Results 1 to 21 of 21
Thread: Another Helicon question...
    Apr 2008
    Lancs, UK
    181
    I read somewhere that the Helicon software is (understandably) sensitive to camera movement.
    Have any of you guys tried it with a view camera, especially one with a Copal shutter? ...or is that a really dumb idea?
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Another Helicon question...
    I have not tried it with a view camera, but I have tried it with a Horseman with a Copal shutter.
    There were no problems whatsoever, but the Horseman is possibly considerably stiffer than the front standard of some view cameras.
    I have also tried it with hand-held images taken with an M8 and I guarantee that I am a lot less stable than almost ANY tripod.
    The software seemed to handle that just fine too, so I doubt that there would be a camera motion problem for almost anything tripod mounted.
    -bob
    4,333
    Speaking only from my experience with CS4 – it allows you to “auto align layers” prior to using the “auto blend layer”. I’ve had to use the auto align even when on a rock steady tripod but there was wind.
    I wouldn’t be too surprised to hear that helican software doesn’t offer the same.
    Don
    Btw I’m now shooting over 95% of my landscape images with a Cambo RS 1000 using lenses with copal0 shutters.
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Prescott, Arizona
    4,492
    367
    Helicon seems to just assume that alignment is necessary and just does it.
    -bob
    Apr 2008
    Lancs, UK
    181
    Quote Originally Posted by Bob View Post
    -bob
    I don't know if it is the software, or your hand-held skills, but I'm impressed either way!
    Apr 2008
    Lancs, UK
    181
    OK, let's push the boat out here...
    ...what do we think about stitching the output from three or four focus-layered images? Or is that asking too much?
    Los Altos, CA
    10,486
    1031
    You'd be possibly dealing with a lot of subject motion, but other than that, why not?
    The obvious question that then comes to mind is do you stitch first then focus blend, or focus blend then stitch? My gut says the latter is the best approach, but I don't know for sure...
    home: www.getdpi.com
    Manchester/Jerusalem
    2,652
    290
    Unless you're using stitch software that allows you to save control points (PT) it's very likely that the stitches will be slightly different. Especially when you're dealing with images that have different focus points and therefore have tiny focal length differences. As such you're asking Helicon to work far harder in matching the images as the geometry of the resulting stitches may be different. Aligning pixels is one thing, working with different distortion corrections and unwrapping alogorithms is probably too much to expect the program to be able to do. As such methings focus blend then stitch.
    23,623
    2555
    I would focus blend each set than stitch would be the ideal way. This way each image going in would be fine tuned before the stitch. That would be my guess
    www.guymancusophotography.com
    Sep 2008
    74
    Yes, Guy is correct. I have been experimenting with Helicon and stitched pans. I found running Helicon on each focus bracket set then stitching (I use autopano pro) works great. When I try to stitch first I found that the blending functions create enough distortion to confuse Helicon.
    Howard Cubell
    Quote Originally Posted by smhoer View Post
    Scott:
    If you also bracket for exposure, you will be lucky to get one shot per day. I am dizzy thinking about it. God forbid the light changes.
    23,623
    2555
    Howard that is why we shoot MF we have a great range to make that adjustment if under. At least i told my wife that one. LOL
    Sep 2008
    74
    Howard, Yes, you have to choose between focus bracketing and exposure bracketing if you stitch. But that is cured by a tilt/shift lens. Although I have noticed my hair is longer and more gray each time I post process all those shots.
    Member jerryreed's Avatar
    Essex, CT
    70
    Is it everyone's general sense that the Helicon Focus is the superior to Photoshop's solution?
    Jerry Reed
    23,623
    2555
    I have not tried CS4 for it but from all reports there is a big YES
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by jerryreed View Post
    Jerry Reed
    Hi Jerry:
    For sure. The CS4 entry is a very basic attempt -- it works, but frankly not all that well compared to Helicon.
    Prescott, Arizona
    4,492
    367
    Helicon is far better for focus stacking at this point.
    It does a much better job with its depth mapping technique and besides has some controls for adjusting the algorithms that PS just does not have.
    Also, it is easier, IMO, to edit the masks (easier to produce a good result, not easier from a tediousness point of view) in Helicon to dress up the final result.
    -bob
    Sep 2008
    Near Brussels, Belgium, Europe
    541
    Jerry Reed
    Asked the same question and was told Helicon is the solution.
    I then gave it a try, it's nice and easy, but offer smart tools too.
    Worth every peny.
    A lens I was selling, the guy asked some pictures, so I decided to quickly make a test to see it work:
    Hasselblad HC 120mm f16:
    Hasselblad HC 120mm f16 - 6 shots staked with Helicon:
    Nice and easy, really
  19. #19
    Essex, CT
    70
    Thank you for the responses and examples. I downloaded the trial and will be using it this weekend. Thanks again.
    JR
  20. #20
    DanPBrown
    This is a topic close to my heart. I've been focus blending for about five years now. I use the technique mainly for macro subjects. I've used Helicon Focus and found the results disappointing. All of my successful blends have been done manually, a very time consuming endeavor.
    Here is a photo that was focus blended and stitched as a panorama. The final image is 61 megapixels and composed of 151 images. It took me over 50 hours and 5 months to complete. When it was complete I was reluctant to show it to others, I was afraid that I would receive a yawn and all that time would have been wasted.
    Dan
    www.danbrownphotography.com
  21. #21
    California/Thailand
    1,206
    Dan,
    In my opinion, time spent the way you want is not time wasted.
