ErikKaffehr
Imaging resource has comparable studio scene shots of the GFX, but also the Phase One IQ3100, the Pentax 645Z and other cameras. Now that Lightroom supports all of those I checked out the GFX and found it to have impressive detail. I tossed in the A7rII in the comparison as it is my presently most used camera.
Below are comparisons to the cameras uprezzed to IQ3100 image height:
The next question I asked my self, what happens in a print 40" height. I would say that looking at 180PPI on screen closely corresponds to looking at large prints at close range. So I rescaled the images to 7200 pixels height. That mean upscaling to 7200 pixel for Sony, Pentax and Fuji and downscaling for the IQ3100.
http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/7200res_centre.png
http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/7200res_corner.png
Sharpening was done before scaling i both cases, sharpening after resizing would leave less artefacts.
So, what did I see?
The Schneider Kreuznach 80mm LS f/2.8 has a fairly typical optical design, a 6 element double Gauss without field flattener. That kind of lens is often used for "standard lenses". For large apertures a 7-th focal plane flattening element is often added.
The GFX uses a quiete complex lens design. The front group is still a traditional double Gauss, with a additional ED lens to control chromatic aberration, but the field flattener is a triplet in two groups. The lens focuses using the front group, so it control focal plane curvature using variable air space. I guess Fuji is serious when they say the lens is calculated for 100 MP sensor resolution:
That is not saying that the Fuji lens is better than the Schneider, double Gauss designs can be very sharp, but Fujifilm has invested a lot of design work in that 63 mm medium aperture lens.
Best regards
Erik
- http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/8708res_centre_detail.png
- http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/8708res_corner_detail.png
- http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/8708res_moire_shot.png
- http://echophoto.dnsalias.net/ekr/Articles/FujiGFX/8708res_whibal_shot.png
So, what did I see?
- The Fuji GFX holds up remarkably well.
- It may be that the Schneider lens doesn't keep up with the sensor, but it seems to be well balanced with the sensor showing very little moiré.
- The Pentax 645Z lags behind the Fuji.
- The A7rII has the lowest resolution and it shows
Best regards
Erik
