Hello,
I am having trouble tethering (via firewire) my P65+ back (5.2.2) to a macbook pro (early 2011) with MacOS Sierra. The back is set up to use battery as the power source. I am using a 5m 800 to 400 Neet firewire cable to connect to the mac. The back is not recognized in Capture One 9; it is also not visible in the firmware updater 3.3 software. Once the back is connected it freezes, none of the buttons work and the battery has to be taken out in order to switch the P65+ off and restart it. The back is not visible in Capture One either.
The same back works fine with my PC in all of the above scenarios; the only difference is a different cable (400 to 400 supplied with the back); however, the 5m 800 to 400 Neet firewire cable tests fine on another device when connected to the Macbook pro so both the cable and the firewire port on the macbook seem fine.
Is this a software compatibility issue? Does sierra have issues with Firewire connections? If so, what MacOS will provide full compatibility with the back Capture One 9 and 2011 macbook pro, please?
Many thanks,
Pat
Many thanks,
Pat
