glenerrolrd
As I am starting to do more landscape/seascape photography ...I feel a need to build a filter kit to match . I can go either or the two most common approaches ( 1) Screw IN filters ...82mm and 72mm covers most of my Leica S lenses ) or (2) Square Filters and Holder (I have the Wine Country Holder ).
The three most common filters seems to be :
(1) Polarizers ...I am fine with either the WCC POL or a Heliopan 82MM screw in ... Both have advantages and disadvantages .
(2) Graduated ND filters .....these seem to really only be effective in the SQUARE 4x6 form . I like the NISI but am just starting .
(3) IRND filters ....these I have almost no experience . My biggest question is WHAT STRENGTH is required to smooth the water . (assume F11-f13 is optimal ) .
CONTEXT ...Two scenarios represent my applications :
(1) Ocean at the JUNO BEACH PIER (Quick Google and you can see literally hundreds of photos ) ... right now I like the GRAD ND filters for sunrise /sunset ...but not sure about smoothing the water .
(2) IRELAND ..will be going on the IRELAND WORKSHOP with Peter Cox in late AUGUST to West Coast of Ireland .
I realize the square filter systems have much greater flexibility to mix and match filters (POL & GRAD for example )......but the VAR ND 82MM filters are now more readily available and a lot more convenient to just have in the bag .
Apologize for the long post but sometimes the context helps keep the feedback on point .
