Results 1 to 13 of 13
Thread: 90mm Rodenstock SW Experience?
    Aug 2008
    180
    I had a chance to try out the 90mm Rodenstock f5.6 Alpagon (Alpa version) lens last week, and it is a great lens. I found it was yielding images that to my eye was better than my 80mm Phase One lens. I wanted to ask if anyone has tried the newer 90mm Rodenstock SW lens, and what is your experience, particularly in comparison to the previous 90mm Rodie? I am trying to decide which upgrade path take, particularly between the two 90mm options.
    Thanks for your input,
    John
    Brooklyn
    4,043
    1253
    Re: 90mm Rodenstock SW Experience?
    just got one for my actus/blad 50CFV-c rig. so far so good, but hardly used yet. image attached
    Sep 2011
    1,069
    83
    The 90SW is significantly better than the 80LS. Compared to the older 90W, it is sharper, bigger image circle and physically bigger. it is also more expensive and requires either an extension box or lens barrel making it bulkier to carry. It is the sharpest lens I have.
    Aug 2008
    180
    It looks like Alpa does not have this lens in their line-up. What camera do you use this lens with?
    Sep 2011
    1,069
    83
    https://alpa.ch/en/article/hr-alpagon-5-690-mm-sb34
    HR-SW is the one with the yellow ring (as above). The older HR-W has a blue ring.
    Dec 2010
    Southern California
    141
    21
    Here is the link that Jag tried to post to show that Alpa does have this lens in their line-up.
    http://www.alpa.ch/en/article/hr-alpagon-5-690-mm-sb34
    --Steve.
    Aug 2008
    180
    Got it- this helps.
    Thanks!
    Jun 2010
    15
    I am interested in if this lens can cover 4x5 format (152mm IC), which is about shifting 40mm up/down with 15mm left/right on 40x54 digital back. If it's ok I am tempting to try it on 6x12 and 4x5. Would someone also want to try it? Thanks
    Henri
    Sep 2011
    1,069
    83
    Quote Originally Posted by Pinhua View Post
    Henri
    I think you can push to about +/-30mm shift in landscape without any rise or fall. The IC is only 125mm. On the Rodies you also hit a hard shadow with the disk they have at the limit of the IC.
    I'm assuming you're using film here and the resolution of the SW will likely be overkill, not to mention the price. Some of the "analog" lenses will better serve you i'd think.
    Oct 2009
    128
    5
    Both the older and the newest 90mm from Rodenstock are excellent, with the HR SW yellow ring, a real winner. They are both, like many 90-105mm lenses prone to flare, so be sure to use a good lens shade. Otherwise, as was mentioned above, the latest incarnation of this lens is best out there.
    Be well,
    Rod
    Jul 2010
    655
    never tried the older one. But I can tell you the newer one is the sharpest lens I've ever used... BY FAR
    May 2013
    Los Angeles
    38
    9
    I Use Rod Grandagon 90 4.5, and very happy with, You can download 16,930x8654 original jpeg
    https://www.flickr.com/photos/512354...787708/sizes/l
    Vancouver, WA
    5,802
    564
    Quote Originally Posted by shortpballer View Post
    The older one is no slouch either.
