT of hands on time with it, and likely could help with any questions about lens functionality:
    https://captureintegration.com/?s=actus
    Chris Valites
    Research, Marketing & Support, Capture Integration
    Email-Me
    Aug 2008
    Carmel/Tucson
    2,354
    Quote Originally Posted by f8orbust View Post
    Wouldn't it just be easier if Cambo put John Milich on retainer?
    ken
    May 2010
    381
    2
    ken
    I agree. John Milich's adapter plate is better than Cambo's.
    John's ACTUS DB has vertical scale as well, which Cambo forgot put it. Not sure whether they got that fixed it or not.
    Subrata
    Vancouver, WA
    5,798
    564
    ken
    Of course, if he wanted to, John could build his own Actus ... Hmm, how about one with an asynchronous rocker tilt like Sinar?
    Brooklyn
    4,043
    1253
    oh, boy...
    Brooklyn
    4,043
    1253
    re the sinar P method. as i recall, it works for tilts and swings on the rear standard. the mechanics of the base placed the axes of rotation in the film plane but offset to 1/3 across the ground glass. the idea being you would pick a point in your image on that axis line and set focus; then just tilt (swing) until other relevant parts of the image came into focus.
    of course perspective changes as you rotate the lens plane.
    seems like they suggested you do the movements with the lens plane and record them, the restore the lens plane to plumb and otherwise square and then set the same angles on the front standard.
    that sound right?
    Oct 2009
    128
    5
    Actually, the Arca-Swiss Universalis has MicroOrbix tilt, which is yaw free and
    geared. Yet weighs just over 2 lbs. Nothing extra to buy. If one already has an RM3di system, there is an adapter board accepting the R Bayonet lenses.
    It is also multi-format with format kits for DSLR, MF, and even 4x5, available.
    Also geared rise fall on both standards, Geared shift on rear, and dynamic swing on front.
    Rod
    Vancouver, WA
    5,798
    564
    Rod,
    So many great choices these days. The biggest challenge is having mounted lenses which often ties you to particular solutions. Mine are all Alpa mount so it would take a true Universalis that accepted an Alpa mount to tempt me since I can't afford another set of lenses even on flat lens boards.
    Btw, I really hate my iPhone spell checker - asymmetric became asynchronous somehow ...
    Not Available
    Mar 2015
    220
    I just wish that Cambo will come up with a battery supported MF focal plane shutter for the Actus, like it happens (shortly) with the universalis... It will be a pity to leave multishot shooters unsupported.
    Brooklyn
    4,043
    1253
    i don't see why you couldn't fit the arca shutter unit to the front standard of the combo; there is an actus adapter for that.
    then you would only need and adapter to fit non-arca mount lenses to the shutter...hmm!
    Not Available
    Mar 2015
    220
    The use of a focal plane shutter on the rear standard would allow one to use some MF lenses (of wide image circle) on the front standard in case he wants to integrate the Actus with his MF system.
