Page 3 of 3 FirstFirst 1 2 3
Results 101 to 113 of 113
Thread: thoughts on architectural with GFX, image circle and lens.
  1. #101
    Feb 2017
    9
    Re: thoughts on architectural with GFX, image circle and lens.
    Hello free1000,
    Yes, I have been using the HD DFA 35mm in my professional work extensively.
    The distortion on Pentax 645 HD DFA 35mm is very minimal and can be easily saved by a few settings, it's sharper and less CA at the corner compared to the A version. The A version not only have a curve back up mustache distortion but also very mushy at the corner, totally unusable IMHO.
    cheers!
    Quote Originally Posted by free1000 View Post
    Thats good news.
    I was wondering, since your post last December showing the Pentax 35 lens have you continued to shoot with it much? I notice you mention the Pentax HD D FA above, do you find the distortion acceptable? I'm mostly concerned with how this would handle shots perpendicular to an elevation where there are a lot of straight lines that can easily show the wave distortion in this kind of optic.
    In the end you preferred the FA version of that lens to the Manual A version, why was that? The A version can be purchased for a very reasonable price, so I'm tempted to give this setup a try out.
  2. #102
    Nov 2019
    Ireland
    3
    I'm a newbie here, and I wanted to share my version of a Fuji GFX / 680 hybrid that I've just finished. Still in the testing phase, but the results look good so far. I'm not an architectural photographer, but I do miss having a camera that has rise, fall, tilts etc. The lens can easily cover the full range of movements on the front standard (about 16mm each way from centre for rise, fall and shift), and I can change lenses easily with the Mamiya ring attached at the front. Mamiya lenses can be stopped down using the depth of field preview lever on the side of the lens without having to be attached to a camera, making it very easy to stop down when shooting. I'm using the Mamiya 65mm L-A which is about a standard focal length for this camera. I'll try to post results after I've done some proper testing.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	145324   Click image for larger version.
ID:	145325   Click image for larger version.
ID:	145326   Click image for larger version.
ID:	145327   Click image for larger version.
  3. #103
    Feb 2009
    Scottsdale, AZ
    599
    From one camera tinkerer to another, that looks to be some very nice work!
    Out of curiosity, how much does it weigh?
  4. #104
    Nov 2019
    Ireland
    3
    Quote Originally Posted by Audii-Dudii View Post
    Yes, that's the drawback of my camera, the weight. It comes in at 4.4kgs as a total package with that particular lens. I shoot location and studio work, so for me that's not such a big deal - I well remember carrying around my Linhof Technikarden with a polaroid back, DD slides, meter etc, but still no lightweight in these digital days. Still, it's my first foray into camera tinkering, and I'm already thinking of modifications.
  5. #105
    May 2009
    Marseille, FRANCE
    1,035
    Still waiting for Laowa to produce a 30 / 32mm PC for GFX with several rings to adapt it to canon, nikon, sony...
    it could be a great success...
  6. #106
    Feb 2009
    Scottsdale, AZ
    599
    Quote Originally Posted by SimonB View Post
    Well, when you create the Mk II version -- and you eventually will, if my experience of tinkering with cameras is anything to go by ... lol -- you can start shaving the ounces here-and-there then.
    In the meantime, use and enjoy it as-is!
  7. #107
    May 2009
    Marseille, FRANCE
    1,035
    Anyone tried the 24 ts-e II with the 1.4x on the gfx ?
  8. #108
    Feb 2009
    71
    SimonB -I'm a big fan of the Fuji GX680 and have one working one and one for parts. Could you share your construction method a bit? This looks an intriguing use of it with a mirrorless body. Thanks.
  9. #109
    Jul 2019
    63
    Quote Originally Posted by AndyPtak View Post
    Andy, there are options. Simon's is really nice; I wasn't aware of it. At Audii-Dudii's suggestion, I've used the Toyo VX23D to set up a Fuji GFX 50R-based outfit. Here's what it looks like:
    https://drive.google.com/open?id=1H0...4lCfQwvLo0KEAq
  10. #110
    Nov 2019
    Ireland
    3
    Andy, the production of the camera was a slow process. I removed the front standard and rail system from the GX680 (just undo the brass screws at the back and the grub screws that hold the rails in place) and that's the starting point. After testing different lenses the Mamiya RZ lenses proved to be the sharpest, and because they are designed for a 6x7 format provided a good image circle for camera movements. I did some drawings for the parts I wanted made, which were then draw up in a 3-D programme by a mate (Solidworks I think, see attached file), then these were milled by a CNC machinist and anodised by a local firm. The old GX camera body cost me about 200 euro, then the cnc work and extra bits and pieces came to about 750 euro, so the total was under 1000 euro. Since finishing the camera I have tried a Nikkor SW 90mm lens from my 5x4 kit, and it looks to be also a good option. The Mamiya 65mm LA lens gives as good as file as the Fujinon GF 63mm lens that I bought with the camera. Now looking at the Mamiya Z 110mm F2.
  11. #111
    Senior Member Antonio Chagin's Avatar
    Jul 2008
    Miami-Fort Lauderdale
    484
    7
    Quote Originally Posted by archivue View Post
    I've tried this combination (24mm TS-E II + 1.4X III) and is terrible for architectural photography standards. Is not bad in the center but very soft in the corners evenwithout shifting. I'm selling mine.
    Actually cropping in fron the standard 24mm or correcting the fuji 32-64 in Photoshop.
    What I'm trying to get now is the Hasselblad Carl Zeiss Distagon T* 50mm F/4 CF FLE and adapter to Canon EF to use in conjuntion with the Kipon CanonEF to Fuji GFX. It's a double adapter set up but using Kipon and KF adapters should do the trick.
    Not sure how sharp the Hasselblad Carl Zeiss Distagon T* 50mm F/4 CF FLE would be on the GFX 50R. If anyone tried plese comment.
  12. #112
    Nov 2010
    Munich/Guangzhou
    165
    Best 50 shift lens for GFX is the Canon TSE 50, I would say.
    Second best is the Hasselblad CF 50f4 FLE. Better use with Kipon Hasselblad V - Fuji GF shift adapter, you donít have to stack two adapters. Maybe slightly less sharp in the shifted corners and a bit more CA than the Canon but on the other hand 15 mm vs. 12 mm shift.
  13. #113
    Jul 2008
    484
    7
    Quote Originally Posted by chrismuc View Post
    Yeah Canon 50mm would be great, a little bit pricy though. I see the Hasselblad CF 50f4 FLE at around $750.
