Would you know if it is possible to use a Microsoft Surface Pro 4 with Firewire to tether a P45+?Okay...I'll say it.
It's a kludge. According to Phase One, "until there is an approved functioning adapter, you have to use a powered hub to get USB or FW to the back".
I've recommended my shooters to not upgrade yet or buy the previous version if they absolutely need a laptop. We should see OWC's new hub soon. In theory, you can use an adapter to connect to their Thunderbolt Dock 2 to the laptop, but I haven't tried it yet.
Denny
no you can't !Would you know if it is possible to use a Microsoft Surface Pro 4 with Firewire to tether a P45+?
Thanks.
http://www.apple.com/shop/product/MMEL2AM/A/thunderbolt-3-usb-c-to-thunderbolt-2-adapter?fnode=8b&fs=f%3Dadapter%26fh%3D4595%252B45b0Okay...I'll say it.
Denny
Yes I have also read that it is not possible to convert Firewire into USB.no you can't !
USB-c is great, one interface that will connect and power everything.Just another reason why Apple sucks in 2017.
enough power for an aptus via FW-800... to USB-C ?USB-c is great, one interface that will connect and power everything.
Yesenough power for an aptus via FW-800... to USB-C ?
I use a Hasselblad/Imacon Flextight with my 2016 MacBook Pro via USB-C->Thunderbolt->Firewire without issues. It looks ridiculous but it works....you cannot convert a FW signal into a USB signal.
Denny
This made me think of a support call I received one time....Now maybe the same system could be setup using an rc battery like that for a quadcopter, and the usb-c>thunderbolt2>firewire(with power injector wire).
Really ?I use a Hasselblad/Imacon Flextight with my 2016 MacBook Pro via USB-C->Thunderbolt->Firewire without issues. It looks ridiculous but it works.
Get an older generation Fuji Lifebook Tablet computer, like the T5010, they have Firewire (4 pin) built in and full power Intel processors + touchscreen for tablet mode. Works great. I used mine with P65+. Cheap solution, too.Would you know if it is possible to use a Microsoft Surface Pro 4 with Firewire to tether a P45+?
Thanks.
