Page 4 of 4 FirstFirst ... 2 3 4
Results 151 to 152 of 152
Thread: Pentax 645Z vs A7RII IQ and bang for the buck
  1. #151
    Workshop Member Bryan Stephens's Avatar
    Oct 2011
    Connecticut
    463
    Re: Pentax 645Z vs A7RII IQ and bang for the buck
    Quote Originally Posted by jerome_m View Post
    It is the same sensor, but the multishot process emulates a higher resolution sensor and increases the sample frequency. One will see better the limitations of the lenses.
    Yes and no. It emulates the output of a higher res sensor, but the input is identical to the 50c sensor in single shot mode. It takes multiple single shots (I believe between 2 and 6) and combines them, so it really is not the same as if it were a true 200mp sensor. If it did behave in that manner, you would REALLY need some impressive glass to get optimal results, any any shortfall would be magnified.
    I think even the impressive 60XL or the 40HR would show any possible flaws at that pixel level
    Bryan
    “You don’t take a photograph, you make it.” — Ansel Adams
  2. #152
    Sep 2013
    598
    Quote Originally Posted by Bryan Stephens View Post
    It does behave in that manner. I don't really want to discuss the underlying reason, but this is a consequence of the transfer functions of the lens and sensor being linear. If you had stepping motors of infinite precision, you could actually completely characterise a lens with a single pixel moved around.
    As to the glass being impressive, not that much. Multishot backs of that sort increase the resolution by a factor of two, but the MTF of the lenses will not suddenly go to zero when one samples twice as much. One sees the defects of a given lens more clearly, but the lenses do not suddenly turn to mush just because one has 4 times more pixels, just as good lenses from the film era did not suddenly turn to mush when 24x36 SLRs went from 6 mpix to 24 mpix.
