Page 2 of 2 FirstFirst 1 2
Results 51 to 72 of 72
Thread: Has anyone seen or tried an HTS 1.5?
  1. #51
    Nov 2008
    UK
    561
    Re: Has anyone seen or tried an HTS 1.5?
    Quote Originally Posted by hcubell View Post
    I cannot give you the benfit of extended testing of the HTS, But I did have the opportunity to test it this weekend with my H3D-39 and the HC28mm lens, both untethered and tethered to a Macbook Pro. The bottom line for me is that it is way too difficult to focus accurately without the assistance of 100% image view on the Macbook, and that's just not realistic for me in the field. The HTS I tried out is owned by a highly skilled architectural photographer who is very happy with it and uses it frequently in his work, but he only shoots with it tethered. Perhaps Hasselblad can come up with some sort of tool for magnifying the image in the viewfinder(or another type of viewfinder) so that you can focus accurately with the HTS.
    BTW, when I was done trying the HTS, I put his HC35mm lens on the camera and took two exposures at different focus points and later used Helicon Focus to blend them. I have not had a chance to look real carefully but my initial reaction was that there was excellent sharpness through the whole image, including the corners, which surprised me a bit because the HC35mm lens does not have the best reputation among the HC lenses. For now, I will stick with Helicon Focus. It is an amazing piece of software that is giving me great results in many cases. It can't do everything the HTS can do, but for my work it is the most practical way to get extended DOF.
    Hi Howard,
    You could try the waist level finder as well. I think it takes a bit of time to tune in to the HTS, but with the HCD28 and the HTS I can get pretty good results with manual focus. I was using a waist level though.
    David
  2. #52
    Nov 2008
    UK
    561
    Quote Originally Posted by ptomsu View Post
    I am just using my grey cells for this: you put a lens between the lens and the camera to allow for these adjustment you want to achieve. No matter how good this lens is, it first has to amplify what the original lens produces in order to offer its service.
    This cannot be really good quality. Just all my experiences with teleconverters from different brans tell me this.
    Better would be a TS lens. Or tech camera.
    I have stayed away from this argument as it was well answered by others, but after speaking with the Product Manager a couple of weeks ago I have this to add.
    The HTS is optically designed together with the lenses. Not generic lenses but five different lenses that are relatively optically similar. Performance is not degraded measurably.
    Better would be a tech camera yes, but also consider usability in the field.
    I understand that you do not like converters (absolutely fair enough) but to say 'This cannot be really good quality' without using the HTS is unfair.
    If I showed you an image with the 28mm and the HTS, there would be no clue in the image if it was with or without the HTS.
    Thanks!
    David
  3. #53
    760
    David. I agree with you that when focus is spot on-- the images are outstanding. Sometimes i do have trouble but that is usually only when the iight is not optimal. I should have brought my level waist finder on this trip. I admit I have not tried the HTS with the level waist finder.
  4. #54
    Mar 2009
    Massachusetts and Vermont
    947
    Quote Originally Posted by David Grover / Hasselblad View Post
    Hi Howard,
    David
    Interesting, David. I wonder if the use of the waist level finder would facilitate the use of some sort of magnifying device. I know someone who has investigated a variety of such devices fro his Mamiya AFD III.
  5. #55
    Nov 2008
    UK
    561
    I can't remember off hand if the HVM is more magnified that the HVD90... ill find out.
  6. #56
    Fort Collins, Colorado
    2,077
    Magnification of the HVD-90X is 3.1 and the HVM is 3.25
    Woody
  7. #57
    760
    Regardless the HTS is a great device overall. It is much better than having to buy individual TS lenses. I wish the 120mm macro lens worked on the HTS but nonetheless-- great idea and well executed.
  8. #58
    Senior Member eleanorbrown's Avatar
    Feb 2009
    Houston and Keystone, Colorado
    706
    40
    Mark How does the HTS handle high frequency detail such as grasses, branches, etc. have you done any comparisons at say 100% of files done with the HTS against a file without the HTS...ie: just the lens, to get an idea about any possible loss of resolution with the HTS. Eleanor
    Quote Originally Posted by mark1958 View Post
  9. #59
    760
    I did some still life flower shots with small leaves and my opinion (although I did not keep extremely controlled comparison files) at this point there is very little loss of detail but I really need to do some testing in the field, which I will do this week. So i cannot say anything definitive yet.
    Quote Originally Posted by eleanorbrown View Post
  10. #60
    Nov 2008
    UK
    561
    80 x 1.5 = 120. Add the smallest extension tube and you are not far off!
  11. #61
    Nov 2008
    UK
    561
    Quote Originally Posted by woodyspedden View Post
    Woody
    Glad to know someone knows what they are talking about.
  12. #62
    Feb 2009
    706
    40
    David I'm assuming that with the HTS on my H2 camera and Phase back I will have use of the auto metering system when zeroed, is this correct? also will my H2 LCD on the grip have any read out as to settings of the HTS or not? (just got the camera back from NJ yesterday updated with firmware.) thanks! Eleanor
  13. #63
    Nov 2008
    UK
    561
    When you reach a certain level of tilt/shift the metering will automatically lock as it is then impossible to get an accurate reading. So either meter at 0 settings or verify with the histogram.
    The LCD will output HTS settings yes, but you will not get the benefit of these settings in the file meta data.
    David
  14. #64
    760
    I definitely have all the components to try this out -- If i were not so darn busy with my day job
  15. #65
    New York
    2,120
    66
    Hmmm . . . . started this thread three months ago hoping that someone would post center and edge crops with and without, and maybe an edge crop shifted 10mm. It doesn't have to be fine art - a neighbor's garage will do fine.
    Is there anyone who has or has access to an HTS 1.5 and is willing to take this on?
  16. #66
    Nov 2008
    UK
    561
    Hi Woody,
    I thought I had already done that but seems it was over on Loony Landscape.
    Apologies, and here are the shots..
    Zero'd
    Top Left @ 18mm Shift
    Top Right @ 18mm Shift
    Bottom Right @ 18mm Shift
    Bottom Left @ 18mm Shift
    A three way stitch so you can see coverage compared to the first centre shot...
    Enough?
    David
  17. #67
    Jan 2009
    Brockton,MA
    134
    34
    David,
    What camera do you used for the shots?
    Blas
  18. #68
    Nov 2008
    UK
    561
    Quote Originally Posted by BlasR View Post
    David,
    Blas
    H3DII-50 and the HTS with 28mm.
  19. #69
    Feb 2009
    706
    40
    OK I took the plunge and got the HTS and am learning to use it on my H2 with P45+ back. I've only had it a couple of days but bottom line is that quality is excellent and getting accurate focus on the edges of the frame involves a learning curve. You need good vision, your camera eyepiece set correctly and something with contrast to focus on. If you have these, focusing in reasonable low light is possible...sometimes challenging no doubt, but possible. Eleanor
  20. #70
    2,077
    Eleanor
    I love what the system was able to achieve with these two shots. Particularly the shot of the water at long exposure with the foreground in focus is impressive. Very Very nice
    Woody
  21. #71
    Feb 2009
    706
    40
    Thanks Woody. I'm getting the hang of using this device and what I like is that it works with 4 of my lenses and works well. (I really like having the option to use normal and short telephoto lenses with movements)... the whole key is to get the focusing correct, which I mentioned can at times be challenging. It allows me to make images I never could have made otherwise. I've had three 4X5 cameras in the past with film use along with a hasselblad Flexbody. This HTS allows me to carry only one system that has many options and uses...anything from hand held quick shooting to landscapes on tripod with movements. I don't need to carry an extra tech camera for use with my Phase back. eleanor
  22. #72
    Feb 2009
    706
    40
    Here is one of my first attempts, other than the initial testing inside my house. This is NOT meant to be a pretty or interesting image, only an exercise in using the HTS. This one done with the 80mm lens which ends up being about a 120. Keep in mind this is not a scientific study....the water was moving, there was a breeze, but even so I was impressed with the resolution top to bottom. First image was the entire frame and only sharpening used at all was the "pre sharpen #1" in Capture One. no other sharpening was done. Same with the next two images, one of the left edge and one of the right corner. (the images of the edge and corner at at 100%) Eleanor
