Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 151 to 200 of 268
Thread: Big Hasselblad anouncement on the 22nd.
  1. #151
    Jun 2008
    544
    Re: Big Hasselblad anouncement on the 22nd.
    Where did the dial go? Is it one of those small button-like things on the back to the right of what seems to a an EVF?
    If it is 44X33 is way overpriced for 2017!
    It looks so much like a SWC.
    Seems like images have leaked now. Hasselblad X1D.... $9k body only, so my guess of $8.5k was not too bad. Looks like a 44x33mm sensor, 45mm/3.5 and 90mm/3.2 lens available for $2.3k and $2.7k. I'm hoping for a wide angle too, but it seems like the start is only two lenses.
    The jagged button in the Hasselblad instagram photo seems to be a popup button located behind the shutter button.
  2. #152
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,598
    21
    Unfortunately, the LCD appears fixed.
  3. #153
    Dec 2011
    North Dakota
    171
    3
    Is it just me or does anyone else not see the dial that was on the second teaser picture released by Hasselblad? Is this "leaked" picture fake or is their a second camera out there?
  4. #154
    Jun 2008
    544
    Who knows!
    https://scontent-yyz1-1.xx.fbcdn.net...18013352_o.jpg
    Quote Originally Posted by markymarkrb View Post
  5. #155
    Mar 2012
    Sweden
    1,538
    I think the dial is there, but it's of popup type, look behind the shutter button. Press it, and it pops up, turn it to select whatever you select with that button, and press it again to move it out of the way. The image looks too good and too reasonable to be a fake.
  6. #156
    Mar 2012
    Guelph, Canada
    87
    It could be noted that the new mirrorless mount seems limited to the 44x33 size, and the new lenses are designed for that size, eg an "APS-C" of medium format. This should be expected though as it's intended as a prosumer camera, not to cannibalize on their own H line. The mirror box will stay in the pro segment for yet some time...
    This is the same thing that many said about the Sony E mount for quite some time before the A7 was released, and that was with the NEX's in hand and the exact mount specifications known. I would be shocked if Hasselblad locked themselves into a "crop" sensor size.
    This is definitely an intriguing camera and I am looking forward to seeing proper specs, as well as what Fuji does.
  7. #157
    Jun 2008
    544
    I agree with you. For Hasselblad to lock this system with a 44X33 sensor automatically makes it a niche camera. Full frame 645 has to be. Or is niche market cameras the future for enthusiast photographers? Gosh, at least a 48X36!
    I grabbed my 500CM without lens and mirror up to take a good peak at the camera through the lens opening. Taking into account this sensor must be at around one third the distance to the lens flange, did visual calculations. If this new lens mount is as big as the V camera's, a 54X40 sensor could be possible. me thinks
    Besides Canon, Nikon and Sony are too close in sensor size with their FF35 bodies at 1/3 the cost.
    Eduardo
    QUOTE=med;695647]This is the same thing that many said about the Sony E mount for quite some time before the A7 was released, and that was with the NEX's in hand and the exact mount specifications known. I would be shocked if Hasselblad locked themselves into a "crop" sensor size.
    This is definitely an intriguing camera and I am looking forward to seeing proper specs, as well as what Fuji does.[/QUOTE]
  8. #158
    Sep 2012
    Moscow
    462
    Right, after experiencing a flip screen for the first time on the Z, I'm not sure I could go back. This seems even more important on a compact camera that you can easily hold at all sorts of heights and angles.
    On one hand I'm happy that there's finally a mirrorless MF camera coming out, but on the other hand I didn't expect it to cost more than a 645Z, it seems Hasselblad is still banking on pedigree to some extent.
    I also wonder how the viewfinder and electronics will perform with such a large sensor, and also the thermal limitations of cramming all that stuff into a small body. It's going to need a beefy CPU to handle that no matter how you cut it.
  9. #159
    Feb 2011
    Eads, Tennessee
    1,033
    I don't see anything wrong with building the system around the 44 X 33 sensor size. There's room to grow for pixel density without severely affecting lens performance (by requiring maybe one lower f stop for the same diffraction spec). This would be an easy camera for 16 X 9 two shot pano's as 10mm of shift is equal to 5 degrees of swing which is really pretty small. I was extremely happy with the files I got out of my Leaf CMOS sensor - even single shot. Now...... when will it be available?
    Victor
  10. #160
    Feb 2015
    Colorado
    200
    It's not about the people that have worked in the company built cameras and survived many ownership and CEO changes. I've seen many companies destroyed by poor leadership and top-down steering into the wrong products, I've personal experience about that even, very frustrating when you're one of the designers and forced doing something you don't believe in. The new CEO comes from luxury brands. The owners/board usually don't hire a CEO with that background by coincidence.
    So far I've been surprised of how much camera and how little luxury that has come out from this new leadership. So it looks good so far, but I still think the owners have things to prove that they intend Hasselblad to be a relevant camera manufacturer rather than some sort of luxury brand living off the brand alone.
    This new camera looks good to me so far, but it will be interesting to see how they market it, and what the feature set is. If it functions like a silly compact camera and is marketed to instagrammers there will be a big minus in my book, but if it really has logical functions and is a genuinely well-designed camera for photographers ("prosumers" or not), then it's on the plus side.
    Regardless of what this camera actually turns out to be, I hope it sells in sufficient numbers to keep them cooking along.
    The whole digital vomitorium has been a boon to the photo / camera enthusiast crowd and to the industry types who's livelyhood was born of and rests solely on the phantasm of the "Internet Gear Review Hero"...but it has not at all been kind to actual photographers or camera makers.
    That is why I hope it does well. I know people at Hasselblad who have been with the company for decades through thick and thin and the constant barrage of "Kodak Style" jabs and stabs has been enough to make a few of us want to punch someone.
    Regardless of who is at the helm, it does no one any good to see a phenomenal brand like Hasselblad suffer. But alas, that indeed does seem to be a big part of the photo enthusiast hobby nowadays, the camera toting and live-for-the-internet A-holes who cheer at those who suffer.
    Hasselblad needs to win...I need them to win.
  11. #161
    Jun 2008
    544
    Is it really you Victor?!!!!
    Quote Originally Posted by vjbelle View Post
    Victor
  12. #162
    Jun 2008
    544
    Maybe these are the first pictures online from the X1D. SQUARES?
    Via Photo Rumors.
    Give it a click
    Hasselblad X1D Mirrorless Launch? - Album on Imgur
  13. #163
    Feb 2011
    Eads, Tennessee
    1,033
    Quote Originally Posted by Uaiomex View Post
    Well..... I looked at myself in the mirror and I looked like me so I must be me.
    Me
  14. #164
    Feb 2011
    Eads, Tennessee
    1,033
    Who is K&M Camera? They don't list Hasselblad as one of their product lines. If I was truly interested I would be talking to Dave at CI.... At this point I'm only slightly tempted but its a great release for Hasselblad assuming its available sometime in 2016.
    Victor
  15. #165
    Oct 2008
    Munich
    876
    Victor
    To quote someone at LL: "KM camera are one of the two legendary camera stores of NYC left in business."
  16. #166
    Senior Member Antonio Chagin's Avatar
    Jul 2008
    Miami-Fort Lauderdale
    476
    I said it once in this forum almost 2 years ago and nobody reacted. This is the future.. Medium format, full frame APS-C and all the rest to mirrorless.!!
  17. #167
    Feb 2011
    Eads, Tennessee
    1,033
    Quote Originally Posted by Christopher View Post
    That may be but they don't list Hasselblad as one of their product lines. I don't care how legendary they are I'm not about to give anyone $1k up front when they may not even be a dealer. Just working with the info available.
    Victor
  18. #168
    23,623
    2555
    This certainly does look interesting. Look forward to more data
    www.guymancusophotography.com
  19. #169
    Mar 2012
    Sweden
    1,538
    Via Photo Rumors.
    Give it a click
    I guess it's a part of the marketing strategy, to connect back to the legendary V system. The look of the camera itself is pretty "squarish" too, I think it looks really nice by the way, although I'd like to have a bit more of the retro look on the lenses too. I would expect the camera to have a square crop mode just like the CFV backs, and it's probably that the photographers have used for the album. But the sensor clearly shows that it is a 4:3 camera, and I'm glad for that.
  20. #170
    Feb 2011
    Eads, Tennessee
    1,033
    So Am I!
    Victor
  21. #171
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,598
    21
    The camera registry is clearly very short.
    The sensor plane mark is visible. It is next one of the strap lugs and above the H.
    It gives hope that even Canon EF lenses can be adapted for this camera.
  22. #172
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,186
    This actually looks good and I'd agree that this is potentially a game changer. I hope the next two lenses released are an ultra wide in the 20-28mm range and a long telephoto in the 150-180mm range. The price is expected although I hoped for a revolutionary price that was even lower (closer to 4.5-7k).
  23. #173
    Sep 2013
    New York
    564
    Tell you the truth, I was hoping for something a bit more, well, revolutionary - like say a Phase IQ3 FF for the price of the Pentax. I know, it was too much to wish for. You can't get champagne for beer money, but sometimes you just might......
    From what I am reading, the sensor seems to be the size and resolution as the Sony 50MP in the IQ250 or the Pentax 645z, whether it is exactly the same remains to be seen.
    There is no tilt capable LCD, a big let down for those who've now become accustomed to it.
    The new lenses are just that - new. Unless it can take legacy H glass it becomes very limited.
    The body is smaller, that is very welcome and being mirrorless allows for the development of interesting adapters.
    The price is what the Pentax was offered at initially, so no big gains there (but didn't honestly expect any).
    So far, the only positive thing from my perspective is the smaller size and the Hasselblad reputation. Not sure I can get too excited - not yet anyway. Still it is exactly the kind of boost MF needs, it keeps the interest alive and affordable (relatively speaking).
    Too much to list, let's just say I have a bad case of GAS.........
  24. #174
    Senior Member bensonga's Avatar
    Alaska
    2,416
    819
    Some have made the comment they hoped it would be the equivalent of a digital Mamiya 7II. Well, the basic body shape/design of the new X1D, at least from the few pics we have seen, does have a passing resemblance to a 7II. It will be interesting to see how close it comes in actual physical dimensions and weight.
    I don't think many of us were really expecting the new Hasselblad to be a rangefinder.
  25. #175
    Jun 2011
    30
    7
    Something seams to be wrong with the picture of the body plus the lens.
    The mount of the lens ( and the body) is not Paralell to the front of the lens
  26. #176
    Pratamnak
    9,336
    2157
    Please don't let us have a new "crop vs. full frame" debate. Full frame can be anything from 35mm to 8 x 10. This is a new product family from Hasselblad, and apparently, it's 44 x 33 mm or thereabouts. That's almost twice the size of 35mm, so large enough for many, probably most. Also, a larger sensor would mean a larger body and not least larger, more expensive lenses, limiting the market for the camera.
    Let's discuss what it is and not what it could've been. I've noticed that it doesn't seem to have a built in, steam driven can opener either
    Things I sell: https://www.shutterstock.com/g/epixx?language=en
  27. #177
    Oct 2015
    87
    Quote Originally Posted by Jorgen Udvang View Post
    Are you really sure? I think, that this pop-up dial behind the shutter release is just for that.
  28. #178
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,186
    I guess the big thing left for me to see are the specs. Are the two lenses announce focal plane type lenses or do they have leaf shutters? Is the body dual mode like say the Leica S to be able to support focal plane or central shutters? What's the minimum shutter speed... I'd hope it was at least 1/8000th of a second if it's a focal plane shutter. Is there an electronic shutter? What's with the rumors about removing the ability to tether? I think most people interested in this camera would like the ability to do so even if it's not a regular thing for them.
    Other than had that it looks like it has potential. Seems like the freaky love child of a Mamiya 7II, a Leica T, a Hasselblad H camera, a Hasselblad V camera, and a Sony FE camera.
  29. #179
    Oct 2012
    Singer Island, Florida
    129
    Quote Originally Posted by HiredArm View Post
    I agree. Tethering is important. I believe it would be a mistake to not be able to tether. A certain deal breaker for some.
    We will know the specs in the morning.
  30. #180
    Apr 2008
    313
    Quote Originally Posted by BlinkingEye View Post
    Yes we will
  31. #181
    Pratamnak
    9,336
    2157
    I would be surprised if it doesn't offer wireless tethering.
  32. #182
    Apr 2008
    313
    I'd be surprised if it did, the bandwidth required to send RAWS across wireless would be pretty epic no?
  33. #183
    Sep 2009
    1,587
    It's funny to read some Phase sales people on various forums poo pooing the new compact 'blad because its:
    "Cropped medium format is not *really* medium format. But maybe the rich enthusiasts it’s pointed at won’t know the difference."
    And other such gems... So the cropped sensor *is* MF when in an XF, but not in a 'blad? The knives are out, eh?
  34. #184
    Pratamnak
    9,336
    2157
    Quote Originally Posted by Nick-T View Post
    I would also be surprised if it doesn't have pretty epic wireless bandwidth also
    Look at it this way:
    This is a very portable camera and will be used a lot for on-site shooting where tethering to a laptop will be the rule. That laptop will often be some kind of MacBook, and since Apple seems hellbent on removing all kind of holes from their computers (they're probably afraid of data leaks or something), WiFi might soon be the only way to connect. With more serious processing capacity and competent editing software becoming available for tablet computers like the iPad Pro, wireless is already the way to go.
  35. #185
    Pratamnak
    9,336
    2157
    Quote Originally Posted by tjv View Post
    "Cropped medium format is not *really* medium format. But maybe the rich enthusiasts itís pointed at wonít know the difference."
    They're probably scared out of their minds. The D810, A7R and now the K-1 are already serious threats to their products. Here then comes a mirrorless product that seems to be around the size of a standard 35mm DSLR body but with a sensor twice the size. This camera will have to be pretty bad not to be a very serious competitor to any medium format camera out there, and in this case, the Hasselblad name doesn't hurt either.
  36. #186
    Mar 2009
    Massachusetts and Vermont
    947
    Please point me there. I need entertainment.
  37. #187
    Sep 2009
    1,587
    Quote Originally Posted by hcubell View Post
    https://www.cinema5d.com/hasselblad-...k-live-stream/
  38. #188
    Pratamnak
    9,336
    2157
    I just love the "too late to the party" argument. Too late compared to all the other medium format mirrorless cameras or too late compared to Canon, Nikon etc. who haven't even launched a 35mm mirrorless yet? Oh well....
  39. #189
    Oct 2012
    NykŲping Sweden
    1,191
    Doug never heard about the Phase One IQ3 50…
    But, he may have a point, I am not so sure about the advantage of a 50 MP 44x33 mm sensor over a 42 MP 24x36 mm one. No doubt, there is an advantage but it may be a small one.
    On the other hand, larger is larger and I think we are going to see a lot of iterations from Sony on the sensor side.
    Best regards
    Erik
  40. #190
    May 2014
    Oxford
    759
    I guess no one wants to buy any IQ140, IQ350 any more and now they only care about the sales of the 100MP (whose stock level is low at the moment however).
  41. #191
    Oct 2008
    Munich
    876
    As much as I hate people bashing on the XF which is an amazing camera. The other way around is only sad as well. Perhaps Doug really forgot all about Phase ones history which began with cropped sensors and even NOW there is ONLY ONE none cropped modern sensor which is the 100MP version
    Now I know of the IQ360/380 but, sorry, they are old and I would never consider them for these price points.
    Currently I shoot phase and I am looking for a second system. This one won't be for me as I probably go with Sony. However, it is a great package with a great price and I really hope they sell tons of them.
    Sorry Doug but only because Phase can't over something familiar a cropped sensor is suddenly bad. In a year or two it will have a new version which can easily has 120 or more million.
    The greatest thing I think is Sony is doing a lot on the sensor front. So there is no way we have to wait a long time for new developments like before. Steps will also be larger. Great times for photography.
  42. #192
    May 2013
    Los Angeles
    38
    9
    If this medium format mirrorless camera have 50 Mpix, sensor shift, and Sensor tilt control for a digital camera could be game changer foe landscape photography. If not ??????
  43. #193
    Apr 2008
    313
    I posted this on another forum as well.
    I think Phase one make great cameras. I know a bunch of people who work there and they are all talented and passionate. I happen to be a (passionate) Hasselblad user but that doesn't mean I feel I have to denigrate other brands. Research and buy what works for you or your business.
  44. #194
    Feb 2014
    London
    232
    give me a 200c MS sesnor in one of these and i will glue a canon 17mm TSE onto it
    and considering glue it to my hand/face !
    Keep It Simple.
    XQ2 / A7r / 15mm / 25mm / 28-35-50mm
    EOS M3 / 18-35mm
  45. #195
    Apr 2008
    313
    Hopefully Doug will chime in here and explain what exactly medium format is...
    Name:  Screen Shot 2016-06-22 at 7.32.06 pm.jpg
    Name:  Screen Shot 2016-06-22 at 7.32.52 pm.jpg
  46. #196
    Jan 2012
    1,198
    Utterly shameless!
  47. #197
    Jan 2012
    1,198
    No. Please don't encourage that discussion in this thread. Let's keep this about the new announcement.
    Kind regards,
    Gerald.
    (A very happy owner of Phase One backs who is delighted to see Hasselblad take this initiative and grow the MF market segment.)
  48. #198
    Mar 2012
    Sweden
    1,538
    In terms of the game changer bit, the most important part is the price, which of course leads up to a 44x33mm sensor. Hasselblad is for the first time interested to provide the masses with medium format cameras, and comes with a price that makes it quite possible. It's not as cheap as the 645z (yet), but it's a whole lot sexier to the general public. If Hasselblad succeeds with this new volume model, maybe in the longer term also the H system will come down in price.
    Many would have liked 54x41mm 100MP full-frame at $9k, but it's just not realistic. Manufacturing cost wise it might actually be these days, but you can't just put the highest end sensor in there in their consumer product.
    This product is not primarily aimed at current MF owners, but to those that look at buying say Leica SL or A7r-II and want something beefier. It will attract some current MF users too I think for sure, but I expect a bit more consumer-like UI and lacking some features pro users would want.
    I wonder if the camera has a focal plane shutter. Unfortunately I think it won't have which makes it much more limited than the A7r regarding its use on Actus/Universalis, and then we'll probably not see a metabones adapter to run the TS-E lenses, which otherwise would be really cool.
  49. #199
    Sep 2009
    1,587
    Why is a focal plane shutter better for use on an Actus etc than an electronic shutter? I wouldn't have thought it mattered?
  50. #200
    Jun 2015
    216
    If the thought police allow me to indulge in an opinion on the camera based purely on supposition then I think that key features will make or break its acceptance by certain sectors of the market.
    If there is no tethering then it's a non starter for a lot of working professionals, if it will not work with an Actus or similar that too will close off another market (especially if it offers nothing more than 8mp extra over an A7rII and a slightly bigger sensor) it's filming specs could be spectacular or purely a bullet point add-on like phase. Leica have followed the DSLR's and seen moving image as important to their mirrorless cameras, maybe HB will follow suit.
    Though it's not an attractive business proposition for me (8mp extra and less movements on my lenses if it works with an Actus) it looks absolutely perfect for a walk around travel camera to stake stunning quality images with if that's your thing.
    A few more hours and things will be a lot clearer.
    never trust the opinion of anyone who lists a load of gear in their forum signature. Dealers do not email me asking to buy your products.
