Results 1 to 9 of 9
Thread: Camera shake/focus
    Dec 2015
    Sparks, Nevada
    64
    Camera shake/focus
    I recently got a Mamiya AFDII with a Sinar 54m 22mp back. My pictures and files seemed nice, smooth, sharp with good depth. The problem with the Sinar back is it only works tethered so I bought a Leaf Aptus II-8 40mp, from Ben off this site so I could carry around my camera easier on photowalks with my wife (As opposed to my easy to use Leica). I'm just an amateur but I do submit some pictures to a couple of stock companies for the challenge. I have noticed that even on a tripod its harder for me to get the nice sharp pleasing pictures with my Leaf like I could with my Sinar. I was wondering if this could be because of the higher pixel count seeing more resolution? Or what? Not all my pictures with the Leaf are bad just a higher percentage than with the Sinar.
    Any ideas?
    Greg
    NYC
    3,647
    7
    Re: Camera shake/focus
    For a high jumper to clear a 4 foot pole requires minimal effort. Any pair of shoes will do, any technique, and he can even be a bit hungover.
    For the same high jumper to clear an 8 foot pole requires more effort. Every detail of the technical execution matters.
    Or put differently... If you want 40 sharp megapixels your technique (e.g. min shutter speed, how you hold the camera) matters a lot more than if you want 20 megapixels.
    I'd recommend speaking with your dealer about what equipment and techniques might help. Helping you get the most out of your gear is literally their job! If that's us feel free to reach us by email, phone, text, Facebook etc!
    Dec 2015
    Sparks, Nevada
    64
    Thanks for the reply. I've been working on technique and am pretty sure my hit ratio will improve with practice. I kind of thought the additional pixels has something to do with it.
    Greg
    Little Rock AR
    2,178
    8
    Forums are an open area to share information so you can call your dealer, or pose the question here, and hope that some other photographers that have used this or similar equipment might pass on some thoughts that might help. I am one of the later.
    Can you provide more information on:
    1. Lenses you are using,
    2. Shutter speeds,
    3. ISO
    4. Shutter release
    5. Mirror up or not
    The reason I ask, is the AFDIII, is well known for the mirror slap. I used the AFDIII for almost 3 years with a P45+ and had some similar problems when the camera was on vertical. I can't remember if your leaf back has the internal rotation sensor or not. But for some reason the AFDIII seems more prone to give some shutter/mirror vibration when the camera is vertical. Make sure you have mirror up and with that set, make sure you wait a sec or two to allow the vibrations to subside. The effect you see most times is part of the image may look like double vision or you may see double edges. In the years I used the AFDIII and then the Df, I rarely shot the camera without a tripod, it just became part of the deal. I also usually used the remote release, (coiled cord)
    Lenses, the more telephoto you go, the more problematic technique becomes. Really with Medium format anything at 80mm and out, you really need to make sure the tripod/camera rig is all solid. And you might again try mirror up. The older Mamiya glass can be excellent but you really need to watch your shutter speeds, with medium telephoto on out.
    Shutter speeds, I would not try to hand hold the AFDIII, slower than 1/125 or 1/60 especially with a 80mm or higher. Wide angle you might be OK hand held.
    Consider getting the Mamiya remote release. This allows you to trigger the shot without hitting the camera's shutter button. These are available on B&H and have a coiled cord. Well made and can give you a lot more shooting control with slower shutter speeds. The IQ backs, have the ability to trigger the camera (focal shutter) from the LCD of the back, which I have found to be invaluable.
    AF or manual focus? I moved from 25 + years of using various DSLR and 6 x7 cameras to the 645 AFDIII in early 2008. I never was comfortable with trying to manually focus from the viewfinder unless I was working in close. You can purchase a viewfinder magnifier that attaches to the eye piece of your AFDIII which you might want to try. These are often on eBay. There is no AF micro adjustment on the AFDIII, but the AFDIII, is hit three times type focus. YOU RARELY GET THE CORRECT FOCUS, on the first hit. This is also a well documented issue and was not fix until the DF+ and even then with a later firmware update. But with the AFDIII, you need to develop a tap, tap tap on the shutter button and you can hear the AF working each time, usually the last tap will be the good focus. The AF can be very good, but the trick is to realize the first hit is most often NEAR, but not the best.
    I mentioned mirror up, but that really is critical on the AFDIII or most Mamiya bodies, even the latest the XF. Unless you are shooting fast shutter speeds consider using mirror up on most of your shots. Also, work with your lenses, as certain lenses seem to have shutter speeds that they just seem to get out of sync with the mirror/shutter movement. My old 105-210, was one of these, and no matter what I did, the shutter speeds of 1/30 to 1/45 tended to have blur, even on tripod.
    Just a few thoughts to try.
    Paul C
    Paul Caldwell
    [email protected]
    www.photosofarkansas.com
    Dec 2015
    Sparks, Nevada
    64
    Hi Paul,
    Thanks for the insites. I'll check into the focus magnifier though I didn't think that is a real problem as I'm using the same camera with both backs. BTW. it's a AFDII not 3. On my tripod I try to use mirror up, a cable release or self timer and iso 80 and expose to the light. The lenses are a 80 2.8 af and a mf 150 3.5. I used those lenses on both backs also. I generally end up with a slow shutter speed. Maybe thats part of the problem. I'll have to work on better lighting or maybe a wider f stop with focus stacking.
    Greg
    Little Rock AR
    2,178
    8
    Hi Greg.
    Sorry about the II vs III miss. The AFDII and III both have the mirror slap problems. Overall AF issues were finally addressed with the DF+. Sounds like you are doing all the right things.
    Paul C
    Paul Caldwell
    [email protected]
    Dec 2015
    Sparks, Nevada
    64
    Thanks Paul,
    You have wonderful photos on your website.
    Greg
    Senior Member etrump's Avatar
    Jan 2009
    1,311
    Big time! I recently upgraded to the XF and IQ3100 and am very pleased with the improvements in regard to mirror slap and shutter vibration. I can even use the 300mm lens which is tack sharp. Prior to this kit, I could not get satisfactory results with any of the AFD bodies.
    Hi Greg.
    Paul C
    Ed Cooley
    Visit My Website
    Dec 2015
    Sparks, Nevada
    64
    Update...
    I got a manual focus screen for the camera and have been really working on technique and it's starting to pay off. At least now the majority of my pictures have something in focus.
    Click image for larger version.
Name:	Horse family running.jpg
    Wild Mustangs
    iso 100 200APO at F4 1/800
