Results 1 to 9 of 9
Thread: DT Tech cam samples
    Sep 2011
    1,095
    83
    DT Tech cam samples
    Looks like Doug has the files up. Being in Canada, I don't appear to be getting an email download link. Has anyone had a chance to look? Mostly interested in the 32HR/100 vs. 32HR/80 images.
    Sep 2011
    1,095
    83
    Re: DT Tech cam samples
    Was simply impatient. Got the download link. Lots of files to look at, thanks again DT & Doug.
    Little Rock AR
    2,178
    8
    Quite a body of work, thanks to DT and Doug for posting and allowing full access.
    Paul C
    NYC
    3,647
    7
    For anyone looking...
    Phase One IQ3 100mp Raw Files Download
    Thanks for the kind words gents.
    If anyone would like to arrange further testing our offices in LA and NYC and our cabinets full of gear are always available to such testing (appointments strongly encouraged to ensure we have the specific gear and staff time you need).
    Brooklyn
    4,043
    1253
    how about a brief summary?
    NYC
    3,647
    7
    Obviously some over-simplification in pursuit of brevity.
    Regarding 100mp use on a Tech Cam:
    - About the same effective range of movement allowed as the 80mp or 50mp. Less movement allowed than the 60mp.
    - Schneider wides are generally not recommended but may work straight on, or with minimal movements
    - Center filters recommended for any wides, Rodenstock or Schneider
    - The live view (on back, via wifi, or via USB3), HDMI out, and dynamic range of the IQ3 100mp are very well suited to tech cam use
    Given the resolution, sensor size, live view quality, and dynamic range I suspect many of our customers will select the IQ3 100mp for use on tech cameras, knowing that they'll lose some movement flexibility with wider lenses.
    I also suspect we will see more use of correction of perspective in post (using C1 or PS) or using wider-than-needed lenses to allow cropping part of the frame as an effective rise/fall/shift movement. 100 sharp megapixels in a single capture covers a lot of ground in this regard. This is not necessarily mutually exclusive with movements in-camera. For instance you could accomplish a very large virtual rise, with a very sharp high res image from a combination of 10mm of rise with the 32HR, combined with a degree or two of pitching the camera backwards on the tripod to look up a bit more (and corrected that degree or two in C1), combined with cropping the top 2/3rds of the frame.
    Little Rock AR
    2,178
    8
    On the 32mm Rodenstock, was the CF used? And thanks again for an outdoor test.
    The 32mm looks very good, after corrections and the 60mm @10mm has a very small amount of cast, so it might easily make 15mm or 18mm of shift.
    Paul C
    NYC
    3,647
    7
    Paul C
    No Center Filters were used in the tests. In reviewing the images I wish we had.
    Since the pixel pitch on the 80mp and 100mp cause a good amount of light falloff, minimizing the optical falloff is more important.
    Little Rock AR
    2,178
    8
    One last question, in the indoor tech camera series, Millar Room, the shift is listed as -20 shift, is this the same as 20mm R shift? or with an Arca 20mm of moving the DB to the left?
    If so I was pleasantly surprised to see that the IC indicator is not really a big factor as it allowed 20mm of shift. On the 40mm HR-W, the indicator seems to be more visible by 18mm of shift and by 20mm quite hard on the edges.
    Paul C
