Results 1 to 4 of 4
Thread: Leaf Aptus-II 7 EXIF issue
    Jun 2015
    Melbourne AU
    181
    New user of a MFDB here. The issue is when I use the back tethered to Capture One (8.3.4) the time and date make the journey to Capture One in the EXIF data. However when I use the back with a CF card the time and date appear not to be written to the image file. I've checked the files using a utility to check that it's not a Capture One issue, but apparently an issue with the back not writing the data to the file.
    The back is being used on an Alpa STC.
    The back is actually a Mamiya DM33 - a re-branded Leaf with the latest firmware.
    Any ideas?
    Dec 2010
    Southern California
    141
    21
    Re: Leaf Aptus-II 7 EXIF issue
    Quote Originally Posted by Pelorus View Post
    Any ideas?
    I have the same digital back that you have. I can see the EXIF data on the back, in Light Room, and in Capture One 8.2.
    --Steve.
    Jun 2015
    Melbourne AU
    181
    Thanks Steve, that's what I was seeing when I shot tethered. When I shot to CF card I wasn't getting that.
    However I've found the solution. For reference: If you have any odd characters in the information entered into your back then it won't right EXIF data to the CF card properly. In my case I had in the copyright field. As soon as I deleted that the EXIF wrote to the card properly.
    May 2009
    Marseille, FRANCE
    972
    by the way, sometimes you will have trouble with the internal battery as well...
    see "Aptus Internal battery"
    http://www.getdpi.com/forum/medium-f...t=battery+leaf
