Results 1 to 10 of 10
Thread: dip toe into view camera with phase back?
    Senior Member faneuil's Avatar
    Nov 2008
    611
    forgive the ignorance. I come from Mam 645 land.
    What would be a 'low cost' method of getting into a view camera with my Phase back?
    I assume I need: 2x3 view camera, lenses and lens board and plate /trigger for the phase back.
    any help appreciated!
    my back has live view, so I imagine I would compose and focus that way
    view camera curious,
    Eric
    Eric Korenman
    www.korenman.com
    NYC
    3,647
    7
    Re: dip toe into view camera with phase back?
    Quote Originally Posted by faneuil View Post
    Eric
    What problem are you trying to solve? In other words what will you use the view camera setup for? There are a lot of differences between the right way to go if you want to do, for instance [long-lens-macro product photography] in studio vs [wide angle landscape images in the field].
    Tell us more about what you'd like to accomplish and you'll get better advice about what way is best to go about it.
    Also "low cost" is a very relative term. Do you have any specific budget in mind?
    Nov 2008
    611
    thank under $3000 or so.
    plan is to shoot more interior and architectural work.
    was looking at the toyo 2x3 digital solution.
    I see used toyos under $1800 here and there.
    eric
    Eric Korenman
    www.korenman.com
    NYC
    3,647
    7
    eric
    Generally interior and architecture calls for wide angles and high mechanical precision. The Toyo will do poorly with both. An Arca, Cambo, or Alpa wide angle tech body would all be more logical choices. If you need to stay on a budget you can sometimes find Cambo Wide DS body with a lens for within your budget. Just make sure you get one with an M mount.
    Toyo makes an okay budget studio camera where the lenses are typically longer. At shorter focal lengths the same amount of slop (e.g. +/- 1 mm of wiggle movement on the front standard) produces a greater issue.
    Mar 2012
    Sweden
    1,538
    If your back is one of the newer CMOS backs and you want to shoot technical wide angles you should know that there's limited compatibility with the lenses. As you're new to architecture photography(?) then the choice becomes more difficult as you won't have a good feeling of how limiting the movement limitations will be for your work.
    It's quite complex to relate to so I'd recommend to contact a dealer which knows the stuff if you start from zero.
    If you want a budget system it's easier to find one for an older back like a P25+ or P45+ as those doesn't have the same requirements on lenses and the larger pixel sizes is a little bit more forgiving.
    Nov 2008
    611
    will be using my IQ180 CCD back
    reaching out to my favorite dealers today!
    thanks
    eric
    Eric Korenman
    www.korenman.com
    Member AreBee's Avatar
    Dec 2012
    Highlands, Scotland
    171
    torger,
    ...it's easier to find one for an older back like a P25+ or P45+ as those doesn't have the same requirements on lenses and the larger pixel sizes is a little bit more forgiving.
    Do you happen to know if the P45+ requires an LCC when used with the widest Schneider lens? Does it require an LCC even when used with the Rodenstock 23HR?
    NYC
    3,647
    7
    Quote Originally Posted by AreBee View Post
    torger,
    An LCC is always suggested. The amount of color cast with unshifted wides on a 45+ is pretty minor and easy to miss until you apply a proper LCC and see the image with no color cast.
    Remember the LCC also provides optional dust-removal and optional vignette/falloff correction.
    Mar 2012
    Sweden
    1,538
    torger,
    I have never seen the P45+ with a 23HR, so I don't know. With the widest Schneider, being the SK28XL, I would surely apply an LCC.
    There are various reasons for color cast but in the least case it happens directly in the sensor color filters just by changing the angle the light passes through it, so with the current technology it's unavoidable, and when the widest tech lenses were designed it was with awareness of these issues. As well-behaved color cast is 100% correctable with the simplest flat-field correction algorithm it was considered an acceptable drawback. Tech cam workflow is quite slow anyway, so the extra step doesn't cost much time. You also get the added bonus with corrected vignetting and dust spot removal.
    As color cast is in comparison quite minor I know some skip LCC for more casual shots, or sometimes even leave it in for effect. But for the perfect picture you should apply it also for the older backs.
    Senior Member Lars's Avatar
    Sunnyvale, California
    1,811
    19
    I had a similar idea when I got my Ebony SW23 6x9cm view camera in 2002 - Once prices on digital backs come down I'll use it for digital.
    Well, prices never did come down - the backs just got better. and of course different lenses would have to be used due to sensor size being much smaller than 6x9 cm.
    Monochrome: http://mochro.com
